 How to: remove surface rusted transaxle/gearbox gears
How to: remove surface rusted transaxle/gearbox gears Empty
PostSubject: How to: remove surface rusted transaxle/gearbox gears   How to: remove surface rusted transaxle/gearbox gears Icon_minitimeJanuary 19th 2014, 11:27 pm
So on my junkyard 820 i needed to clean the axle, perform maintenance. The cassette gears were rusted on one half most of the time, maybe being in the air or grease for years. So i found a good method on how to remove this rust, you don't want this floating around in the tranny.
Things i used:
Corded drill
wire wheel
gloves
safty glasses
How to: remove surface rusted transaxle/gearbox gears 15460110
This is how i held it. i used towels fo the machined surface wasnt damaged. I used a papter towel becuse the wheel catches it sometimes, and just blows it apart vs getting wrapped up
How to: remove surface rusted transaxle/gearbox gears 15248710
Ew
How to: remove surface rusted transaxle/gearbox gears 99654110
It is slightly pitted, but i used a screwdriver and coildnt get any debris out of it. So id call it fairly close to good.
How to: remove surface rusted transaxle/gearbox gears 15266810
» How do I remove a stuck Transaxle Pulley?
» Remove a stuck transaxle pulley in less then 5 minutes
» transmission gears wrong
» Need Help Removing a Rusted on Rim And Carb Issues.
