| | more F N R problems | |
jaymz_eric Member
| Subject: more F N R problems Wed 06 Mar 2013, 4:16 pm | |
| ok in my other post i was talking about my F N R on my new craftsman givin me problems. I got the kill switch problem fixed but she still " lurks and lunges " basically if i put in drive and let out on the clutch theres a second or two delay before she starts to creep, once shes movin she lunges real bad, does this in reverse to. one mower mechanic said it was a s ealed unit and my best bet was to ride it around and see if it breaks itself back in. all the brakes are disconnected so its not that and the belt is tight as a drum.....any ideas? thanks guys! | |
| | | Chopperhed Moderator
Age : 57 Join date : 2012-10-14 Points : 5038 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: more F N R problems Wed 06 Mar 2013, 4:51 pm | |
| I'd be checking the variable pulley to make sure it moves freely, Mine did that when I first got it. | |
| | | jaymz_eric Member
| Subject: Re: more F N R problems Wed 06 Mar 2013, 6:00 pm | |
| what is the variable pulley exactly? are you refering to the drive pulley on top of the transaxle? if so its what i would consider stiff, it takes me pushin pretty hard with one finger to get it to move any.....how could i fix that? | |
| | | Doug Site Owner
Age : 28 Join date : 2012-12-24 Points : 7553 Posts : 3035 Location : Lebanon County, PA
| Subject: Re: more F N R problems Wed 06 Mar 2013, 6:06 pm | |
| - jaymz_eric wrote:
- what is the variable pulley exactly? are you refering to the drive pulley on top of the transaxle? if so its what i would consider stiff, it takes me pushin pretty hard with one finger to get it to move any.....how could i fix that?
The vari-drive pulley is the double pulley where the two belts loop around, ususally in the tractors midsection. It runs needle bearings and if you dont lube it right, itll seize. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | jaymz_eric Member
| Subject: Re: more F N R problems Wed 06 Mar 2013, 6:10 pm | |
| I dont have that all.....mine runs from the motor pulley straight thru to the tranaxle, clutch and tensioner..... | |
| | | Doug Site Owner
| Subject: Re: more F N R problems Wed 06 Mar 2013, 6:15 pm | |
| Might be something wrong in the transaxle. Has it ever been apart? Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: more F N R problems Wed 06 Mar 2013, 6:46 pm | |
| Heres a variable pulley : There has to be some sort of 'transmission' - unless the trans is a hydro - FNR transaxles have no actual stepped gearing - just forward and reverse - to get any sort of motion, youd need to contantly have your foot on the clutch like a hydro to moderate your speed. Any way to get pics of this setup on your tractor? | |
| | | jaymz_eric Member
| Subject: Re: more F N R problems Thu 07 Mar 2013, 9:58 am | |
| mines the hydro from what I'm told......and yes i can get some pics on here hopefully tonight, im at work right now | |
| | | crafsmankiller Member
Age : 26 Join date : 2012-10-18 Points : 4677 Posts : 412 Location : livingston texas
| Subject: Re: more F N R problems Thu 07 Mar 2013, 11:25 am | |
| if it has a shifter on the side with a rabbit and/or turtle diagram thingy, or foot pedals that you use to control speed then its a hydro | |
| Who is online? | In total there are 16 users online :: 1 Registered, 0 Hidden and 15 Guests MightyRazeMost users ever online was 412 on Sat 07 Jan 2023, 6:59 am |
