 Keep busting trans
Fattypipemuarry
PostSubject: Keep busting trans    Sun Jul 07, 2013 3:02 pm
I have busted two different transaxle this weekend. One was I Foote an one was a tecumseh. I was running the same pully ratio an same tires on both with a 12hp Briggs, neither one was locked. What could be causing this?
crazykid1994
PostSubject: Re: Keep busting trans    Sun Jul 07, 2013 3:06 pm
did the case shatter? could just be stress on them from riding
Forum Rep : 11
PostSubject: Re: Keep busting trans    Sun Jul 07, 2013 3:18 pm
Where/how are they breaking?
If it's the case itself that keeps cracking, you need to examine the stresses upon it. Could be that frame flex is getting the best of it?
Fattypipemuarry
PostSubject: Re: Keep busting trans    Sun Jul 07, 2013 11:47 pm
The muarry broke 4th gear an shot it throw the housing, the Foote shot the spiders out an the shifter twisted off.
crazykid1994
PostSubject: Re: Keep busting trans    Mon Jul 08, 2013 7:59 am
did the murray have enough oil or grease in it? it could have been stress or it seized and broke. how big are your tires? and same with the foote
Maine Mud Mower
Forum Rep : 2
PostSubject: Re: Keep busting trans    Mon Jul 08, 2013 9:48 am
Agreed on chase flex I get the same comments about breaking tranies on my youtube channel then they send me a walk around video and they have no bracing in their chase
http://www.Mudmower.com
Fattypipemuarry
PostSubject: Re: Keep busting trans    Mon Jul 08, 2013 10:26 am
My tires are 20/11/8 tractor tires. I'm running a 4 inch front and a 5 on trans. I don't think it's frame flex
crazykid1994
PostSubject: Re: Keep busting trans    Mon Jul 08, 2013 12:02 pm
i havent snapped a tranny yet. i beat up a hydro and the frame has no bracing. it flexes. its all on where the stress is on the frame. bouncing can twist the ranny if its not mounted properly or yes braced right to keep it from twisting. most transmissions have a forward and rear mount to help it from twisting
Forum Rep : 32
PostSubject: Re: Keep busting trans    Mon Jul 08, 2013 3:19 pm
I would sy its flex. I would check your mounts to make sure they are all tight. Yes, the two arms that grab the front of the case on each side are required to be there.
2018 Build Off Entry Commissionaire - Have a question? Ask me! Type in "@Doug" in your post!
Fattypipemuarry
PostSubject: Re: Keep busting trans    Mon Jul 08, 2013 3:24 pm
Both arms are on the front an all bolts are tight. Do you think the gear could have been bad
crazykid1994
PostSubject: Re: Keep busting trans    Mon Jul 08, 2013 5:47 pm
i doubt the gear would go bad just like that. it might have seized or something inside caught. or a wobbly bushing caused issues? who knows. could be any one of those things
Keep busting trans
» 1st attempt at a MTD vari drive and 3 speed manual trans mutation
» manual trans-axle
» Trans axle issues again, please help!
» Trans Am trail in TN
