| Talk About Anything Thread V1 | |
+38Crazy_Carl TedTheDestroyer TN_Murray Double W Cross Ranch Lawren Wimberly AllisKidD21 CraftsmanQuad19 RichieRichOverdrive MightyRaze Rockinator marmower prancstaman MatthewD willis923 Craftsman1998 TheBeal jamcco mr.modified LAWN MOWER MUDDER craftsmancole T-Dub13 bbuckler 1997 Murray motorizedeverything redlinemotorsportts Chopperhed Murray modder Kel davidgt6000 crafsmankiller mudmonkey06 Ariens YT11 Thunderdivine truckin42 xxXMowerdudeXxx WellThatsSurprising TheRainbowBoxer Doug 42 posters |
| Subject: Re: Talk About Anything Thread V1 December 10th 2017, 1:42 pm | |
| Oh, thats too bad. Cool trans, wonder what it looks like on the inside. Weird how it has a bunch of bolts on the underside like that. | |
Age : 23 Join date : 2016-04-12 Points : 5718 Posts : 2617 Location : Indiana
Age : 25 Join date : 2016-07-10 Points : 8349 Posts : 5190 Location : Ontario Canada
| Subject: Re: Talk About Anything Thread V1 December 10th 2017, 1:59 pm | |
| That trans looks just like one we swapped into Carter's Jake except that one doesnt have the hi/lo range. It has the shift collar system kinda like an FNR so no shift keys. Also like Rich said all the bolts are on the bottom, which is kind of a pain hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4692 Posts : 1944 Location : Kansas
Age : 49 Join date : 2016-09-06 Points : 14946 Posts : 10556 Location : Oklahoma
| Subject: Re: Talk About Anything Thread V1 December 11th 2017, 12:44 pm | |
- Oh, thats too bad. Cool trans, wonder what it looks like on the inside. Weird how it has a bunch of bolts on the underside like that.
We will find out. I'll bust into it in a couple months. The serial # badge is missing from the tractor so I don't know exactly which year yet. I have done 0 investigating at this point. LOL It sure is a bit smaller than I thought. About a foot shorter frame than the Murray GT for next year. Frame has a bend in the back, but it should be super easy to straighten out and I can easilly brace it. As well as the front grill. | |
| Subject: Re: Talk About Anything Thread V1 December 11th 2017, 1:49 pm | |
| Assuming the engine is factory, should be pretty easy. I assume its a briggs. Pretty sure you know how to read those, but to everyone that doesn't, the year is the last two digits in the "Code" set of numbers. This applies to all briggs engines that I know of. Don't know about kohler, Tecumseh, or Kawasaki. EDIT: on second thought, that is a Tecumseh. The intake is on the bottom and exhaust on top, Briggs are opposite of that. Anyone know how to read Tecumseh tags? | |
| Subject: Re: Talk About Anything Thread V1 December 11th 2017, 3:03 pm | |
| i had a Tecumseh engine just like that, had a aluminium strip on one of the crankcase bolts that had the numbers on it. it was just kinda sticking outand got broken off
muckmudd Established Member
Age : 21 Join date : 2017-07-11 Points : 3323 Posts : 825 Location : In the shop
| Subject: Re: Talk About Anything Thread V1 December 11th 2017, 7:11 pm | |
| Just out of curiosity anyone here ever done rallying or built a rally car? kinda looks fun and dangerous to me.
| Subject: Re: Talk About Anything Thread V1 December 11th 2017, 10:09 pm | |
| The shroud has the #s on it. I got it pulled off tonight. Looking into the #'s I think it is Tecumseh. There was crud between the starter and flywheel causing the grind. Not filled with water as I thought, I think it is Gas coming out. That is fixable. Also, this old engine appears to have really good compression. Pretty hard to one hand it. I may try to fix this engine? See how it goes. | |
Age : 21 Join date : 2016-10-29 Points : 6503 Posts : 3563 Location : Lewisburg, KY
| Subject: Re: Talk About Anything Thread V1 December 11th 2017, 11:23 pm | |
| I actually watched like 10 Group B rally vids earlier lol. Makes me think about doing a rally themed tractor...
You can read the Tecumseh codes, I don't remember how though. | |
| Subject: Re: Talk About Anything Thread V1 December 11th 2017, 11:26 pm | |
| Just visually, this thing looks to be a 917.255274, (1979-81?) but that model is suppose to have a BRIGGS in it not a Tecumseh? This has a Tecumseh, 143336022 SER 3165D. That would be a June 14, 1983 Engine. SER "3" year ending number 165=day of year, to my knowledge.
