| Rustey Medal | |
+17MowBandit Doc Sprocket WellThatsSurprising redlinemotorsportts Murray modder mudmonkey06 richie thomas xxXMowerdudeXxx Thunderdivine Marines2621 TheRainbowBoxer Doug Chopperhed AcreFarm dangeroustoys56 CornishMorgan truckin42 21 posters |
truckin42 Veteran Member
Age : 25 Join date : 2012-10-04 Points : 5266 Posts : 1070
| Subject: Rustey Medal January 13th 2013, 12:50 pm | |
Last edited by truckin42 on February 2nd 2013, 5:56 pm; edited 1 time in total | |
CornishMorgan Member
| Subject: Re: Rustey Medal January 13th 2013, 1:19 pm | |
| Nice mower, I like the front bumper. it suits the chassis | |
Age : 53 Join date : 2010-02-10 Points : 6839 Posts : 1726 Location : Florida, USA
| Subject: Re: Rustey Medal January 13th 2013, 3:25 pm | |
| Ditch the hydro trans - those are for mowing only - no good for offroading. | |
| Subject: Re: Rustey Medal January 13th 2013, 6:39 pm | |
| Ya thats futrue plans dont have the cash right now. | |
AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4699 Posts : 208 Location : Tennessee
| Subject: Re: Rustey Medal January 13th 2013, 7:58 pm | |
| The most important thing you can do until you upgrade the transaxle is make sure it stays clean & the fan is in good shape. Your K46 is known for heat-related problems, but most of those issues stem from grass & debris building up on top of the transaxle, effecting air flow/cooling. | |
Chopperhed Moderator
Age : 57 Join date : 2012-10-14 Points : 5017 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Rustey Medal January 13th 2013, 8:10 pm | |
| - AcreFarm wrote:
- The most important thing you can do until you upgrade the transaxle is make sure it stays clean & the fan is in good shape. Your K46 is known for heat-related problems, but most of those issues stem from grass & debris building up on top of the transaxle, effecting air flow/cooling.
Hydro systems need to be clean and air free internally, clean and free air externally. An aftermarket cooler/filter can be added if you have external ports/hoses. | |
| Subject: Re: Rustey Medal January 13th 2013, 8:17 pm | |
| It normally does great aslong as it an't coverd with dirt or anything. | |
| Subject: Re: Rustey Medal January 26th 2013, 6:01 pm | |
| Got alittle bit done today i got the head gasket fixed and the valve cover gaskets replaced and hoping it seals. | |
| Subject: Re: Rustey Medal February 2nd 2013, 6:05 pm | |
| Todays progress: Got a leakeg setup done so now it can be driven. It now has a hand shifter. I took these pics later on in the day. Tell me what you think. | |
| Subject: Re: Rustey Medal February 3rd 2013, 2:36 pm | |
| Heres a better pic of the linkage setup and the hand shifter | |
| Subject: Re: Rustey Medal February 6th 2013, 4:57 pm | |
| The new battery box. Tell me what ya think. | |
Doug Site Owner
Age : 28 Join date : 2012-12-24 Points : 7532 Posts : 3035 Location : Lebanon County, PA
| Subject: Re: Rustey Medal February 6th 2013, 5:54 pm | |
| Ok thanks,i will watch the battery for rubbing. | |
Doug Site Owner
| Subject: Re: Rustey Medal February 7th 2013, 12:23 am | |
| If you see it rubbing, just strap it down tighter and/ or get some foam/ rubber to create some insulation. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Rustey Medal February 8th 2013, 5:53 pm | |
| Heres what i got so far it a steering stifiner. I cut it at a 45* angle and then welded it. | |
| Subject: Re: Rustey Medal February 11th 2013, 1:17 pm | |
| Got the steering shaft stifner done. Almost ready for a test drive just need to weld on the steering wheel,and make a throttal. Tell me what you think. | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5462 Posts : 1089 Location : Galion, OH
| Subject: Re: Rustey Medal February 11th 2013, 1:38 pm | |
| Looks like you are making progress! Steering support looks like it will do the job. | |
| Subject: Re: Rustey Medal February 11th 2013, 5:40 pm | |
| Yeah i should. I got the steering wheel done and welded on. | |
Marines2621 Member
Age : 26 Join date : 2012-12-31 Points : 4346 Posts : 215 Location : Mountainburg, Arkansas
| Subject: Re: Rustey Medal February 11th 2013, 8:47 pm | |
| Real nice build im almost done on mine. | |
| Subject: Re: Rustey Medal February 12th 2013, 5:33 pm | |
| Thanks. Ill check out your build.
| Subject: Re: Rustey Medal February 17th 2013, 5:59 pm | |
| Well today i got the foot throttal done. Now its ready for a test drive. Tell me what ya think. | |
| Subject: Re: Rustey Medal February 18th 2013, 2:32 pm | |
| Its almost done. Mods done foot throttal steerring stifner new steering wheel front bumber custom drive leakage car battery foot pegs custome seat Future mods rear bumber pull start roll bar or roll cage stacks tire chains Heres it is tell me what ya think. | |
| Subject: Re: Rustey Medal March 12th 2013, 5:39 pm | |
| Well got some work done today im fabing up a new foot throttal. Heres what i got so far just need to weld it together. | |
| Rustey Medal | |
