Welcome to the All-Terrain Lawn Tractor Forum! 2024 is the 10th and LAST ATLTF.COM BUILD-OFF . . . for now! |
| | vari drive + transaxle | |
fast adam Member
| Subject: vari drive + transaxle November 16th 2014, 8:59 pm | |
| i recently acquired a yard machine with a vari drive in it and im thinking about putting a 6 speed transaxle in it so then it will have a 42 speed tractor it will be un-pully swapped and im looking for any tips/estaments on the top speed if i get enough interest in it i will build it, so any help would be greatly appreciated (i got the idea from fearless front + i don't have know if anyone has done it before) | |
| | | Carshowkid Member
Age : 24 Join date : 2014-07-22 Points : 3955 Posts : 347 Location : Downers Grove Illinois
| Subject: Re: vari drive + transaxle November 16th 2014, 9:55 pm | |
| I would try to help you since I have a mtd w/ Vari drive... But I have no clue about gear ratios... Heck I have only drove my mtd once for about a min | |
| | | fast adam Member
| Subject: Re: vari drive + transaxle November 16th 2014, 10:04 pm | |
| Ya with the vari drive there's only f-n-r so I should figure out the ratio of the transaxle I think its probably the same as the 6-speed in 6th gear It should have alot of speed ranges | |
| | | Carshowkid Member
| | | | fast adam Member
| Subject: Re: vari drive + transaxle November 16th 2014, 10:25 pm | |
| Now what I'm wondering is, does the vari drive act like a governor/torque converter like if you go uphill | |
| | | Carshowkid Member
| Subject: Re: vari drive + transaxle November 16th 2014, 10:35 pm | |
| - fast adam wrote:
- Now what I'm wondering is, does the vari drive act like a governor/torque converter like if you go uphill
i don't think so... But don't quote me on that... cause I'm not sure. | |
| | | fast adam Member
| Subject: Re: vari drive + transaxle November 16th 2014, 11:33 pm | |
| I don't think so on second thought because it works by clutch movement and belt tension | |
Join date : 2012-12-21 Points : 6327 Posts : 2101 Location : Norway, Europe
| | | | fast adam Member
| Subject: Re: vari drive + transaxle November 17th 2014, 11:43 am | |
| Ya mine is just like that but a few years older. Mine has f-n-r on a panel between my legs si it would be very easy to put in a 6-speed | |
| Who is online? | In total there are 28 users online :: 1 Registered, 0 Hidden and 27 Guests PizzaKitty26Most users ever online was 412 on January 7th 2023, 7:59 am |
