| what thing should be done | |
+5Jerbear0612 TheRainbowBoxer crazykid1994 Stretch44875 tman9114100 9 posters |
tman9114100 Member
Join date : 2013-03-17 Points : 4103 Posts : 45 Location : LaCrosse, WI
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5464 Posts : 959 Location : Mansfield, Ohio
tman9114100 Member
| Subject: thanks August 23rd 2013, 9:06 am | |
| i already have one, i was just wondering if there was anything that i dcould do to help it perform offroad
Age : 29 Join date : 2013-03-18 Points : 4688 Posts : 618 Location : loxahatchee, florida
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5462 Posts : 1089 Location : Galion, OH
Jerbear0612 Member
Age : 27 Join date : 2013-04-23 Points : 4106 Posts : 89 Location : Salem ct
| Subject: Re: what thing should be done August 23rd 2013, 11:44 am | |
| like mentioned above, pulley swap, better tires, lock the rear end. Id say gas pedal and some skid plates couldn't hurt either | |
k2500life Veteran Member
Age : 26 Join date : 2013-06-19 Points : 5134 Posts : 1135 Location : Southern Florida
Age : 27 Join date : 2013-03-18 Points : 7246 Posts : 3131 Location : raleigh nc
Murray modder Member
Join date : 2012-11-23 Points : 4564 Posts : 356 Location : Somewher in Va
| Subject: Re: what thing should be done August 23rd 2013, 7:16 pm | |
- Lock, aggressive tires, gas petal, bypass the safety sensors.
This guys knows it! | |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 29 Join date : 2010-05-12 Points : 6139 Posts : 899 Location : PA pittsburgh and pymatuning
| Subject: Re: what thing should be done August 23rd 2013, 7:32 pm | |
| honestly single best mod would be put some quad tires on the back and larger front tires, then a pulley swap, and then lock the rear axle, but is not needed ive conquered many holes without one, gas pedals and stacks wont help you perform better, just makes it cooler and although the gas pedal is nice to have | |
redzz02 Site VIP
| Subject: Re: what thing should be done August 23rd 2013, 8:35 pm | |
| - redzz02 wrote:
- honestly single best mod would be put some quad tires on the back and larger front tires, then a pulley swap, and then lock the rear axle, but is not needed ive conquered many holes without one, gas pedals and stacks wont help you perform better, just makes it cooler and although the gas pedal is nice to have
Actually the stack helps because mine likes to bog out when my pipe goes under but I'm in Florida with like 4 ft of water in one of my trails so depends if you have water or not | |
redzz02 Site VIP
| Subject: Re: what thing should be done August 23rd 2013, 9:28 pm | |
| My stuff runs good and as long as you keep the tons a little she doesn't big down, but yes stacks are good for when your continuously in deep water but also makes you sick with the exhaust blowing in your face for too long | |
redzz02 Site VIP
