GOLF CART AXLE Lend10PortalHomeFAQSearchMemberlistRegisterLog inDiscordCountdown TimerGOLF CART AXLE Rend10
 GOLF CART AXLE
tractor_guy
tractor_guy
GOLF CART AXLE Empty
PostSubject: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeMon Dec 02, 2013 8:31 pm
Just scored a golf cart rear axle. Anybody know anything about them? Looks as stout if not more then my transaxle with 1" shafts and the brakes on it are monstrous compared to tractor brakes. Only problem is it is just an axle and diff. No forward, neutral, reverse.
Any ideas? Lets brainstorm.
Forum Rep : 47
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeMon Dec 02, 2013 8:33 pm
Its just a straight axle with a diff. Use a sprocket to a torque converter off a horizontal. Some pillow blocks and done.
Forum Rep : 19
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeMon Dec 02, 2013 8:44 pm
Check the gear redux ratio. Could be 12:1 all the way down to 20:1. If it were me, I would examine using a 700 tranny with it. I foolishly got rid of one a few years ago thinking I was never going to use it. I'm still kicking myself...
GOLF CART AXLE Facebo12
tractor_guy
tractor_guy
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeMon Dec 02, 2013 8:51 pm
It looks like a transaxle. Its all in a housing. Including axleshafts. But instead of a pully on top it looks like a right angle gearbox and the input is out the front of that. Looks like a mini rockwell (deuce and a half army truck) axle.
I dont have any horizontal motors so I would eather have to go with docs 700 idea (though I dont have one of those eather) or turn the housing on its side and find a way to make that work.
GenevaCustoms
GenevaCustoms
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeMon Dec 02, 2013 9:00 pm
Turn the axle were the input is on top lol, but you'd only have a foward from the engine lol, no neutral or anything
tractor_guy
tractor_guy
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeMon Dec 02, 2013 9:27 pm
Im likin the peerless 700 idea so far. I have no experience with them though. Would they take an 18hp engine 23" super lugs and some hard beatin on it?
I was also thinkin I could use it for a mini jeep build I wanna do by turning it on its side like you said and usin a centrifugal clutch and doin a rear mounted engine.
tractor_guy
tractor_guy
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeMon Dec 02, 2013 9:47 pm
Posted a pic of one like mine with a lil info I found on it on my tractor builders facebook group. https://www.facebook.com/groups/165224337018366/
GenevaCustoms
GenevaCustoms
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeMon Dec 02, 2013 9:57 pm
With the 700 u need a straight axle so the only stress on itself is wear the chain will stress the output shaft from the torque of the big tires, but other then that it doesn't have stress on like the axle shafts as a normal mower tranny does so I don't see why it wouldn't be able to handle that lol maybe even 25s
Forum Rep : 19
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeTue Dec 03, 2013 6:20 am
I think the 700 is up to the task. Mount it solidly, race prep it, and away you go.
slim67
Forum Rep : 3
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeTue Dec 03, 2013 3:51 pm
Its probably out of an early EZGO, G-1 yamaha or maybe a Harley 3 wheel cart. All of those carts used 2 stroke engines that ran either direction negating the need for a direction lever inside the trans. In other words, if used with a 4 stroke you will not have reverse. they along with all golf cart transaxles are pretty tough.
GenevaCustoms
GenevaCustoms
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeTue Dec 03, 2013 4:18 pm
I have a early 90s ezgo gold cart with a toe cylinder 4 stroke, with the forward refers lever goin to the gear box thing lol, never reall looked at it
slim67
Forum Rep : 3
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeTue Dec 03, 2013 7:13 pm
They went to a geared transaxle in the later Marathons when EZGO started with the twin cylinder. Thats a great transaxle you have there.
GenevaCustoms
GenevaCustoms
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeTue Dec 03, 2013 7:42 pm
Well actuallyyy.... It's my grandpas golf art he uses all the time lol
slim67
Forum Rep : 3
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeTue Dec 03, 2013 8:10 pm
well you can forget about that one!
tractor_guy
tractor_guy
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeTue Dec 03, 2013 9:41 pm
I think its a cushman. Number on axle is 879981
slim67
Forum Rep : 3
PostSubject: Re: GOLF CART AXLE   GOLF CART AXLE Icon_minitimeWed Dec 04, 2013 4:58 am
if its out of a cushman, then it was probably an electric maintenance cart. not sure who their vendor was. cushman also made some durable stuff. im pretty sure taylor-dunn used a 8 or 9 inch ford rear. only adding that because i remember something being said about it looking like a rockwell.
GOLF CART AXLE
» 2010 S Rear Axle Problem
» Front Axle Pivot Or No Pivot On Lifted Tractor?
» axle shaft removal
» Lawn Flite Trail/mudder build
» Need help with 2008 700 Rhino CV Joints
