| lawn tractor on steroids | |
+3CityRedneck mowerstompin race murry 7 posters |
race murry New Member
Age : 34 Join date : 2012-04-13 Points : 4401 Posts : 11 Location : wales
| Subject: lawn tractor on steroids June 21st 2012, 11:42 pm | |
| been geting bord with the tractors i got. seeing what u guys would think of a v8 powerd lawntractor just for racing and mudd racin tell me what u guys would think
mowerstompin Member
Age : 31 Join date : 2012-06-14 Points : 4355 Posts : 28 Location : Central Arkansas
| Subject: Re: lawn tractor on steroids June 22nd 2012, 12:18 pm | |
| I think id be to much work, time, and money to build something like that. Talkin serious frame strengthening, youd have to figure out the tranny, rear end stuff and all that. I personally think itd be a waste of money to be honest, a v8 just way much. Now if it was me and i wanted to use a different kinda motor then a vertical shaft mower engine id use a atv motor, and maybe a 125/250 dirt bike motor. Would be awrsome, fast and fun, and much cheaper. Dont get mr wrong a v8 mower would be different and neat i just personally wouldnt ever try and do it.
Good luck! | |
CityRedneck Member
Age : 27 Join date : 2011-08-13 Points : 4928 Posts : 241 Location : Winter Park
| Subject: Re: lawn tractor on steroids June 22nd 2012, 1:57 pm | |
| yea. but i get what he means with the v8 but it would be ALOT of work unless you have the parts and engine laying around. ive been wanting to put a small diesel engine in my tractor but might not and might just do a cr500 or cr250 engine in it | |
| Subject: Re: lawn tractor on steroids June 22nd 2012, 5:46 pm | |
| i got all the parts and u just bold a drive shaft to the moter and use a old hydro trans | |
fetters18 Member
Age : 26 Join date : 2010-12-18 Points : 4947 Posts : 59 Location : ohio
W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5035 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: lawn tractor on steroids June 23rd 2012, 4:09 pm | |
| When you think of it, Building a V8 Lawn mower would be cheaper then a cr250 or cr500 probably(if you had all the materials for frame strengthening), Looking Online I can get a 305 with an automatic transmission for $400 in working condition(60,000 km) and I can get a rear end from an older chevy truck for $100(with the driveshaft) and with some axle shortening it would look good. | |
| Subject: Re: lawn tractor on steroids June 23rd 2012, 4:13 pm | |
| i got a chevy 350 and trans and a lot of tractors to make it nothign better then ur dad working in a scrap yard to get free stuff | |
W1ldyOvvnZ Member
| Subject: Re: lawn tractor on steroids June 23rd 2012, 4:14 pm | |
| - race murry wrote:
- i got a chevy 350 and trans and a lot of tractors to make it nothign better then ur dad working in a scrap yard to get free stuff
if you willing to put in the time it would be cool. | |
matthew sidor Member
Age : 29 Join date : 2012-04-13 Points : 4575 Posts : 184 Location : Montesano, Washington
| Subject: Re: lawn tractor on steroids June 23rd 2012, 4:30 pm | |
| most guys just use the old drive shaft hydro transmissions and buy stronger gears so it can withstand the horsepower and custom make a drive shaft its a hell of a lot of work if you don't have all the stuff to make custom parts. I think its a waste of money unless you have the machines to make your own parts. but good luck. | |
W1ldyOvvnZ Member
| Subject: Re: lawn tractor on steroids June 23rd 2012, 4:34 pm | |
| - matthew sidor wrote:
- most guys just use the old drive shaft hydro transmissions and buy stronger gears so it can withstand the horsepower and custom make a drive shaft its a hell of a lot of work if you don't have all the stuff to make custom parts. I think its a waste of money unless you have the machines to make your own parts. but good luck.
I personally wouldn't do a V8, I would use a 4cylinder engine from a FWD car and put that in and turn it then put a rear end on it. Buying the stronger gears would be alot of money but the driveshafts aren't hard to make, its just alot of accuracy. | |
| Subject: Re: lawn tractor on steroids June 23rd 2012, 4:47 pm | |
| it was just a thought of a cool build im to busy to build one but maby later on down the road ill make it | |
| Subject: Re: lawn tractor on steroids June 23rd 2012, 8:08 pm | |
| Do it when your retired and have nothing else do to and have the money to do it. | |
| Subject: Re: lawn tractor on steroids July 5th 2012, 7:06 pm | |
| Anything's possible - ive seen some videos of a guy that wedged a small block chevy motor into a ATV - he was using it for local pull competitions.
Some shaft drive transmission would need to be used ( and modded) - heck use a narrowed car rear axle - Panzer tractors came stock with them.
Alot of fabbing would be needed.... | |
