| yamahurry! | |
+5T-Dub13 Lawren Wimberly Doug k2500life partin_us_99 9 posters |
partin_us_99 Member
| Subject: Re: yamahurry! March 9th 2014, 2:39 pm | |
| ok. But do u know how several ppl have dropped their seats in between the fenders? Looks slick im just trying to figure out how its done and how I should begin doing it. | |
Age : 57 Join date : 2013-12-21 Points : 4589 Posts : 744 Location : Salem Illinois
| Subject: Re: yamahurry! March 9th 2014, 3:02 pm | |
| Generally, the dropped seat requires the sprocket to be outside the seat well, between the tire and the inner fender. A brake disc or band brake drum goes in the other fender well.
in essence, you are just moving the sprockets and such out from under your seat. | |
partin_us_99 Member
Age : 36 Join date : 2013-10-28 Points : 3996 Posts : 144 Location : muncie IN
| Subject: Re: yamahurry! March 9th 2014, 3:03 pm | |
| so basically turning a vertical shaft engine to a side shaft engine setup? | |
| Subject: Re: yamahurry! March 9th 2014, 3:49 pm | |
| that is the easiest way, but by FAR not the only way. Like I said, the motor choice dictates the trans choice.. and so on
partin_us_99 Member
| Subject: Re: yamahurry! March 9th 2014, 3:56 pm | |
| well im definitely wanting the look of the seat recessed into the fenders and I'll most likely go live axle in the rear but yea I guess I need to get my driveline figured out before the asthetics of it. | |
| Subject: Re: yamahurry! March 9th 2014, 4:04 pm | |
| even with the stock set up, there is a good deal of room to lower things... Look at the set up, and figure how much you can cut out. The MTD I took apart to build the fox had almost 12 inches I coulda dropped the seat. Kinda hard to see over the hood when you get TOO low though
partin_us_99 Member
| Subject: Re: yamahurry! March 9th 2014, 9:10 pm | |
| sooooo im in pickle. I've got a fella with a kz650 bike but its just a roller its got engine trans no carbs and 130 psi compression (so he says) wants 100 bucks but is willing to trade me for my old iphone 4 OR do I trade my vintage sears ss16 tractor project for a good engine for the yamahurry? | |
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5545 Posts : 1408 Location : Galway NY
| Subject: Re: yamahurry! March 9th 2014, 9:28 pm | |
| trade the iphone. noone wants an apple product anyway | |
partin_us_99 Member
| Subject: Re: yamahurry! March 9th 2014, 10:35 pm | |
| lol well here they're like crack haha. But I'm a little worried by taking ones word that it might run AFTER I buy 200 bucks worth of carbs etc. I'd honestly like to find something I can hear run ya know? | |
| Subject: Re: yamahurry! March 9th 2014, 11:08 pm | |
| i dont care what ya do, just do NOT can the sears.. those things are too precious | |
partin_us_99 Member
| Subject: Re: yamahurry! March 9th 2014, 11:14 pm | |
| o im never gonna can it lol ill either trade it or keep it. Just hate dealing with the points and coil compared to the ignition system of a newer engine. | |
| Subject: Re: yamahurry! March 9th 2014, 11:15 pm | |
| you could probably convert it if you had some time to kill | |
mrkadage Member
Age : 34 Join date : 2014-01-12 Points : 3862 Posts : 103 Location : queensland, Australia
| Subject: Re: yamahurry! March 10th 2014, 5:42 am | |
| i wouldnt trade the sears. just ditch the iphone, they are worthless these days anyways. plus you can use any carbs you want if you can make a manifold | |
| Subject: Re: yamahurry! March 10th 2014, 8:56 am | |
| - mrkadage wrote:
- just ditch the iphone, they are worthless these days anyways.
worthless unless it has flappybird... LOL | |
partin_us_99 Member
| Subject: Re: yamahurry! March 10th 2014, 9:01 am | |
| lol stupid flappybird game. I have all the time in the world since my disability just gotta think how to convert a briggs ignition system on an onan. | |
mrkadage Member
| Subject: Re: yamahurry! March 10th 2014, 8:37 pm | |
| just use a briggs magnatron coil to match the horse power on the onan and it should work perfect... at least it does in theory haha | |
partin_us_99 Member
| Subject: Re: yamahurry! March 10th 2014, 10:21 pm | |
| well I'd have to add a magnet to the flywheel correct? | |
| Subject: Re: yamahurry! March 10th 2014, 11:27 pm | |
| I'm still tryin to figure out why you wanna ditch the points... you can fine tune ignition timing with a points set up... they aren't that hard to figure out | |
mrkadage Member
| Subject: Re: yamahurry! March 11th 2014, 4:51 am | |
| - Lawren Wimberly wrote:
- I'm still tryin to figure out why you wanna ditch the points... you can fine tune ignition timing with a points set up... they aren't that hard to figure out
I agree larwen, points are probably the simplest ignition system around. if you wanted to run the magnatron however, you would have to source a B&S flywheel as well and ensure the timing will all line up. honestly I'd go with lawren on this one and save yourself the headache | |
jeremynitro New Member
Age : 40 Join date : 2014-06-19 Points : 3605 Posts : 11 Location : IN, in the sticks
partin_us_99 Member
| Subject: Re: yamahurry! June 20th 2014, 8:20 am | |
| Prolly solid. But I might go swing arm never really thought bout goin swing arm | |
| yamahurry! | |
