 need a better clutch for my 1987 murry rear engine ridder
2 posters
murryforever123
murryforever123
need a better clutch for my 1987 murry rear engine ridder Empty
PostSubject: need a better clutch for my 1987 murry rear engine ridder   need a better clutch for my 1987 murry rear engine ridder Icon_minitimeSeptember 29th 2012, 1:32 pm
anyone have a good idea it has for a clutch for my murry it has a pulley swap but i dont have alot of room to work with on there???
murryforever123
murryforever123
PostSubject: Re: need a better clutch for my 1987 murry rear engine ridder   need a better clutch for my 1987 murry rear engine ridder Icon_minitimeSeptember 29th 2012, 1:40 pm
[quote="murryforever123"]anyone have a good idea it has for a clutch for my murry it has a pulley swap but i dont have alot of room to work with on there alsoo i have it to were i push the clutch in. it tightens the belt thats good when it dry when i gets wet it just sits there and spins cuzz it has no grip!!1
moremorelawnmowers
moremorelawnmowers
PostSubject: Re: need a better clutch for my 1987 murry rear engine ridder   need a better clutch for my 1987 murry rear engine ridder Icon_minitimeOctober 3rd 2012, 9:01 pm
The easiest thing to do is get a tighter belt and / or a tighter clutch spring. Another thing you can do to tighten up you clutch spring is to drill a new hole in the frame and mount it further away from the pulley so the spring has more tension on it. It is alot easier than building a new clutch.
https://www.youtube.com/user/moremorelawnmowers?feature=mhee
» Rear Engine Rider
» rear engine racer
» Rear Engine Off Roader
» Murray Rear Engine Tractor
