| | 97 Craftsman | |
dirtybird Member
Age : 44 Join date : 2011-09-30 Points : 4607 Posts : 26 Location : Nova Scotia
| | | | craftsman30mph Member
Age : 31 Join date : 2011-08-23 Points : 4791 Posts : 127 Location : branch MI
| | | | Jamus Established Member
Age : 44 Join date : 2010-06-28 Points : 5568 Posts : 511 Location : Southern WV
| Subject: Re: 97 Craftsman September 30th 2011, 8:36 pm | |
| It might depend on your engine but you should still have plenty of torque. I run 5" engine and 5" pulley with a 16.5 OHV and it put me on my back in 2nd gear when I let he clutch out too fast. | |
Age : 53 Join date : 2010-02-10 Points : 6838 Posts : 1726 Location : Florida, USA
| Subject: Re: 97 Craftsman September 30th 2011, 9:18 pm | |
| I had my 94 murray as a speed mod - i ran a 18.5HP opposed twin briggs, 6" motor pulley and a 3" trans pulley on the stock 6 speed shift on the fly tranny.
Using a hand throttle ( which i didnt like) - ill say it took a few seconds to 'catch up' - when it did, it was almost too fast to hang on in near stock form. I had it up in 3rd gear around 1/2 throttle, and nearly crashed it - guessing at MPH- faster then my street's posted 30mph speed limit.....
Any smaller then 3", youll slip and burn belts off - isnt enough belt wrap with that small a pulley .
Also keep in mind, the faster it goes, harder it is to control, specially with an unlocked front axle and stock steering .
On my offorad/trail agway i put a 4" motor and a 8" trans pulley on it, not wanting suicide speeds, just slightly faster then the stock 3 speed 'granny gears' ( which i havent tested yet- its still under construction).
Addicitive? Slightly - have 27 tractors, most mow, some are under construction and have like 6 mod tractors in progress ( of various uses). | |
| | | dirtybird Member
| Subject: Re: 97 Craftsman October 1st 2011, 12:38 am | |
| getting so much fantastic info off this site... I think I might just go to a 5" or 4" pulley and keep the stock one on front..
I have 2 quads and a street bike that hardly get used due to my new obsession with taking this tractor offroad!.. AND CHICKS ACTUALLY DIG THIS LAWN MOWER OFF ROADING!.. lol..
| Subject: Re: 97 Craftsman October 1st 2011, 12:42 am | |
| - dirtybird wrote:
- getting so much fantastic info off this site... I think I might just go to a 5" or 4" pulley and keep the stock one on front..
LMAO she thinks my tractors sexy haha can't wait to get mine done!!, have you seen mine yet? | |
| Subject: Re: 97 Craftsman October 1st 2011, 7:47 am | |
| When i was younger the spoiled kid around the corner had an ATC - i always wanted one but couldnt afford it - now im like " Argh- coulda modded a tractor" - never actually crossed my mind to.
The few ive put together havent cost a whole lot, BUT its still cheeper then going out and buying a new ATV - and its something different then the norm. Since i started getting more tractors , id take em down stock into the swamp behind my folks house - i couldnt believe what they could actually go thru and over totally stock.
I want to get phase one of the agway done, so i can see how it rates next to my nephews yamaha 4x4 ATV - phase 2 will be a trans up front for 4x4 mod - using a similar setup to a noma rear steer tractor - sometime in the future id like to build a monster 4x4 tractor from my 90's GT6000 , using all rear tires on it. | |
| | | redneckcarrow Member
Age : 54 Join date : 2010-12-22 Points : 4886 Posts : 30 Location : maine
| Subject: Re: 97 Craftsman October 1st 2011, 10:16 pm | |
| have a guestion why does everyone change the rear pulley and not the engine pulley seems like most are runninig 1 to 1 ratio somy thought would be go bigger on the engine pulley would think that would give you lot more surfice area for the belt to grab
just thinking out loud | |
| Subject: Re: 97 Craftsman October 1st 2011, 10:18 pm | |
| - redneckcarrow wrote:
- have a guestion why does everyone change the rear pulley and not the engine pulley seems like most are runninig 1 to 1 ratio somy thought would be go bigger on the engine pulley would think that would give you lot more surfice area for the belt to grab
just thinking out loud definately a good point, I did change my motor pully but it just wasn't enough speed for me idk bout others | |
| Subject: Re: 97 Craftsman October 1st 2011, 11:13 pm | |
| Every mower will be different, I changed both. Mine came with 3" motor and huge(12"?)trans. Some mowers will have a smaller trans pulley, like the MTD's have a 5". On the other hand, the hydro murray has a 5" motor pulley, which is what I'm using. | |
| | | dirtybird Member
| Subject: Re: 97 Craftsman October 2nd 2011, 11:47 am | |
| mine has the stock 9" on the rear, very good point, I'm changing the trans pulley just cause it seems way easier to get at to change...
I was rock crawling mine yesterday and flipped it over, and did I ever beat myself up!!! I need to lose some tourque, tractor is fine, but I'm hurtin today, those bear claw tires will dig & dig untill it flips backwards, but I still have a huge smile on my face, I LOVE OFF ROAD TRACTORS.LOL | |
| Subject: Re: 97 Craftsman October 2nd 2011, 3:50 pm | |
| Has some math to it ( dont ask me) , but has to do with revolutions of the motor vs the trans and ratios - large motor pulley with RPM range means itll go alot faster , too big tho and it lugs the motor down tho.
Stock tractors use the smaller engine pulley for more power, because its driving both the deck and trans - motor needs to turn faster - the large trans pulley slows it down , with the set gear ratios in the trans - putting a smaller pulley on the trans speeds the ratios up .
Its similar if the tractor comes with small tires, if you put large tires on it, it actually will make it faster, because they cover more ground then the smaller tires - that also changes the ratios.
Sort of like in a car- if it came with 15" wheels, you put 20" wheels on it- thats a 5" difference - that screws up your speedometer and also affects how the car drives - because of the set ratios in the trans and differential - sorta like lil toyota trucks with 44" mud hawgs on em and the stock differentials- things cant get out of their own way.
Depends what youre after, either speed or power - for speed : large front pulley ( id go no larger then 8" - lugs down the motor too much- my 6" has some delay with a twin cylender) and no smaller then 3" ( belt issues) on the trans.
Power : 1:1 - or a bit smaller/larger then stock - front could be an inch or two bigger, the rear a few inches smaller then stock .
Sometimes you just need to experement with different pulleys to get the right combo..... | |
| | | Ford Boi Member
Age : 39 Join date : 2010-08-22 Points : 5230 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
| Subject: Re: 97 Craftsman October 3rd 2011, 10:58 pm | |
| That is a sweet tractor man. You need a lift and bigger front tires tho lol... Love the bear claws. On my Rally I have a stock front with about 4" rear pulley and she still crawls in the low gears, but putts alog pretty good in 4th and 5th with enough rip to whip donuts running a stock 12HP Briggs and my 25x13" tires lol | |
| | | | | 97 Craftsman | |
| Who is online? | In total there are 29 users online :: 0 Registered, 0 Hidden and 29 Guests
