| Two Wheel Tractor | |
+5jamcco Thunderdivine redlinemotorsportts Moose truckin42 9 posters |
truckin42 Veteran Member
Age : 25 Join date : 2012-10-04 Points : 5265 Posts : 1070
| Subject: Two Wheel Tractor October 23rd 2014, 8:42 am | |
| My latest project, the old fashion two wheel tractor. Built from a tiller. Its got a 6.5 hp motor with a 3 speed tranny (locked) and 22'' tires. It is geared allitle to high right now... in low gear at about quarter throttle it does jogging speed lol. | |
Moose Established Member
Age : 34 Join date : 2014-01-12 Points : 4713 Posts : 919 Location : Defiance, Ohio
| Subject: Re: Two Wheel Tractor October 23rd 2014, 11:30 am | |
| sounds like it is geared just right to be a segway! | |
| Subject: Re: Two Wheel Tractor October 23rd 2014, 3:19 pm | |
| Make a chariot style platform to stand that articulates off the tiller. Perfect for tiller racing! Lol | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6305 Posts : 2101 Location : Norway, Europe
| Subject: Re: Two Wheel Tractor October 23rd 2014, 4:21 pm | |
| That's cool, so that means no more the one in your Avatar pic. | |
| Subject: Re: Two Wheel Tractor October 23rd 2014, 8:12 pm | |
| That's a good idea Redline.. I just might do that.
As for the build in the avatar picture, that build I stopped because I figured that since it was a tiller I could use most of the original parts and only have to modify it alittle bit to turn it into a Two wheel tractor.
With the 22in cut turf tires, running almost 0psi and with the locked tranny this thing will go absolutely anywhere. Im gonna be putting together a series of test and obstacles, and steep hill climbs to really put this thing to the test. the frist offroad only two wheel tractor. | |
jamcco Member
Age : 24 Join date : 2014-01-04 Points : 3978 Posts : 226 Location : New Hampshire
| Subject: Re: Two Wheel Tractor October 23rd 2014, 11:57 pm | |
| - truckin42 wrote:
- That's a good idea Redline.. I just might do that.
With the 22in cut turf tires, running almost 0psi and with the locked tranny this thing will go absolutely anywhere. Im gonna be putting together a series of test and obstacles, and steep hill climbs to really put this thing to the test. the frist offroad only two wheel tractor. i mean i think we've all had a 2 wheeled tractor at one point....it may not have been intentional but..... | |
ZSmachines Member
Age : 24 Join date : 2014-08-27 Points : 3754 Posts : 221 Location : PNW
| Subject: Re: Two Wheel Tractor October 24th 2014, 1:44 am | |
| So I'm not trying to be rude or snarky or anything, but honestly what is the point of a two wheeled tractor? You can't really ride it, so what do you do with it?
| Subject: Re: Two Wheel Tractor October 24th 2014, 9:30 am | |
| Well im not exactly sure but they were made for gardening back around 1913 and been around ever since. Its basically a little tractor, They are built to pull, tow, do garden work, and felid work. Pretty much everything a tractor can do just on two wheel and a smaller set up and they were cheaper to buy than an actual tractor.
But the bad part about em is that they are walk behind lol. | |
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5208 Posts : 1311 Location : NW USA
| Subject: Re: Two Wheel Tractor October 24th 2014, 10:38 am | |
| I put mustang tires on my simplicity rototiller when i was 8 (5 hp briggs) and i added on little wheels on the back that I could stand on and i rode it around it was fun before i had a mower. | |
| Subject: Re: Two Wheel Tractor October 24th 2014, 6:09 pm | |
| - 1997 Murray wrote:
- I put mustang tires on my simplicity rototiller when i was 8 (5 hp briggs) and i added on little wheels on the back that I could stand on and i rode it around it was fun before i had a mower.
Interesting, Did it have any steering? | |
| Subject: Re: Two Wheel Tractor October 25th 2014, 9:42 am | |
| there was a slot 1/2" in the back that held a 3/8" bar (to hold the tiller back) with little 10" wheels. it was angled down and forward from the mount, but I turned it around so it angeled backwards and if I leaned against the handlebars it would flex a bit and I could turn. | |
fast adam Member
| Subject: Re: Two Wheel Tractor October 25th 2014, 10:11 am | |
| you shoud find a rear engine tractor frame and drop it in that it, and boom your ready to go. | |
| Subject: Re: Two Wheel Tractor October 29th 2014, 8:09 am | |
| - fast adam wrote:
- you shoud find a rear engine tractor frame and drop it in that it, and boom your ready to go.
That's actually a pretty good idea, I might do that if i can find one cheap enough. | |
fast adam Member
| Subject: Re: Two Wheel Tractor October 29th 2014, 8:26 pm | |
| ya you could probably find one with a blown engine on craigslist for cheap. | |
| Subject: Re: Two Wheel Tractor October 31st 2014, 2:02 pm | |
| Yeah, iv been looking around and I found one for 100 buck but it runs and drives great apparently. I can got one cheap for about 50 bucks just gotta keep my eye on craigslist. | |
fast adam Member
| Subject: Re: Two Wheel Tractor October 31st 2014, 3:55 pm | |
| You should be able to find one, it would be great for mudding because you have the weight of the engine to help you dig. | |
| Subject: Re: Two Wheel Tractor November 17th 2014, 8:50 am | |
| - fast adam wrote:
- You should be able to find one, it would be great for mudding because you have the weight of the engine to help you dig.
Yeah, it also has a straight axle set up so posi traction all the time. Gonna take this thing out today and go on it frist offroad trip... This should go good | |
fast adam Member
| Subject: Re: Two Wheel Tractor November 17th 2014, 1:18 pm | |
| - fast adam wrote:
- So what does it look like now?
The same as it did lol, Looks of it never changed. | |
fast adam Member
| Subject: Re: Two Wheel Tractor November 17th 2014, 1:35 pm | |
| So I still don't know what it ever looked lil other then the 1st picture | |
| Subject: Re: Two Wheel Tractor November 17th 2014, 5:16 pm | |
| I took this pictures today, This is what it looks like. I don't have a picture of what it looked like befour I turned it into a two wheel tractor. All I know is is its an 80s model sears tiller. | |
fast adam Member
| Subject: Re: Two Wheel Tractor November 17th 2014, 6:57 pm | |
| so how to you ride it? do you have any video of it? | |
Doc Sprocket Site VIP
Age : 50 Join date : 2013-04-21 Points : 7080 Posts : 2914 Location : Ontario Canada
fast adam Member
| Subject: Re: Two Wheel Tractor November 17th 2014, 7:18 pm | |
| - Doc Sprocket wrote:
- Maybe remove the tines?
no I bet the tines would help in mud/sand, unless you go at high speeds then I would remove them. | |
ZSmachines Member
| Subject: Re: Two Wheel Tractor November 17th 2014, 7:20 pm | |
| Build a snow plow and A set of wheels that attatch to the original spikes think that goes into the ground to hold the tiller back, and make it articulated. Then make a pedestal seat on top of those wheels to sit on, and turn it by pushing the handles like you normally do. But a snow and dirt plow would be sick, and should work well as the weight would be in the drive wheels! | |
