can someone tell me why my stock peerless on my craftsman lt1000 has the problem of not going into reverse (on the shifter) , when i shift what should be neutral is reverse, first is neutral, and 3 4 5 6 are the same? need it fixed asap
AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4720 Posts : 208 Location : Tennessee
The shift linkage may be loose or damaged. Or where the linkage bolts to the selector shaft on the transaxle may have worn into an oblong shape. I've seen that happen multiple times due to the bolt loosening up.
