The day I brought it home..a block down from my house with a free sign..motor mounts went bad and took out all the shear pins and the deck was shot
Started with the engine and deck pull..got everything cleaned up, new air filter, fuel filter, gas line, ran new bolts for engine mounts, bypassed safety switches, and rebuilt carb.
After finishing the engine I then dropped the differential and replaced the shear keys that were bad.
I figured since I had the differential out I would do a pully swap and decided to put a 4 inch on the back making it a 1:1 ratio
After a few good romps and durability tests I decided it was ready for more upgrades
Started stripping badges getting it ready for paint
Fresh paint moved the rear tires to the front of the machine with extended spindels and got some garden tractor tires for rear
Before
After....So let me know what you guys think! and thanks for looking! Future mods include car tires front truck tires back, kc lights and a brush guard, differential lock, small winch. If you guys have any ideas let me know. SkiLLz
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5462 Posts : 1089 Location : Galion, OH
You might want to upgrade to a higher quality rear pulley... those cast aluminum ones will wear through, and it will take your belt with it when it goes.
My build (Chaos is one of 3 built like this) Chaos Build
