 How do you grease a transmission if there is no grease nipple?
13mudman13
PostSubject: How do you grease a transmission if there is no grease nipple?   Thu Oct 18, 2012 4:27 pm
How do u grease a dana spicer transmission if there is no greasenipple on the tranny
greener179
PostSubject: Re: How do you grease a transmission if there is no grease nipple?   Thu Oct 18, 2012 5:08 pm
if theres no grease nipple you got to open the trans and put some in if i were you i would add a few grease nipples when you have it open
CornishMorgan
PostSubject: Re: How do you grease a transmission if there is no grease nipple?   Thu Oct 18, 2012 5:16 pm
Indeed, but if your going to put grease nipples on, just drill the hole gently so you don't crack the casing.
If you don't know how to open the gearbox, check out this video by Fearlessfront.
This gearbox is a peerless but it's the same basic principle to open, grease and reseal it.
13mudman13
PostSubject: Re: How do you grease a transmission if there is no grease nipple?   Thu Oct 18, 2012 8:51 pm
Where do i put the grease nipples at
PostSubject: Re: How do you grease a transmission if there is no grease nipple?   Sat Oct 20, 2012 6:16 am
As an experement i put a few zerks in a mod MTD transaxle - i put mine where theyd be easy to grease - underneath near the axle ends and right by the main drive gear - they could be put pretty much anywhere except where itd interfere with anything inside - it just needs to be in the area, the grease will spread out.
I bot a box of grease fittings from harbor freight, a tap and die set and a good set of drill bits - you drill then tap the hole, then for added insurance i put a dab of locktite on the zerk to keep it in place.
If the tractor is trail ridden or mudded, id put them in an acessable spot , but pointing out the sides, so they wont be ripped off by debris.
13mudman13
PostSubject: Re: How do you grease a transmission if there is no grease nipple?   Sat Oct 20, 2012 11:17 am
How much did it all cost?
PostSubject: Re: How do you grease a transmission if there is no grease nipple?   Wed Oct 24, 2012 6:27 pm
Box of various sized zerks was like $5 - tap and die kit was like $15 - i used a step drill bit just a lil smaller then the zerk. All the stuff was at Harbor freight.
» How do you grease a transmission if there is no grease nipple?
» grease to oil conversion?
» adding grease fitting to the rear hubs
» Adding grease fittings to extend the life of your transaxle?
» Speed Build
