 I propose a project.
Chopperhed
PostSubject: I propose a project.    Fri Feb 08, 2013 11:21 pm
Sort of an intellectual exercise.
I propose we fantasy build the ultimate off road tractor.
All participants would propose the best features/options/engines/tires/mods. etc, and would then explain why. With diagrams and reasons why.
Parts would all have to be standard Garden/Lawn tractor parts from whatever year, or from whatever brand.
The first step will be to determine what represents the ultimate ALL TERRAIN tractor.
Results to be voted on by the team (meaning members)
Next step is to find a way to get the right parts to the right people to build it.
We film it all , start bto finish. post it on you tube, with an independant witness, ( I bet we could find a dozen desparate internet journalists to get all over it) sell it, and give the cash to a childrens hospital.
Just an idea
Murray modder
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 12:06 am
I'd have to say a V-twin for the imense power, (Im biased, the only engine I own is a briggs v twin, and a khler I never work on) and Id LOVE to see some ATV arms on this thing that function just like on an atv. I have a Corvette manual, they use the U jounts for rear suspenion flex (unlike out staright axles) WHy couldnt we chop our axles a bit and add atv front drive systems to it? Seems legit to me...
Chopperhed
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 12:24 am
Now your thinking.
IRS rear ends are easy.
Murray modder
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 1:11 am
They're not the cheapest parts, and our reliable craigslist probably wouldnt fail, But I have absolutely no idea how the heck you'd manage to mount this thing strut rods maybe,Ill look into how the vette did with em, back in the 70's...
Chopperhed
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 1:18 am
remember the idea is to stick to tractor parts.
Id f it showed up on a stock factory built tractor, we can use it, no matter the modification
Murray modder
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 1:59 pm
I see, but they might be able to use a straight axle, tied with the joints i mentioned earlier, (Im positive an atv or something used em, I know they have to be used for the front end on 4wd atvs) To ATV wheels, Thats would make her with rear suspension, and the transaxle could stay stationary like that. and the wheels for the front could go the same way, what could make it 4wd.
dked41
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 3:11 pm
Transverse leaf spring, don't know how it would work on a tractor with belt driven transaxle. Straight axle might work.
dked41
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 3:21 pm
I was thinking of a 4wd articulated tractor using 2 hydraulic drive Case lawn tractor axles.
Chopperhed
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 4:18 pm
That would be cool too
Murray modder
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 8:41 pm
We need to figure out tank treads....THAT! would be amazing..
Chopperhed
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 11:00 pm
Scrounge up an worn out pair of 44" mudders. Cut out the sidewalls, stretch them over a pair of tires. Voila, instant tracks.
Of course there are half a dozen other ways to do it it too.
Buy a pair of scrap sleds with matching drives.
Build a track using salvaged large pitch chain,sprockets and welded plates
Spend the bucks ( about a grand I figure ) and buy #100 chain and sprockets, with steel idlers, and then weld plates to the chains to act as treads.
Take the time to build a chain from steel flat bar, steel rollers and bronze bushings with hardened steel pins, then weld those to tread plates, make your own sprockets, and idlers
Use the existing system from a small tracked unit, like a ditchwitch or bobcat.
Use two endless strips of rubber joined by steel bars, running on rubber tires.
Thats six.
All these methods have been used
Murray modder
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 11:40 pm
I suppose we'd have to have 6 wheels for that eh? Or, Make this thing like a zero turn for four wheel.
Webmaster
Webmaster
Forum Rep : 28
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 11:44 pm
Halftrack.
Murray modder
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 11:53 pm
Halftrack? what is it? But I think the main goal is...4wd, and has ATV suspension...and hopefully, a Way to make rear suspension.
Webmaster
Webmaster
Forum Rep : 28
PostSubject: Re: I propose a project.    Sat Feb 09, 2013 11:56 pm
A halftrack is just that. Wheels (or skis) in the front, tracks in the back.
As for rear suspension any horizontal shaft would do, then you could do leaves easily enough. Or even coilovers.
Murray modder
PostSubject: Re: I propose a project.    Sun Feb 10, 2013 12:11 am
So, basicly its a snow-mobile.
Webmaster
Webmaster
Forum Rep : 28
PostSubject: Re: I propose a project.    Sun Feb 10, 2013 12:24 am
I think half-tracks have been around longer, but yes, like a snowmobile if 2 were taped together and the inside skis removed..
Murray modder
PostSubject: Re: I propose a project.    Sun Feb 10, 2013 12:32 am
so 6 axles?
Webmaster
Webmaster
Forum Rep : 28
PostSubject: Re: I propose a project.    Sun Feb 10, 2013 12:38 am
so 6 axles?
Yes.
If you want to ask more about it I suggest making a new thread in an off-topic forum. We have strayed from the topic enough already.
PostSubject: Re: I propose a project.    Sun Feb 10, 2013 6:59 pm
Panzers came with a narrowed dodge rear axle - stock - so a car rear axle could be used. Toyota trucks have a small differential.
» Project Peenemünde!
» Project 45 For Sale
» Cheap go kart project
» Another project to add to the list.
» weekend project
