 67' Ford lgt 100 build
5 posters
Kaptain Krunch
67' Ford lgt 100 build Empty
PostSubject: 67' Ford lgt 100 build   67' Ford lgt 100 build Icon_minitimeSeptember 6th 2013, 10:38 am
Whatsup everyone, new to the forum, not so new to fabrication, off road mowers, and such. A few years back, i built a 73' wheel horse, dubbed the red rocket. Now i've decided i need a second for friends to ride.
SO, i found a 1966 or 67 ford lgt 100, for $50 with no motor, four mismatched tires, and no steering linkage. It has a 5 speed transmission (granny low, 1,2,3,R), which is solid cast iron, with 1" axle shafts, and roller/ball bearings all around. I put in a short days work last week, and made some steering linkage from snowmobile tie rods and scrap steel, mounted some 25x8x12 atv tires, and also mounted an 8hp tecumseh for the time being. Yesterday i made a little more progress.
She runs goes and stops
8hp Tecumseh
hooked up gas pedal
custom made tensioner
Hood is painted
Diff is welded
Overall pretty good, the belt slips in higher gear, may need to re-angle my spring for better tension. The transmission is solid, with the exception of one gear which is pitted from rust, where it didnt sit in oil. This transmission is extremely rugged, it has removeable axle housings, with roller bearings to support the carrier/axle, and roller bearings to support the axle at the hub. The granny gear first is EXTREMELY slow, which is awesome, should be great for crawling. Should be picking up a 16hp v-twin this weekend which will be the new power plant if i can make it fit. Next top priority is to address the clutch, clean and paint the seat pan/fenders and make a seat for it, and weld the front axle so it doesnt pivot.
67' Ford lgt 100 build Photo1-1
Tensioner setup, hard to tell but both pulleys actually pivot, on the same fixed plate. 67' Ford lgt 100 build Photo2-1
Custom steering arm, snowmobile tie rods, steers pretty nice.
67' Ford lgt 100 build Photo3-2
Transmission, gear looks worse than it actually is. This thing is HEAVY.
67' Ford lgt 100 build Photo5-167' Ford lgt 100 build Photo167' Ford lgt 100 build Photo267' Ford lgt 100 build Photo3-167' Ford lgt 100 build Photo4
Diff locker done the right way!
Red Rocket Specs:
Locked diff
25" atv tires in rear, snowblower tires up front
18hp kohler opposed twin
welded front axle pivot
pulley swap (does about 25, with governor)
gas pedal
brake upgrade (new lining, removed spring from linkage)
Hood latches from a snowmobile
Diamond plate dash, custom
Had duel stacks in video, now it has a glass pack with a downpipe
Headlights
Suzuki samurai alternator
www.youtube.com/watch?v=kMdE7pd0oqQ
Here are the most recent pics i have of her
67' Ford lgt 100 build P411064067' Ford lgt 100 build P4110639
PostSubject: Re: 67' Ford lgt 100 build   67' Ford lgt 100 build Icon_minitimeSeptember 6th 2013, 11:15 am
Those look like some nice solid platforms. Should make some good rugged crawlers.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
matt-man
matt-man
PostSubject: Re: 67' Ford lgt 100 build   67' Ford lgt 100 build Icon_minitimeSeptember 6th 2013, 5:41 pm
Might want to put some kind of shield's around the belt in case it breaks you don't want your leg all cut up
PostSubject: Re: 67' Ford lgt 100 build   67' Ford lgt 100 build Icon_minitimeSeptember 6th 2013, 5:52 pm
Wow, that's one LARGE engine pulley!
PostSubject: Re: 67' Ford lgt 100 build   67' Ford lgt 100 build Icon_minitimeSeptember 6th 2013, 6:15 pm
I really like both tractors, and Ive always wanted to build a tractor that had that old tranny like your ford has, one question though, why weld the axles? just for stability at high speeds?
Kaptain Krunch
PostSubject: Re: 67' Ford lgt 100 build   67' Ford lgt 100 build Icon_minitimeSeptember 7th 2013, 9:26 am
-matt
Belt guards are definitely in order, i have the stock ones from both tractors, but they don't fit anymore as i changed the pulleys too drastically. For now i wear jeans haha.
=Stretch
i believe its a 9" on the engine, and 6" on the transmission for the red rocket.
-creepy
Thats basically the only reason i weld up the front axles, it gets pretty tippy at 20 if you don't. Not really ideal for crawling, but its a tradeoff. I'm considering putting in some small coil overs, so it can flex if it needs too, just not when i'm cornering at speed. Not sure how well that would work though.
» Ford lgt 100 build
» Ford 120 restoration build
» CC's Ford YT16 Trail Mower Build
» Ford LT 110 Off-Road Build
» 1969 Ford Thunderbird build
