| | New project, 60's Jacobsen. Anyone know anything about it? | |
BlackMountian88 Member
| Subject: Re: New project, 60's Jacobsen. Anyone know anything about it? February 20th 2013, 9:50 pm | |
| No unfortunately not. It needs $110 worth of parts to be perfect.
Just to get it started I need a coil ($30). Other parts needed air filter and housing, muffler, and oil drain.
Once I get a job hopefully I can finish it up and get it going agian. | |
| | | THE MTD GUY Member
Age : 26 Join date : 2013-02-15 Points : 4154 Posts : 69
| | | | Ariens YT11 Established Member
Age : 27 Join date : 2012-10-31 Points : 4948 Posts : 745 Location : The Wyo-Braska Panhandle
| | | | Chopperhed Moderator
Age : 57 Join date : 2012-10-14 Points : 5038 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
Age : 24 Join date : 2012-09-08 Points : 4677 Posts : 399 Location : NH
| Subject: Re: New project, 60's Jacobsen. Anyone know anything about it? February 21st 2013, 12:39 pm | |
| Yeah that was the same issue i had with my 69 wheelhorse - needed a new magneto and that was like $120 ( even then it wasnt guarenteed to run), swapped a 5HP honda on it and then found the trans had issues, it just needed too much work , was in too bad of shape and was missing too many parts.
Ebay might have some parts you need - itd be worth it to go check out local tractor shows/swap meets for parts youre needing also. | |
| Subject: Re: New project, 60's Jacobsen. Anyone know anything about it? February 21st 2013, 12:53 pm | |
| Yes, I checked eBay. There's just so many different Kohler. There's the k161, but it was put in half a dozen different tractors and each one is slightly different. I thought about dropping a new motor in, I found a 40's Briggs for $40, but I like this one so much! | |
| | | THE MTD GUY Member
| | | | Sponsored content
| Who is online? | In total there are 17 users online :: 1 Registered, 0 Hidden and 16 Guests AdnohMost users ever online was 412 on January 7th 2023, 12:59 pm |
