| | Honda gx390 exhaust ideas | |
goesman Member
Age : 45 Join date : 2012-01-18 Points : 4637 Posts : 119 Location : Salem, Mo.
| Subject: Honda gx390 exhaust ideas August 24th 2012, 1:28 pm | |
| I am running a Honda 13 HP gx390 that was originally used on a power washer. I am wanting do some thing different with the exhaust. I'm not looking for any thing loud so a quite muffler of some sort would be great. Any ideas | |
| | | goesman Member
| | | | matthew sidor Member
Age : 29 Join date : 2012-04-13 Points : 4575 Posts : 184 Location : Montesano, Washington
| | | | Hillbilly Homer Member
Join date : 2012-04-22 Points : 4624 Posts : 197 Location :
| | | | goesman Member
| Subject: Re: Honda gx390 exhaust ideas August 25th 2012, 4:11 pm | |
| Nope I am not lazy at all. I liked that one kit for it nice smooth bends and ready to go exhaust flange. I am going to go to Lowes and check out there galvanize conduit bends. I have used them before. I like the idea with the two mufflers put together. Its not to restrictive is it. Thanks | |
| | | W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5035 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: Honda gx390 exhaust ideas August 25th 2012, 5:15 pm | |
| I like the Tractor Exhaust by NR Racing, im not sure if they make them for the GX390's or if its only for the GX200's. I bought alot of my Parts for my Baja Warrior from there, never bought an exhaust from them though. | |
| Subject: Re: Honda gx390 exhaust ideas August 25th 2012, 6:54 pm | |
| - goesman wrote:
- I like the idea with the two mufflers put together. Its not to restrictive is it. Thanks
Not at all. i used 1" the stock outlet was less then 1/2. | |
| | | Chopperhed Moderator
Age : 57 Join date : 2012-10-14 Points : 5038 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Honda gx390 exhaust ideas December 10th 2012, 7:38 pm | |
| For custom exhaust on the GX390, you will either have to modify the stock manifols to take threaded pipe or build a new axhaust from the flange back.
The exhaust port is not threaded like some of the other engines.
I made a flange out of 1/4" plate, and brazed a piece of 1-1/8" galvinized flex to that, and brazed a piece of 1" conduit to the end of the flex. It exits out the rear under the fender
Be very careful when welding or brazing galvinized, zinc fumes are very very bad for you. | |
| | | Tractor Man Jeff Moderator
Age : 29 Join date : 2012-06-26 Points : 4797 Posts : 492 Location : Back in the sticks of VA
| | | | Sponsored content
| Who is online? | In total there are 26 users online :: 0 Registered, 0 Hidden and 26 Guests
