| 04 husqvarna mudder/trail rider | |
mudmonkey06 Member
Age : 28 Join date : 2013-03-18 Points : 4378 Posts : 327 Location : Rindge, NH
| Subject: 04 husqvarna mudder/trail rider August 21st 2013, 11:40 am | |
| hey guys. been off for a couple months now. i got a new tractor for free and have started making it into a mudder. its a 04 husqvarna that has hydrostatic and it came with a 20 horse kohler. The kohler needed a carb and those are expensive so i swapped on a 12.5 horse briggs. this is how it came stock this is after i swapped the engine and put tires on it. i brought it on a romp and climbed a fallen wood pile i want to swap in a peerless at some point and i need to get a new belt tell me what you guys think | |
Age : 29 Join date : 2013-03-18 Points : 4709 Posts : 618 Location : loxahatchee, florida
| Subject: Re: 04 husqvarna mudder/trail rider August 21st 2013, 12:11 pm | |
| Hydros aren't all that bad. Lol. You can pulley swap them on the engine. And the torque you can get outta them isn't bad. I have a Murray with a hydro I used to use to pull out other lowers with | |
Age : 27 Join date : 2013-03-18 Points : 7267 Posts : 3131 Location : raleigh nc
TennesseeCowboy Member
Age : 28 Join date : 2012-08-05 Points : 4410 Posts : 124 Location : TEN-A-SAYY
| Subject: Re: 04 husqvarna mudder/trail rider August 21st 2013, 3:40 pm | |
| Honestly, I would try to say that I would either sell or mow with a free mower that is that new...but that thing looks way too mean to pass up turning into a mudder! Interested to see how this turns out! | |
k2500life Veteran Member
Age : 26 Join date : 2013-06-19 Points : 5155 Posts : 1135 Location : Southern Florida
mudmonkey06 Member
| Subject: Re: 04 husqvarna mudder/trail rider August 21st 2013, 7:27 pm | |
| if i put the kohler back in i would need to put everything back where it was. i welded a new battery box where the gas tank was and put the tank up front. what im going to do is swap in a different transaxle so it goes faster than 5 miles per hour. | |
| Subject: Re: 04 husqvarna mudder/trail rider August 21st 2013, 7:32 pm | |
| - mudmonkey06 wrote:
- if i put the kohler back in i would need to put everything back where it was. i welded a new battery box where the gas tank was and put the tank up front.
what im going to do is swap in a different transaxle so it goes faster than 5 miles per hour. haha cant sling mud at that speed | |
mudmonkey06 Member
| Subject: Re: 04 husqvarna mudder/trail rider August 22nd 2013, 9:52 pm | |
| - crazykid1994 wrote:
- you can pulley swap i hydro and amke it faster. i went 12 mph on a hydro. 20" tires pulley swapped
how did it not burn up | |
| Subject: Re: 04 husqvarna mudder/trail rider August 22nd 2013, 9:59 pm | |
| because it doesnt just burn up unless you dont take care of it. it has good oil in it and the fan was on it to keep it cool. and i always washed it after to help keep it cool and clean. | |
mudmonkey06 Member
| Subject: Re: 04 husqvarna mudder/trail rider August 23rd 2013, 1:59 am | |
- because it doesnt just burn up unless you dont take care of it. it has good oil in it and the fan was on it to keep it cool. and i always washed it after to help keep it cool and clean.
good point. i just reall dont want to put effort into making the hydro work better because i plabn on swapping it in the near future | |
mudmonkey06 Member
| Subject: Re: 04 husqvarna mudder/trail rider August 23rd 2013, 1:09 pm | |
- Well pulley swap the engine I mean
the engine is dying and will be swapped also it burns oil and i found oil in the carb the only good part on that engine is the block . | |
| Subject: Re: 04 husqvarna mudder/trail rider August 23rd 2013, 2:09 pm | |
| you could still pulley swap? lol. i would. and just ride it till the engine died. it could just be to much oil so its blowing through the pcv valve. | |
