| Monster Mud mower | |
+6DICE464 Ford Boi Trcustoms dangeroustoys56 Chunk redzz02 10 posters |
Trcustoms Member
| Subject: Re: Monster Mud mower September 29th 2010, 9:55 am | |
| Awesome, isn't the exhaust going to blow in your face though? The camo paint will be cool. What size angle steel did you use and what gauge? | |
Ford Boi Member
Age : 39 Join date : 2010-08-22 Points : 5230 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
| Subject: Re: Monster Mud mower September 29th 2010, 4:53 pm | |
| How do you have the engine and exhaust setup up in there? Btw looks dinky with the stock tires can't wait to see the big tires!! | |
Age : 53 Join date : 2010-02-10 Points : 6838 Posts : 1726 Location : Florida, USA
| Subject: Re: Monster Mud mower September 29th 2010, 6:04 pm | |
| Looks pretty cool- imagine a set of 5 bolt rear tires off a craftsman GT on it.... | |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 29 Join date : 2010-05-12 Points : 6138 Posts : 899 Location : PA pittsburgh and pymatuning
| Subject: Re: Monster Mud mower September 29th 2010, 6:11 pm | |
| 1. im putting a flapper on it so it will help a little from it hitting me in the face 2. its 1/8th inch thick and how ever wide a regular craftsman front axle is and CHUNK lol i thought it sprayed camo out awhile ago but then realized its just used for camo but heres some pics of the paint not done yet tell me what you think and im dieing to put the bigger tires on it looks so dinky and stupid with these tires on it | |
Guest Guest
Ford Boi Member
| Subject: Re: Monster Mud mower September 29th 2010, 8:43 pm | |
| LOVING THE PAINT DUDE!!!!! Totally military look. That's gotta be one of the toughest looking paintjobs I've seen. | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower September 30th 2010, 5:55 pm | |
| k guys heres how im doing the rearend first i took two old big pulleys and cut out the centers, then i slid the centers onto a 5/8 shaft and welded all around this will act as a cupling for the input shaft and 5/8 shaft extension then i got a jackshaft bearing or you could use a pillowblock bearing i welded the bearing mount to a solid brace to keep the shaft from moving back and forth, this suports the shaft and will keep it from ripping out your input shaft this is it all together you just add keys, set screws and a pulley on top with a little snap ring grove to hold it all on and heres some pics in the light still needs more work paint, welding, and still doesnt move | |
Trcustoms Member
Join date : 2010-09-19 Points : 5171 Posts : 225 Location : Bear,De USA
| Subject: Re: Monster Mud mower September 30th 2010, 10:37 pm | |
| And all the stock steering linkages still work fine? | |
Trcustoms Member
| Subject: Re: Monster Mud mower September 30th 2010, 10:40 pm | |
| I was looking at your pics again and i spotted a yellow vintage briggs. What model and year? Go to the engine tech section and check out a vid of my 1949 5s if you have the time. | |
Ford Boi Member
| Subject: Re: Monster Mud mower October 1st 2010, 12:24 am | |
| That beast is looking awesome, like the shaft idea, but I have 2 concerns. 1: keeping those set screws tight and 2: that mild steel rod as a shaft. I can't say for sure but I think an old axle would probly be stronger? Hope your setup works tho. You've definitely put alot of work into it and I hope it works well! I have thought about a setup like that, but I was thinking about using a small U-joint (from a steering shaft of a car) in there somewhere to keep it turning smooth. Just throwin out some Ideas don't hate lol. I'm going to have to start building a monster as well, I will accept any and all criticism from you gratefully lol !
Ford Boi Member
| Subject: Re: Monster Mud mower October 1st 2010, 12:30 am | |
| - Trcustoms wrote:
- I was looking at your pics again and i spotted a yellow vintage briggs.
What model and year? Go to the engine tech section and check out a vid of my 1949 5s if you have the time. I've got a very good running 1966 2 1/4 HP Briggs horizontal shaft! out of a power trowel made by Master Vibrator LOL , got the motor for free, put n a pedal bike. I'll post up pics when I find 'em ! | |
| Subject: Re: Monster Mud mower October 1st 2010, 6:55 am | |
| Is it me ( or the angle of the picture) or does that shaft to the trans look like its at a slight angle?
Looks cool tho - id put a tack weld on that adapter collar as well.
Ford Boi: My oldest motor is a 70 verticle shaft 5HP ( still runs- its on my toro tractor) - i have a 69 8HP - but it was in pieces when i got it- never seen it run.
