| | Foote/Dana 5 Speed Transaxle Problems. | |
Marines2621 Member
Age : 26 Join date : 2012-12-31 Points : 4367 Posts : 215 Location : Mountainburg, Arkansas
| Subject: Foote/Dana 5 Speed Transaxle Problems. July 8th 2013, 11:29 pm | |
| I locked this transaxle today and it acts Wierd. It runs with no problem but when it's in neutral it will not coast at all. I have took off the brake and nothing. If had it coast a little but it rough. What could cause these problems? Yes there is alot of greese in it. | |
| | | Guest Guest
| | | | Marines2621 Member
| | | | Guest Guest
| | | | Marines2621 Member
| Subject: Re: Foote/Dana 5 Speed Transaxle Problems. July 9th 2013, 12:08 am | |
| I didn't change the grease. But when I put vise on the axles and use force to spin it. It makes a noise. Kinda like the brake draging. But the brake was off. I think something it binding | |
| | | MowBandit Member
Age : 28 Join date : 2013-03-16 Points : 4533 Posts : 477 Location : Haddock,Georgia
| Subject: Re: Foote/Dana 5 Speed Transaxle Problems. July 9th 2013, 12:46 am | |
| sounds like you got slag from welding in one of your gears or on your axle take the top case off spin the axle and see if it lifts up anywhere | |
| | | Marines2621 Member
| | | | Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5485 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: Foote/Dana 5 Speed Transaxle Problems. July 9th 2013, 8:42 am | |
| If it wasn't welded perfectly straight, the axle will bind, after being installed and bolts tightened.
Or one of the tab's on the bushing's is out of place. | |
| | | Marines2621 Member
| Subject: Re: Foote/Dana 5 Speed Transaxle Problems. July 9th 2013, 9:32 pm | |
| Well I found out the ball for the shifter and spring fell in the case which made it bind up. I took and cleaned the gears put it back in put the tabs in right and she is so smooth now. Just perfect. Thanks for the ideas! | |
| Who is online? | In total there are 19 users online :: 0 Registered, 0 Hidden and 19 Guests
