| | Foote tranny problem | |
+3Stretch44875 Ariens YT11 theswampmachine 7 posters | Author | Message |
theswampmachine Member
| Subject: Foote tranny problem May 13th 2013, 11:51 am | |
| I was riding my mower and it was in 4th gear and all of a sudden it locked up. So I put it in third and worked fine along with 1st and 2nd so then I tried 4th again and it more like 5 feet then locked up again. And ever since then it's only moving in reverse no matter what gear does anyone know what happened? | |
| | | Ariens YT11 Established Member
Age : 27 Join date : 2012-10-31 Points : 4927 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: Foote tranny problem May 13th 2013, 12:16 pm | |
| Well you need to take the tranny out and tear the tranny apart then you will know whats wrong. Lots of work but worth it. I had problems with my foote 3 speed tranny also but took it apart and cleaned it all and it works fine. | |
Age : 49 Join date : 2012-04-05 Points : 5464 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: Foote tranny problem May 13th 2013, 12:44 pm | |
| Sounds like something seized up. Only way to tell is tear it down...
Does shifter still move, and all gears are reverse?
| Subject: Re: Foote tranny problem May 13th 2013, 1:11 pm | |
| Ok so I just took it apart and all I found was that one tooth was broken off in 4th gear I pulled the piece out but should I be worried about it? Also it seems to all Work just fine now | |
Age : 49 Join date : 2012-04-23 Points : 5462 Posts : 1089 Location : Galion, OH
| Subject: Re: Foote tranny problem May 13th 2013, 1:16 pm | |
| the piece of tooth was probably wedged in the gears. If you got the piece out, it should work ok. | |
| | | | crafsmankiller Member
Age : 26 Join date : 2012-10-18 Points : 4656 Posts : 412 Location : livingston texas
| Subject: Re: Foote tranny problem May 14th 2013, 8:50 am | |
| id think you'd still have 4th, but there would be 'slack' when it gets to the broken tooth | |
| | | xxXMowerdudeXxx Established Member
| Subject: Re: Foote tranny problem May 14th 2013, 10:03 am | |
| I woulnt use 4th for fear of breaking off another tooth, but is should still work good | |
| Subject: Re: Foote tranny problem May 15th 2013, 12:04 am | |
| does anyone know where i could get parts for it at? i cant seem to find any parts for it. its a foote 3865 | |
| | | MowBandit Member
Age : 28 Join date : 2013-03-16 Points : 4512 Posts : 477 Location : Haddock,Georgia
| Subject: Re: Foote tranny problem May 15th 2013, 12:19 am | |
| ive me the full model number and ill see if i can find 4th gear for you | |
| Subject: Re: Foote tranny problem May 15th 2013, 1:24 pm | |
| - theswampmachine wrote:
- does anyone know where i could get parts for it at? i cant seem to find any parts for it. its a foote 3865
I think my tranny is a Foote 3965 I'll look today and will edit this post later. | |
| Who is online? | In total there are 19 users online :: 1 Registered, 0 Hidden and 18 Guests CrazycraftsmanMost users ever online was 412 on January 7th 2023, 7:59 am |