Trcustoms Member
| Subject: Re: Monster Mud mower October 1st 2010, 9:20 am | |
| - Ford Boi wrote:
What model and year? Go to the engine tech section and check out a vid of my 1949 5s if you have the time. I've got a very good running 1966 2 1/4 HP Briggs horizontal shaft! out of a power trowel made by Master Vibrator LOL , got the motor for free, put n a pedal bike. I'll post up pics when I find 'em ! Sweet, i'd love to see a pic. | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower October 1st 2010, 11:17 am | |
| i wanted to do the u joint but they were like 30 bucks cheapest i could find and its a gokart jackshaft so it should be fine , i noticed that it looked on an angle too but its just the picture and that little yellow moter is one of the many i have i got a selection of parts and 14 motors for free from my dads friend all containing 2 brigss 6s and 2 brigss 52, a couple little reo real motors, a big ass wisconsin motor, and some 7hp and 8hp briggs all side shafts hopefully i will get it to move this weekend and finish it up and test it so i will take some pictures | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower October 3rd 2010, 4:08 pm | |
| didnt get much done this weekend it sucked up my camp it rained all saturday, and i broke my black monster mower. i went down into a deep pit and got stuck my Jamie was pulling me out and i heard a big clunk noise and the chain popped but i soon discovered the mass torque of the opposed twin twisted and broke the angle i had mounting the tranny the pics arent so great it was raining and getting dark the first picture shows it all on and angle and not square to the frame second one is the front angle piece snapped me and jamie mudding didnt get pics really but its something me on big black one jamie on his my 25 halfway burried, had to use winch i was by my self then there was my new monster mower next to my other one with tires on it at this moment because of flats and starting to rain it has not one of the same tire on it lol hope you like | |
| Subject: Re: Monster Mud mower October 3rd 2010, 6:57 pm | |
| Cool pics- whats with the upside down gear shift lever on the black one? Lil hard to shift....
redzz02 Site VIP
| Subject: Re: Monster Mud mower October 3rd 2010, 7:05 pm | |
| havent gotton around to making one that comes up through the frame and i just have to reach down far inbetween the belt to shift | |
Trcustoms Member
| Subject: Re: Monster Mud mower October 3rd 2010, 7:26 pm | |
| WoW, i would have never thought that would break like that. | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower October 3rd 2010, 7:31 pm | |
| its because it was old angle out of the ground and both pieces had a couple sets of holes i then and the one had a piec cut out of it for the chain when i had the tranny mounted a different way
redzz02 Site VIP
| Subject: Re: Monster Mud mower October 12th 2010, 5:07 pm | |
| sorry guys havent got much done this past weekend i spent most of my time playing in the mud with my other monstermower and broke it again, but i did change out the flywheel and starter and it runs great. the last flywheel had a stupid plastic gear on it and half the teath were stripped. but anyways dangeroustoys56 was right about the shaft being on a slant and i just didnt want to say anything because i was in a hurry and screwed up. i made one of the tranny drop downs an inch shorter than the other one so, i have another frame laying around with the dash i need already on it so this winter i am going to start rebuilding this mower and build it right this time, but i am not sure what tranny to use. i have a sumwhat good 6 spd thats in it now but the axle shafts are loose and move around. i also have a 4spd wich i think is weeker but it is pretty much 100% sealed so no mud or water will get in it. or my final choice is to put out about 75$ rims and tires to fit on it and buy a peerless 820 with the one inch shafts wich are pretty Much bullet proof for mowers i hear so let me know what you think i should do | |
Trcustoms Member
| Subject: Re: Monster Mud mower October 12th 2010, 5:14 pm | |
| - redzz02 wrote:
- sorry guys havent got much done this past weekend i spent most of my time playing in the mud with my other monstermower and broke it again, but i did change out the flywheel and starter and it runs great. the last flywheel had a stupid plastic gear on it and half the teath were stripped. but anyways dangeroustoys56 was right about the shaft being on a slant and i just didnt want to say anything because i was in a hurry and screwed up. i made one of the tranny drop downs an inch shorter than the other one so, i have another frame laying around with the dash i need already on it so this winter i am going to start rebuilding this mower and build it right this time, but i am not sure what tranny to use. i have a sumwhat good 6 spd thats in it now but the axle shafts are loose and move around. i also have a 4spd wich i think is weeker but it is pretty much 100% sealed so no mud or water will get in it. or my final choice is to put out about 75$ rims and tires to fit on it and buy a peerless 820 with the one inch shafts wich are pretty Much bullet proof for mowers i hear so let me know what you think i should do
The 820 has a 1" shaft? Awesome, i'll look for one of them then. | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower October 12th 2010, 6:15 pm | |
| yea they have 1inch axles 3/4 inch imput and everything inside it has bearings on them so vertualy they are the 2.5 ton rock well axles in the offroading truck world | |
DICE464 Member
Age : 27 Join date : 2010-07-30 Points : 5123 Posts : 129
redzz02 Site VIP
| Subject: Re: Monster Mud mower October 14th 2010, 7:29 pm | |
| i will try and get a video this weekend but im redoing it so itll be driving next spring
Chunk Established Member
Age : 32 Join date : 2010-02-10 Points : 5982 Posts : 779 Location : Angus, Scotland
| Subject: Re: Monster Mud mower October 17th 2010, 7:10 am | |
| Im still trying to hunt down a 820, hard to get hold of apparently, | |
redzz02 Site VIP
