| Exhaust/Stack Ideas | |
+19Thecrazyoldcraftman Doug Junkstarbuilds Ariens YT11 boggo Tractor Man Jeff CornishMorgan TheRainbowBoxer gearheadmike W1ldyOvvnZ Craftsman Dude Chopperhed TennesseeCowboy Bigal CityRedneck AcreFarm canadianromper dangeroustoys56 Crazymudder 23 posters |
TennesseeCowboy Member
| Subject: Re: Exhaust/Stack Ideas December 18th 2012, 2:07 pm | |
| Ok, so i took it off and found out that the engine part is threaded. And i found a piece of pipe that would thread into it. What should i do next? (Unless I should just leave it like this... ) Its pretty loud too, how would i make it have a deeper roar to it instead of a loud popping sound? | |
Tractor Man Jeff Moderator
Age : 29 Join date : 2012-06-26 Points : 4776 Posts : 492 Location : Back in the sticks of VA
| Subject: Re: Exhaust/Stack Ideas December 18th 2012, 9:54 pm | |
| You can only do so much with the sound. Small engines like these ain't going to sound like a 460 V8 gasser for sure. I found making the pipe bigger makes a deeper tone. Making a longer stack will also make it deeper, but it could be detrimental if you roll the thing over. Just try a bunch of ideas and see which one gives you the deepest tone. | |
Chopperhed Moderator
Age : 57 Join date : 2012-10-14 Points : 5017 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Exhaust/Stack Ideas December 18th 2012, 10:27 pm | |
| for deeper louder volume a megaphone is best. you have a threaded port. Go to a hardware store or any place that sells plumbing and heating supplies and for a few bucks, you can build a system that progressively gets larger as it extends. The longer and bigger the pipe the deeper it will get. For maximum effect, a cheapo motorcyle megaphone from motovan will add a bit of flash and some nice tones.. They have turn out styles Rat tail styles, anything you could want for motorcycle atv side by side and sled parts. They are canadian, so shipping south may be an issue. but i find I can get their parts from any serious bike shop in town. And If you look, you can find some very economical deals on go kart, dune buggy, cycle , atv, stuff. Sorry about the plug, but i love their catalogue. | |
Age : 53 Join date : 2010-02-10 Points : 6839 Posts : 1726 Location : Florida, USA
| Subject: Re: Exhaust/Stack Ideas December 18th 2012, 11:27 pm | |
| I ran shorty pipes ( temporarily) on my 18HP twin murray - thing sounded just like a harley davidson motorcycle. | |
boggo Member
Age : 28 Join date : 2010-08-22 Points : 5047 Posts : 64 Location : australia, victoria
Age : 28 Join date : 2012-08-05 Points : 4389 Posts : 124 Location : TEN-A-SAYY
| Subject: Re: Exhaust/Stack Ideas December 19th 2012, 11:52 am | |
| boggo, that setup is kinda like the one i was thinking of making. How does yours sound? | |
boggo Member
| Subject: Re: Exhaust/Stack Ideas December 20th 2012, 8:03 pm | |
| it sounded really good, nice thump to it but was abit loud being a black 11hp motor. lower revs should be fine though (i had mine screaming its head off). but everyone around my area likes it, so it did get alot of attention | |
AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4699 Posts : 208 Location : Tennessee
| Subject: Re: Exhaust/Stack Ideas December 20th 2012, 9:31 pm | |
| Not a stack, but this is my exhaust. It's 1" from the block, stepped to 1 1/4" for 24" then stepped to 2" for another 20". It's got a good, low rumble at low RPMs, with a decent bark when wide open | |
| Subject: Re: Exhaust/Stack Ideas December 20th 2012, 9:44 pm | |
| That there is what is called a good looking tail pipe. Well supported, and well built. Not to mention good smooth flow. Nice job | |
| Subject: Re: Exhaust/Stack Ideas December 21st 2012, 12:20 pm | |
| - boggo wrote:
- it sounded really good, nice thump to it but was abit loud being a black 11hp motor. lower revs should be fine though (i had mine screaming its head off). but everyone around my area likes it, so it did get alot of attention
Mine has an 11 hp, think that would be a problem if i run it wide open mostly? - AcreFarm wrote:
- Not a stack, but this is my exhaust. It's 1" from the block, stepped to 1 1/4" for 24" then stepped to 2" for another 20". It's got a good, low rumble at low RPMs, with a decent bark when wide open
I dig that. Looks really professional lol | |
| Subject: Re: Exhaust/Stack Ideas December 21st 2012, 1:05 pm | |
| - TennesseeCowboy wrote:
- Mine has an 11 hp, think that would be a problem if i run it wide open mostly?
