| 70's Wheel horse C-120 mud crawler trail rider | |
+28TheBeal AllisKidD21 Crazy_Carl tscustoms mr.modified RuggBateman donaldcon kawasaki220 offroadking MoMower TroyBilt Pony T-Dub13 Lawren Wimberly murrayracer truckin42 willis923 gearheadmike Doc Sprocket mudmonkey06 Jerbear0612 redlinemotorsportts greener179 k2500life Stretch44875 Doug LAWN MOWER MUDDER TheRainbowBoxer Creepycrawler 32 posters |
T-Dub13 Established Member
Age : 36 Join date : 2013-07-02 Points : 4781 Posts : 731 Location : Logan Ohio
Join date : 2013-06-01 Points : 4572 Posts : 578 Location : West Virginia
| Subject: Re: 70's Wheel horse C-120 mud crawler trail rider April 10th 2014, 10:03 pm | |
| Easiest way to make a key way is to find a bolt a little to big and use a bench grinder to grind it to a square a little bit at a time. Then buzz the head off of it | |
| Subject: Re: 70's Wheel horse C-120 mud crawler trail rider April 10th 2014, 10:22 pm | |
| Ive made keyways in a pinch, and they work, but over a year or two of hard riding, they eventually eat out the keyway, because they arent perfectly square. I usually just run to the hardware store and get new ones if I lose my old ones. Red, why not 1080 30 fps? thats what I shot in last time. I ordered two extra batterys earlier this week, hopefully it gets here in time, and yes it is like a rockwell, bout as heavy too, dang cast iron case..... | |
| Subject: Re: 70's Wheel horse C-120 mud crawler trail rider April 10th 2014, 10:40 pm | |
| - Creepycrawler wrote:
- Ive made keyways in a pinch, and they work, but over a year or two of hard riding, they eventually eat out the keyway, because they arent perfectly square. I usually just run to the hardware store and get new ones if I lose my old ones. Red, why not 1080 30 fps? thats what I shot in last time. I ordered two extra batterys earlier this week, hopefully it gets here in time, and yes it is like a rockwell, bout as heavy too, dang cast iron case.....
You get more storage time in lower res. i can get a hour or two out of mine, 32 gig card i think. quality is basically the same | |
| Subject: Re: 70's Wheel horse C-120 mud crawler trail rider April 16th 2014, 11:43 pm | |
| little update. got the tranny out, locked and back in. went riding, forgot the memory card and phone was dead double so just some pics and mods for now Trans beef just cause its awesome Unlocked Locked Done and in place, its the only clean part Close up on my mod to get more clutch tension with the stock spring, works great! | |
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5463 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: 70's Wheel horse C-120 mud crawler trail rider August 17th 2014, 11:20 am | |
| update, its been a long time since I did much with the old girl, Seems I didnt add the pics of the ride after I fixed the tranny, Ill post those below. I bought a set of tires this winter, super swamper vampires, size 25x13.5x9 I like to find big tires with small rims, they ride sooooo much softer than regular 12 inch garden tractor rims and this is why. The only way that you absorb bumps on a lawn mower are the seat springs and the rear tires. the smaller the rim, (keeping the same size tire) the more rubber/air you put between your back and the ground. which gets more important as you get older Lol. when I was younger I wouldnt even run seat springs because I felt more in control when I wasnt bouncing around. My back would hurt for a couple hours and I was good, now if I would run one of my old tractors like that I would have trouble walking the next day Lol. How ever the only problem was no matter how hard I searched, I couldnt find any 9 inch rims with the five lug bolt pattern I needed. So the other day I was at the atv junkyard and found a set of old steel 9 inch atv wheels with 4 lug pattern. Ended up only paying 5 bucks a piece for em ! score! in this pic one wheel is almost done, and the other just has the holes welded up So at this point I took my welder and welded up the old holes. Then I machined out a ring that centered up a old hub I had in the atv rims. dropped it in and drilled out All done! err almost I need to drill them out to the right size, but thats easy, I just ran out of time Next is removing the vamps from the old rims and putting them on the new ones, I think these tires are gonna hit the fender supports on my horse, so might have to deal with that also. | |
MoMower Member
offroadking Member
offroadking Member
| Subject: Re: 70's Wheel horse C-120 mud crawler trail rider August 20th 2014, 10:27 pm | |
| Those tires are sweet! but i would love to join your "club" if you would let me im an pretty experencied offroader and i would love to do what you guys are doing seems great and fun! | |
offroadking Member
Age : 23 Join date : 2014-01-22 Points : 4333 Posts : 546 Location : north carolina
| Subject: Re: 70's Wheel horse C-120 mud crawler trail rider August 21st 2014, 10:41 am | |
| Ebay, just type in kenda xtra grip and they will come up. the best place to get them is GCT wholesale, Ebay store is called gregthree. He is on vacation now, but I just got mine for 79 dollars for two, which is way cheaper than anywhere else I found. Shipping was around 20 bucks | |
donaldcon Member
Age : 37 Join date : 2015-04-28 Points : 3717 Posts : 395 Location : Roseville, OH
RuggBateman New Member
Join date : 2013-05-20 Points : 3978 Posts : 9 Location : Concord NH
| Subject: Re: 70's Wheel horse C-120 mud crawler trail rider July 29th 2015, 11:28 pm | |
| Those front tires!!! i'm on the search for those now, thanks for posting the name of them. watched the trailer vid too, your Tractor is insane bad ass little trail rig, your buddy has a good crawler too! now i just need to kick myself in the arse and start building mine... | |
donaldcon Member
