| | WHat everybody wantedfor a locked trans. | |
Murray modder Member
Join date : 2012-11-23 Points : 4585 Posts : 356 Location : Somewher in Va
| Subject: WHat everybody wantedfor a locked trans. December 31st 2012, 3:57 pm | |
| I fingured out a DETACHABLE OUTSIDE LOCK! I havent tried it yet because I dont have the parts, but I can find any holes in it. What if you had a rod with ball bearing supports (fearless has what Im taking about holding his axle for the racing mower) Then you'd add to gears to the ends, (justline the ones INSIDE a trans case) on the ends, the bearing supports could be mounted DIRECTLY TO THE TRANS AXLE., as there are mounts for the transaxle to the frame) Lastly, youd need to weld, or machine the axles to hold a gear on each side. (these go on the axles for the wheels.) This would DIRECTLY link both wheels, thereof, not needing any welding, so NO crap inside the trans. Anybody punch any holes in this idea? | |
| | | jaymz_eric Member
| | | | Doug Site Owner
Age : 28 Join date : 2012-12-24 Points : 7553 Posts : 3035 Location : Lebanon County, PA
| Subject: Re: WHat everybody wantedfor a locked trans. December 31st 2012, 4:40 pm | |
| Seems expensive and unnecessary. You could buy a duplicate transaxle off a scrapped tractor for the same price or cheaper than having to do all of the mill work, as well as all the parts required.
Plus since the gears are exposed, you run the risk of seizing them with rocks, gravel, etc and since they arent lubricated they would get hot and wear quick. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: WHat everybody wantedfor a locked trans. December 31st 2012, 7:39 pm | |
| I know you'd hae to have at least one spare transaxle or a bunch of spare gears. If the heat thing arised, Im sure you could revamp the entire thing to run off of chains and sprokets. and the only milling I was talking about is for the keyways for the gears/sprokets | |
| | | Tractor Man Jeff Moderator
Age : 29 Join date : 2012-06-26 Points : 4797 Posts : 492 Location : Back in the sticks of VA
| Subject: Re: WHat everybody wantedfor a locked trans. December 31st 2012, 9:04 pm | |
| In this hobby, a lot of stuff guys try is most of the time unnecessary. The point is to see how far and what kind of neat and sometimes wacky ideas we can attempt to try. Sounds like a neat idea. I'd be curious to see if it can be done. | |
| Subject: Re: WHat everybody wantedfor a locked trans. January 1st 2013, 5:56 pm | |
| Sounds alot like the old 60's hot rods/drag racers using a 'quick change' rear end - the rear end has a cover , pop the cover and 2 'stubs' with the gears are actually separate from the main rear axle ( little or no gear oil comes out) and can swap gears almost instantly. This is what one looks like: | |
| | | Marines2621 Member
Age : 26 Join date : 2012-12-31 Points : 4367 Posts : 215 Location : Mountainburg, Arkansas
| | | | Sponsored content
| Who is online? | In total there are 20 users online :: 0 Registered, 0 Hidden and 20 Guests