Unless you remove the governor, these things are built to run wide open all day long. Removing the governor will negate that. Over revving these engines can cause severe damage. They are built to be best around 3000 to 3500 rpm depending on the engine. Some may even go as high as 4000. | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5462 Posts : 1089 Location : Galion, OH
| Subject: Re: Exhaust/Stack Ideas December 21st 2012, 1:19 pm | |
| Ours put up with ungoverned over revving just fine, but we also understand that we are reducing the life expectancy of the engine. In general, valve float will keep the RPMs down enough to prevent serious issues. For liability reasons, I would not recommend doing what we do though | |
| Subject: Re: Exhaust/Stack Ideas December 21st 2012, 1:26 pm | |
| Certain flathead flywheels have been known to explode, and cause some pretty severe injuries. I've had a flywheel come off after the threaded section broke on the crank, and the retaining nut disappeared. Some sanctioning bodies have outlawed rear engine riders due to exploding flywheels causing severe injuries. | |
| Subject: Re: Exhaust/Stack Ideas December 21st 2012, 1:41 pm | |
| I've heard that, and (other than modified engines) never seen any proof it happens. B&S would have to have the flywheels tested at a much higher RPM than stock for liability reasons. If you mod the engine to make the RPMs go past the natural ceiling that a stock engine has (like the racing people do), you would definitely have a point. The magnitude of a lawsuit facing B&S would be huge if a governor failed and the flywheel detonated. Would love to see someone get video of spinning one to the point of destruction to see what it would take.
Note: edited for clarity
Last edited by TheRainbowBoxer on December 21st 2012, 8:06 pm; edited 2 times in total | |
| Subject: Re: Exhaust/Stack Ideas December 21st 2012, 1:43 pm | |
| ...and like I said, I don't recommend anyone do what we do. | |
| Subject: Re: Exhaust/Stack Ideas December 22nd 2012, 9:07 pm | |
| Lol thanks for the tips guys but thats totally not what i was asking..I was wondering if his pipe setup would be unbearably loud if i ran wide open all the time But thanks anyways:) | |
Age : 27 Join date : 2012-10-31 Points : 4927 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: Exhaust/Stack Ideas December 22nd 2012, 10:27 pm | |
- Lol thanks for the tips guys but thats totally not what i was asking..I was wondering if his pipe setup would be unbearably loud if i ran wide open all the time But thanks anyways:)
To answer your question is yes it would get loud after a while. | |
| Subject: Re: Exhaust/Stack Ideas December 23rd 2012, 12:02 am | |
| To answer your Q: Any kind of straight pipe is gonna be pretty loud at throttle. | |
| Subject: Re: Exhaust/Stack Ideas December 23rd 2012, 2:14 pm | |
| Ahhh that sucks, I want it loud, just not destroying my ears loud haha | |
AcreFarm Member
| Subject: Re: Exhaust/Stack Ideas December 23rd 2012, 3:48 pm | |
| Where the exhaust exits will effect how loud it is for the operator. If you have a short stack that dumps around head-level it will be considerably louder for you than something that dumps below your head & out to the side, or out the back. My ATLT has no muffler at all, just the long pipe, and it is bearable for the operator. Not quiet... but definitely bearable. I mow with an 11hp Murray that has a straight-thru tractor muffler which dumps below the left footrest. It's not bad for the operator, but it's pretty loud for anyone off to the side of it. | |
| Subject: Re: Exhaust/Stack Ideas December 23rd 2012, 4:31 pm | |
| - AcreFarm wrote:
- Where the exhaust exits will effect how loud it is for the operator. If you have a short stack that dumps around head-level it will be considerably louder for you than something that dumps below your head & out to the side, or out the back. My ATLT has no muffler at all, just the long pipe, and it is bearable for the operator. Not quiet... but definitely bearable.
I mow with an 11hp Murray that has a straight-thru tractor muffler which dumps below the left footrest. It's not bad for the operator, but it's pretty loud for anyone off to the side of it. Some good info here, what about slightly below head level and pointed forwards? | |
AcreFarm Member
| Subject: Re: Exhaust/Stack Ideas December 23rd 2012, 4:44 pm | |
| I think anything right at, or just above/below head-level is going to be pretty loud... If it is an open exhaust. I've got a stack (straight-thru tractor muffler) on my Wheel Horse that ends above my head, and that's not too loud at all. But that wouldn't be a good option for a tractor that will be running thru brush and low-hanging branches. | |
| Subject: Re: Exhaust/Stack Ideas December 23rd 2012, 6:48 pm | |
| - AcreFarm wrote:
- I think anything right at, or just above/below head-level is going to be pretty loud... If it is an open exhaust.
I've got a stack (straight-thru tractor muffler) on my Wheel Horse that ends above my head, and that's not too loud at all. But that wouldn't be a good option for a tractor that will be running thru brush and low-hanging branches. i don't quite understand..did you use an actual tractor muffler? | |
AcreFarm Member
| Subject: Re: Exhaust/Stack Ideas December 23rd 2012, 8:20 pm | |
| On my regular mower, and my Wheel Horse I used tractor mufflers. My all terrain mower has no muffler, just the stepped tailpipe I made for it.
| Subject: Re: Exhaust/Stack Ideas December 24th 2012, 6:17 am | |
| My regular tractors all have mufflers, yet some stock are loud as hell - i ran open shorty headers on the ex mod murray with a twin - thing was pretty loud , but it was temporary ( didnt want to burn a valve) .
The older briggs flatheads are threaded and use bolts to hold the mufflers on - my 82 has both. My 70 toro has a threaded setup on the 5HP - the only issue with that is its right near the clutch pedal - if my foot slips, itll burn my sneeker - need to find some sort of way to change it - it also has a small piece of metal welded to the chassis holding it up - im not sure if it was stock that way or someone changed it . | |
AcreFarm Member
