| | spicer tansaxle lost 6th gear i think | |
jaymz_eric Member
| Subject: spicer tansaxle lost 6th gear i think January 12th 2013, 8:21 pm | |
| the spicer transaxle in my lt1000 is loosing 6th gear, all the other gears work fine but 6th gear, no matter wat speed lunges real bad like it has teeth sheared off the gears or sumtin...any any ideas wat could have happened? | |
| | | Doug Site Owner
Age : 28 Join date : 2012-12-24 Points : 7553 Posts : 3035 Location : Lebanon County, PA
| Subject: Re: spicer tansaxle lost 6th gear i think January 12th 2013, 8:29 pm | |
| I think the gear got work out either where the shift keys move in or maye a few teeth broke off. Probably gonna have to open it up. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | avrappy New Member
Join date : 2012-12-26 Points : 4152 Posts : 16 Location : N. IDAHO
| Subject: Re: spicer tansaxle lost 6th gear i think January 12th 2013, 8:50 pm | |
| You should open it up. I opened mine. I was told mine had been replaced with a 5 speed. Turned out to be a 4 speed. I have the old one. It looks like they are the same. The 4 speed just has the gears aranged different. Biger steps between gears. I could make mine a six speed If I want. The just put spacer bearings in place of the missing gears. The only diff. is my new one has only one leg on the shift fork not two like the other one does. I would guess it's for being a shift on the fly. | |
| | | jaymz_eric Member
| | | | AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4720 Posts : 208 Location : Tennessee
| | | | jaymz_eric Member
| Subject: Re: spicer tansaxle lost 6th gear i think January 12th 2013, 9:41 pm | |
| yeah it was doing some gawd awful clackin in 6th gear spinning the ag tires in the snow/ ice trying to get traction.....ever since then it was jacked up.....maybe i will take it apart you guys got me curious now lol | |
| | | AcreFarm Member
| Subject: Re: spicer tansaxle lost 6th gear i think January 12th 2013, 9:46 pm | |
| I know it's a pain, but taking it back apart is a good idea. You don't want pieces of shift keys moving around in there; I've seen a case crack when a piece of shift key got into the gearset. | |
| | | | jaymz_eric Member
| Subject: Re: spicer tansaxle lost 6th gear i think January 13th 2013, 10:43 pm | |
| im not afraid of whats in it, the previous owner apperently tried getting into it and stripped a bolt out and then apperently tried to either drill it out or chisel it out, worse part is its down in this little square recess ontop the trans, no room to get it with vice grips or anything | |
| | | Chopperhed Moderator
Age : 57 Join date : 2012-10-14 Points : 5038 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: spicer tansaxle lost 6th gear i think January 13th 2013, 11:01 pm | |
| - jaymz_eric wrote:
- im not afraid of whats in it, the previous owner apperently tried getting into it and stripped a bolt out and then apperently tried to either drill it out or chisel it out, worse part is its down in this little square recess ontop the trans, no room to get it with vice grips or anything
\Can you cut the head off with a zip disc, and then remove the remainder after you have the case split? Its worked for me on several occasions. | |
| Who is online? | In total there are 20 users online :: 0 Registered, 0 Hidden and 20 Guests
