| the murray | |
+9Craftsman Dude race murry TheRainbowBoxer craftsmancole richie thomas redlinemotorsportts k2500life Thunderdivine crazykid1994 13 posters |
k2500life Veteran Member
Age : 29 Join date : 2013-03-18 Points : 4687 Posts : 618 Location : loxahatchee, florida
| Subject: Re: the murray July 2nd 2013, 10:08 pm | |
| do you know if moores sells tire tubes for mower tires? | |
Age : 26 Join date : 2013-06-19 Points : 5133 Posts : 1135 Location : Southern Florida
| Subject: Re: the murray July 2nd 2013, 10:09 pm | |
| thanks. i need to fix my goflat tire :p | |
| Subject: Re: the murray July 4th 2013, 5:05 pm | |
| got all the parts to finish the stack to my snorkel. all i need is a filter that will fit ocer 2" pvc pipe. and my belt... | |
| Subject: Re: the murray July 4th 2013, 6:28 pm | |
| actually i might bring the stuff back and go with the existing filter i have... i cant find a fitting filter | |
| Subject: Re: the murray July 4th 2013, 10:46 pm | |
| Ya I had to cut some radiator hose in half and zip tie it on to be able to put my k&n on | |
| Subject: Re: the murray July 4th 2013, 10:50 pm | |
| well i got the parts for my airbox... im going to try modifying some way to make my filter fit with the new pipe. Its 2" pipe now instead of 1-1/2" | |
| Subject: Re: the murray July 4th 2013, 10:54 pm | |
| Nice mine gave me more power and acts as a cold air intake. Took the mower to the deep trail today bad idea water was over my snorkel had to get pulled back HAPPY FOURTH | |
| Subject: Re: the murray July 4th 2013, 11:20 pm | |
| damn. sounds like you have some work to do now | |
| Subject: Re: the murray July 4th 2013, 11:21 pm | |
| Ya just had to drain it out its good now | |
race murry New Member
Age : 34 Join date : 2012-04-13 Points : 4379 Posts : 11 Location : wales
| Subject: Re: the murray July 5th 2013, 8:23 am | |
| i have a filter that fits my carb. but im changing the setup. i need to get a reducer from 2" to 1-1/2" | |
| Subject: Re: the murray July 5th 2013, 10:02 am | |
| gunna make my airbox out of a 4"-2" reducer and cut slots in it for air. pictires hopefully later today. and my belt should be in
| Subject: Re: the murray July 5th 2013, 8:41 pm | |
| got my snorkel done. i think it looks good. needs to be painted. got pictures. will post when i get back. got a belt but it doesnt work eright when i hit the clutc so i need a bigger belt... | |
| Subject: Re: the murray July 5th 2013, 9:00 pm | |
| Nice looking forward to seeing it and shoot | |
| Subject: Re: the murray July 5th 2013, 9:14 pm | |
| thanks. obviously removable so i can clean the filter
| Subject: Re: the murray July 5th 2013, 9:18 pm | |
| its running nice and open. i need to run some injector cleaner through my carb tho. and find a 93" x 1/2" belt
Craftsman Dude Member
Age : 29 Join date : 2012-09-08 Points : 4374 Posts : 145 Location : MS
| Subject: Re: the murray July 5th 2013, 10:18 pm | |
| Very nice a little paint to match it to the tractor and it will be perfect plus if you decide it isn't tall enough would be easy to extend ,have you tested it yet?
| Subject: Re: the murray July 5th 2013, 10:31 pm | |
| no craftsmandude. no working belt yet. need to order one to drive it yet
| the murray | |