Issue, the newer ones have sloped fenders, this one has flat fenders. All the flat fenders I have seen with tecumseh do not have the transaxle I have, but a transmission with chain.
EDIT: I am thinking engine swap somewhere down the line. GRR... Model plate is missing from the tractor. | |
| Subject: Re: Talk About Anything Thread V1 December 11th 2017, 11:39 pm | |
- I actually watched like 10 Group B rally vids earlier lol. Makes me think about doing a rally themed tractor...
You can read the Tecumseh codes, I don't remember how though. me too man maybee thats what i will do with my new craftsman lt4000. | |
| Subject: Re: Talk About Anything Thread V1 December 13th 2017, 4:03 pm | |
| - mightyraze wrote:
Sorry Allis, I think I have decided to do a solid axle on the little craftsman on the right. Widen it a bit. Maybe go with a speed type build. On the left I am still torn on the front suspension. Neither will have rear suspension. | |
| Subject: Re: Talk About Anything Thread V1 December 13th 2017, 4:27 pm | |
why do you guys do solid axles on speed builds? ist that super sketchy when turning corners? my mud mower skreetches when is turns corners and it isnt even pulley swapped. | |
| Subject: Re: Talk About Anything Thread V1 December 13th 2017, 4:36 pm | |
| Because the axles are 1 inch verses 3/4 inch and are wider, also the gearboxes have no differential to break and you can play with the sprocket sizes to give more torque or speed for different driving conditions. Its just more durable than having a differential and lets the axle be higher up in the frame for more stability
| Subject: Re: Talk About Anything Thread V1 December 13th 2017, 4:40 pm | |
| But i personally like tranaxles for mudding because you can put more torque on the input shaft and case than a gearbox, . i have blown two gearboxes because of having too aggressive tread and to much hp with very little belt slippage , so they do have limitations but for racing i consider them a better solution | |
| Subject: Re: Talk About Anything Thread V1 December 13th 2017, 6:36 pm | |
| - biggasmowers wrote:
- Because the axles are 1 inch verses 3/4 inch and are wider, also the gearboxes have no differential to break and you can play with the sprocket sizes to give more torque or speed for different driving conditions. Its just more durable than having a differential and lets the axle be higher up in the frame for more stability
I thought you meant that you guys were solid axle swapping transaxles. I see what you mean by more options as far as speed and good brakes go. I got a kinda neat setup in my sears 88 series that im taking apart where there is a 4 speed foote transmission that is chain driven to a rear axle that has a small little diff in the middle of it. im planning on using it when i make my speed/rat rod build. | |
| Subject: Re: Talk About Anything Thread V1 December 13th 2017, 7:07 pm | |
| I am still planning. Biggest issue I have for next year is budget, since I am planning 2 builds. I think I will keep it unlocked for now. I will bust into that trans. I do know I am thinking fixed front axle, wider. I would like to figure out how to widen the back just a bit as well without compromising the transaxle. | |
Doug Site Owner
Age : 28 Join date : 2012-12-24 Points : 7531 Posts : 3035 Location : Lebanon County, PA
| Subject: Re: Talk About Anything Thread V1 December 13th 2017, 10:15 pm | |
| They use solid axles to keep traction, the steering is usually solved with the front axle angles. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
TheBeal Veteran Member
Age : 29 Join date : 2013-06-06 Points : 5475 Posts : 1398 Location : Central PA
| Subject: Re: Talk About Anything Thread V1 December 14th 2017, 9:42 am | |
| Ah, I think I figured out the hardest part of next year's build-off entries. Names! I have them stored away so I do not forget them. I have toyed with some other names, but I think I have that nailed now. I'll give those names out when I enter the build-off! I'll give a little suspense! | |
| Subject: Re: Talk About Anything Thread V1 December 14th 2017, 12:23 pm | |
| - Doug wrote:
- They use solid axles to keep traction, the steering is usually solved with the front axle angles.
I read that the ideal angle is 10 degrees. | |
| Subject: Re: Talk About Anything Thread V1 December 14th 2017, 7:48 pm | |
| My 700 for next year's buildoff is here! Gotta wait til Christmas to open the box though, lol. Probably best that way, dont need to distract myself any more than usual, or get too much of a start on the build. | |
