80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Lend10PortalHomeFAQSearchMemberlistRegisterLog inDiscordCountdown Timer80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Rend10
Forum Rep : 39
80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Empty
PostSubject: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeTue Dec 25, 2012 10:18 pm
So I got this and the Craftsman around April when I was first getting into mower modding stuff. I think its an 80s tractor. Anyways, I like the look of it and it has a pretty heavy duty rear axle on it that looks kind of like a truck axle. Because of that and the mean tires that were on the back, I decided to instead of mod the body, use it as a pulling tractor and maybe possibly put a blade on the front to push snow.
I started teardown around May I think and havent really progressed since then (I sandblasted and painted the body pieces). The engine was bad and the one I was putting in it got used in my racer, so it didnt have any drive. I got another engine though that is close to running so I think ill dig this back up once the engine is finished being repaired.
Pics for now.
80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} 523124_428753877150955_1943868789_n
Condition after I pulled it off the trailer. Its been sitting a while, not a lick of red paint on it anymore.
80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} 551724_428754170484259_1972209209_n
Underside. Only downside to this machine is the fact the belt twists. It worked back then though, so itll work for me.
80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} 380760_428754637150879_572061584_n
11 horse Briggs.
80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} 294902_428753053817704_379901315_n
Hood + seat off. Steering wheel was tossed caused it flexed like rubber. Literally.
80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} 539284_428786763814333_2068388555_n
80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} 556598_428786900480986_1242929122_n
80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} 530015_428878577138485_581027234_n
80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} 550972_428878970471779_1371641186_n
I have it down to bare frame now, primered and ready for a coat of bedliner spray or something similar, but I put it away after the engine was used on something else so I dont have pics of it yet. Ill dig it out when my engine is ready to go on.
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeThu Dec 27, 2012 11:47 am
Man nice find. That's on hoss tractor. Put a horizontal diesel on that sucker and you could pull anything.
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeThu Dec 27, 2012 12:35 pm
Did you say you were going to do pulling with the tractor Doug?
http://pmwcm.forumotion.com/
Forum Rep : 39
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeThu Dec 27, 2012 12:52 pm
Not too sure yet. Ill probably make a trailer for it so I can haul wood when I get my chainsaw back. Or use it to pull around all my spare lawnmowers.
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeThu Dec 27, 2012 1:11 pm
Well I am trying to get into lawn tractor pulling myself, if that is what you are thinking about doing with your tractor.
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeFri Dec 28, 2012 2:11 am
Nice tractor - i always find it odd how manufacturer's could get away with twisting belts like that - my GT craftmans have twisted belts ( horizontal shaft motors to a side input trans) - my 69 simplicity has a similar setup also, because of the flex chassis it has ( twists in the middle just in front of seat).
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeFri Dec 28, 2012 11:57 am
John Deere 165 Hydros twisted the belt like that too Doug
crafsmankiller
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeFri Dec 28, 2012 8:56 pm
i honestly dont see anything wrong with belt twisting,as long as everythign lines up its fine with me. i also love that rear axle and wish i could find a mower like that.
Chopperhed
Chopperhed
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeFri Dec 28, 2012 9:20 pm
The ability to change direction is one of the greatest things about the good old fashioned vee belt.
When I was a kid we had a case 444 and the mower and snowblower were belt drive. from a horizontal motor to a pair of idlers out to the driven pulley. My ford has the basically same arrangement.
I've seen it on Combines and old swathers too.
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeFri Dec 28, 2012 9:21 pm
I think it is tecnically called a A belt cause the belt lookes like a A.
Forum Rep : 39
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeFri Dec 28, 2012 10:24 pm
A, V, either way, the walls arent parallel.
I dug the body out today and set it up on all fours, but without the Vanguard being in a running state its not going to do much.
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeSat Dec 29, 2012 7:32 am
A good example of belt twisting is our IH cub with a WOODS belly mower. It twists several times. It uses only one long belt.
80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Woods59c-5
80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Woods59c-6
AcreFarm
AcreFarm
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeSat Dec 29, 2012 12:15 pm
That will be a good puller/hauler for around the woods. That looks like a Peerless 2300 transaxle... very stout & can handle considerably more power if you ever decided to swap engines. I'd change the gear oil if you haven't already.
gearheadmike
gearheadmike
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeSat Dec 29, 2012 12:35 pm
That would be a perfect set up for a motorcycle engine all you would need is a jackshaft to run from left to right side lol
Forum Rep : 39
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeSat Dec 29, 2012 2:14 pm
My grandfather has a Cub similar to that one but the deck is different.
The transaxle is empty right now, I emptied it a while ago but haent filled it yet.
I cinsidered putting in a motorcycle engine of some sort but I decided to stay with a horizontal.
Forum Rep : 39
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeFri Jan 04, 2013 6:57 pm
So I ordered a pump for the engine last night. Should get it next week so hopefully I will have the Vanguard mounted.
98Murray
98Murray
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeMon Jan 07, 2013 5:53 pm
Good lookin Agway. That hill hold brake is something Murray only offered for a year on the GTs. You should check out MurrayOwnersWorld.com Lots of info on GTs. Look throught the info and you may find some info on your Agway.
Forum Rep : 39
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeMon Jan 07, 2013 6:12 pm
Ill have to do that. I posted about it on MTF when I first got it but nobody could ID it for me. Gonna try to keep this baby stock, other than attachments like a plow that im planning on building and a dually setup.
Forum Rep : 39
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeSun Apr 14, 2013 6:43 pm
Well I think I might dig this up again, im not sure yet. The Vanguard isnt running, however my Racer isnt either. So, instead of having the Kohler sit about, I was thinking of putting that in the GT as I had originally planned.
Nothing is for sure yet though, the chassis needs to be cleaned and primered again before paint, as well as the front tires being taken off so the rims can be cleaned and painted. We will see in the next month or so.
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeSun Apr 14, 2013 9:52 pm
Ok sounds good.
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeTue Apr 23, 2013 9:10 pm
what size is the vanguard?
check out my builds
mini deuce
and my youtube channel
Forum Rep : 39
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeTue Apr 23, 2013 11:59 pm
14hp OHV V-Twin.
GT actually might be getting an Arctic Cat 440 or something rather engine, in which case it will be built for speed. But itll be a sleeper if not too much needs to be molested. Still talking to my friend on getting the snowmobile from him.
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeWed Apr 24, 2013 3:27 pm
if it does get the snowmobile motor, would you consider selling the 14?
check out my builds
mini deuce
Forum Rep : 39
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeWed Apr 24, 2013 8:40 pm
Maybe, depends on what is going on at the time.
Forum Rep : 51
PostSubject: Re: 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy}   80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} Icon_minitimeSun Nov 17, 2013 9:09 pm
Looks like a sears transmission.
80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} 1023291?$gif$***Simplicity Off Road Research & Development*** #64 80s-something Agway GT 11 Pulling Tractor Build + Restoration {Pic Heavy} 1023291?$gif$
Simplicity Adventure Edition
Diesel Submarine Project
Baja Sears Suburban
Modified Briggs Model 5s
ATLTF.COM Race Truck
» Truckin42's Go Kart/Tractor Build
» How to Build a Pull Start!
» Gravely 1238-H Build
» StarPuss's Snapper LT12 Tractor Build (YouTube Videos )
