| Front Suspension | |
+12CornShuck4CE Doc Sprocket k2500life FOSWMT redlinemotorsportts dked41 richie thomas Thunderdivine Doug W1ldyOvvnZ truckin42 Kel 16 posters |
FOSWMT Member
Doc Sprocket Site VIP
Age : 50 Join date : 2013-04-21 Points : 7081 Posts : 2914 Location : Ontario Canada
| Subject: Re: Front Suspension September 29th 2013, 11:09 am | |
| Try sending a message directly to him... | |
CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 3999 Posts : 337 Location : Woodville Al
| Subject: Re: Front Suspension April 9th 2014, 7:50 am | |
| by richie thomas on Wed Apr 17, 2013 7:24 pm why not mount a single leaf spring the length of your front axle ? You cpuld but you would have to have a 4 or 3 link setup to keep the axel in place. | |
CornShuck4CE Member
| Subject: Re: Front Suspension April 19th 2014, 3:27 pm | |
| This is the front of my murray widebody LT. This is the 4 link bars on the side of the frame. This is the panhard bar on front. This is the front look at the motor and shock tower This is the finish product. This is mostly made of lawnmower parts and some off of a chineas atv. I rebuilt the steering and changed it all over to single tierod and atv tierod ends. All link rodends come from www.racingrodends.com. Link bars where custom made out of tool steel. Works great. | |
rarbaugh07 Member
Age : 35 Join date : 2014-01-22 Points : 3840 Posts : 117 Location : Logan, iowa
| Subject: Re: Front Suspension April 19th 2014, 5:03 pm | |
| That is awesome! Great mod very little weight added for the increase in performance. | |
CornShuck4CE Member
| Subject: Re: Front Suspension April 19th 2014, 6:12 pm | |
| Thanks alot. I wonted to keep it as original lookin as possible. Your build sparked alot of ideas as well. I had thought of mounting tranny on its side how does that work out. The hardest part of the front suspintion was working out the shock tower and how to support it and keep it all under that small murray hood. | |
rarbaugh07 Member
| Subject: Re: Front Suspension April 19th 2014, 7:16 pm | |
| Ya same here was going for the stock look. Trans works great and you could run any style of suspension with it that way. | |
jamcco Member
Age : 24 Join date : 2014-01-04 Points : 3979 Posts : 226 Location : New Hampshire
CornShuck4CE Member
Age : 27 Join date : 2013-03-18 Points : 7246 Posts : 3131 Location : raleigh nc
| Subject: Re: Front Suspension April 20th 2014, 8:37 pm | |
| Im impressed CornShuck! Nice work, i think that is a first in the tractor modding world. Slick work, are you going to get different shocks or leave it?
jamcco Member
| Subject: Re: Front Suspension April 20th 2014, 8:38 pm | |
| ok thanks also do you know how much flex you have with the shocks (i have the same shocks laying around) | |
CornShuck4CE Member
| Subject: Re: Front Suspension April 20th 2014, 8:55 pm | |
| Thanks red. Your leaf spring build really impressed me aswell. I wonted to be the first with a four linked lawnmower. I have plans for rear but that will take lots mor time an money. I ride this mowchine just about everyday. So it being down to do mods is hard. As for the flex im not shure somewher around 8 inches i guess. It wasent really built to flex mostly for going fast in rough areas. More like a baja mower. For now it runs 30mph. But since the steering is so much tighter now i think im about to boost it up again. Maybe when i rebuild. The 820 ill do so. The front axel is also mounted in about a 10 degree towards the rear like a auto front axel. This allows the front tires to stay pounted forwards even with hands off the wheel and it will return to center from a turn. Never really looked at it as a baja but i guess it works. | |
| Subject: Re: Front Suspension April 20th 2014, 9:04 pm | |
| - CornShuck4CE wrote:
- Thanks red. Your leaf spring build really impressed me aswell. I wonted to be the first with a four linked lawnmower. I have plans for rear but that will take lots mor time an money. I ride this mowchine just about everyday. So it being down to do mods is hard.
As for the flex im not shure somewher around 8 inches i guess. It wasent really built to flex mostly for going fast in rough areas. More like a baja mower. For now it runs 30mph. But since the steering is so much tighter now i think im about to boost it up again. Maybe when i rebuild. The 820 ill do so. The front axel is also mounted in about a 10 degree towards the rear like a auto front axel. This allows the front tires to stay pounted forwards even with hands off the wheel and it will return to center from a turn. Never really looked at it as a baja but i guess it works. I was looking into 4 link myself because my leafs flex around a little to much. But the price of heims kinda push me away from doing it. how much, and what size were youre heim joints? | |
jamcco Member
| Subject: Re: Front Suspension April 20th 2014, 9:07 pm | |
| cool and yah i am going for "baja" like performance right now. as my project sits i have plenty of of flex on the front axle, but the mower likes to 3 wheel the corners. when i say 3 wheel i mean i have to jump off of it to stop it from rolling. i dont want to lock the axle so i decided i wanted some shocks. the hydraulic car trunk shock setup works well at low speeds but not high speeds. i litterally looked at a mini quad i have lying around a year ago and thought of this design. im glad that some one else has used it and has had success with it. once again thanks for the pointers | |
CornShuck4CE Member
| Subject: Re: Front Suspension April 20th 2014, 9:40 pm | |
| Thay are 3/8-24x3/8. I think they where around 4 dollers each with nuts 5 are righthand and 5 are lefthand. The bars are custom machined out of tool steel. ( what drill bits are made of. ) there very strong. The joints come from www.racingrodends.com And if you would like any special pix just ask. I took it out riding april 19 and thrashed ot pritty good and held up like a champ. Id give myself a pat on the back but you guys are doin a great job. Soon as i get my internet back ill do a walk around and put it on youtube. | |
MurryMaddnes Member
Age : 38 Join date : 2014-03-24 Points : 3698 Posts : 32 Location : Green Bay Wisconsin
| Subject: Re: Front Suspension April 20th 2014, 10:54 pm | |
| I really like what you did with your front suspension I will stealing the idea in a way, there are several changes I would like to make but everything should work out as planned I hope. Thanks for posting this. | |
CornShuck4CE Member
| Subject: Re: Front Suspension April 21st 2014, 6:15 am | |
| I would like to what changes you would make. It might be better than what iv done. | |
tanis Member
Age : 24 Join date : 2014-03-04 Points : 3719 Posts : 37 Location : New Hampshire
| Subject: Re: Front Suspension April 21st 2014, 7:44 pm | |
| im working on building a 4 link system right now this was very helpful to design mine | |
CornShuck4CE Member
| Subject: Re: Front Suspension April 21st 2014, 7:47 pm | |
| Im going to start its own thread in a day or so | |
