| | Been lurking awhile, first post with new project. Lifted Craftsman! | |
+29crazykid1994 k2500life numbnutz muddstir Ddwannabe mudmonkey06 redlinemotorsportts Kel WellThatsSurprising SkiLLz redneck999 genegillis5 xxXMowerdudeXxx dylansrockinrigs Chopperhed gearheadmike Thunderdivine Murray modder richie thomas TheRainbowBoxer Tractor Man Jeff matthew sidor truckin42 avrappy Stretch44875 THE MTD GUY Doug W1ldyOvvnZ fireman 33 posters | |
fireman Member
| Subject: Re: Been lurking awhile, first post with new project. Lifted Craftsman! December 7th 2013, 8:26 pm | |
| Not really an update but I took the tractor to it's first show at the end of September and it was a huge hit. Most people around here had never seen anything like it before. I barely had time to sneak away and roam around the show because of all the interest and questions. I actually turned down an offer to buy it for a $700 from a guy who's kid really wanted it. I decided not to paint it and leave a stock theme to it. | |
| | | Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7102 Posts : 2914 Location : Ontario Canada
| | | | richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6184 Posts : 1434 Location : east dublin georgia
| | | | TroyBilt Pony Established Member
Join date : 2013-06-01 Points : 4594 Posts : 578 Location : West Virginia
| | | | fireman Member
| Subject: Re: Been lurking awhile, first post with new project. Lifted Craftsman! December 8th 2013, 9:01 am | |
| Yeah the rubber bungee is holding the brake lever back. I haven't found the right spring yet or should I say I ran out of time before other projects called! I have to weld a nut on to the square tubing for the lift so I can attach the spring when I get it. I guess I got all winter to get that done! | |
| | | fireman Member
| | | | redlinemotorsportts Moderator
Age : 27 Join date : 2013-03-18 Points : 7267 Posts : 3131 Location : raleigh nc
| | | | fireman Member
| Subject: Re: Been lurking awhile, first post with new project. Lifted Craftsman! August 18th 2014, 11:27 am | |
| it's been a long time but finally got back to the Craftsman. If you followed my build there were a few things I still wanted to do but hadn't got to. The shifter extension would flex at the top to allowing me to shift accurately without playing hide and seek. Since i'm on vacation I decided to have a go at it. As you can see in the picture I fabricated a rigid mount to "grab" the top of the extension so it would rotate in stead of trying to bend. It actually works pretty good but the gears are very close together only taking about half of the normal shift range. I was wondering why I was looking at it then it struck me, I had offset the extension. So even thought it works it's still not working as I want it. I have to move the extension so it's directly over the shift bolt that goes into the transmission. Should be no big deal. I'm just gonna weld plated on the sides off the original bracket with like a 3" rise and a plate at the top of those. Then weld the extension to that so it should work properly. Leaving two sides open will allow me still get the bolt out if ever necessary. I'll post more pictures and an update when I finish. Should be sometime this week. " /> | |
| | | MoMower Member
| | | | Sponsored content
| Who is online? | In total there are 25 users online :: 0 Registered, 0 Hidden and 25 Guests
