| Richie's lifted 4x6 IH cub 782 GT "mini deuce" | |
+19mr.modified willis923 the craftsman mudder Doug B440 LAWN MOWER MUDDER Moose k2500life 1997 Murray mrkadage Lawren Wimberly dked41 Doc Sprocket redlinemotorsportts Thunderdivine TheRainbowBoxer TroyBilt Pony camomanusa richie thomas 23 posters |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6162 Posts : 1434 Location : east dublin georgia
| Subject: Richie's lifted 4x6 IH cub 782 GT "mini deuce" January 20th 2014, 8:04 pm | |
| well guys, ive been thinkin for a couple years to do a 4x6, and now ive decided to do it, im gathering parts now and should be ready to start buildin in febuary. my base mower is a IH cub cadet 782 GT, this mower is really heavy duty. the stock frame on the mower is 6 foot, front front wheel to back wheel is just under 6 ft, im adding either 3.5 ft or 4 ft to the frame, more than likely it will be 4 ft. this will stretch the frame out to 11 ft. from my measurements and guessing, from front wheel to rear wheel when im done is going to be ~9.5-10 ft. i plan on running at least 25" tall tires, but i am trying to find a set of 27x12x12 tires that are similar to my tres on dixie, if i can then im going to run 27" tires rear. the build is getting a 8" lift so that is giving me between 20.5"-23" ground clearance. im going to be running 2 posi locked mst-206's on this build. the front tires i have already, ther will be 24x8.5x12 in atv tires. the front end i plan on doing a leaf spring suspension. the motor for this build will be a 18.5 hp briggs opposed twin, im going to run a 1:1:1 ratio. now instead of doing like most people who have built 4x6's ad done a flat bed, im building a 42"wx60"Lx18"H bed for this bad boy. im also planning on a removeable roof and tinted plexiglass windshield. the bed is going to be framed out of 1" square tube and be covered in 16ga steel. its getting a small sound system, which will all be water proof.im also mounting my winch on this thing, this will be my ultimate mower, i plan on using this thing for mudding, trail-riding, yard-work, recovery/repair.
Last edited by richie thomas on January 21st 2014, 5:01 pm; edited 1 time in total | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4341 Posts : 467 Location : Greensburg, PA
Join date : 2013-06-01 Points : 4572 Posts : 578 Location : West Virginia
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5461 Posts : 1089 Location : Galion, OH
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" January 20th 2014, 8:47 pm | |
| - TheRainbowBoxer wrote:
- Like they say (whoever "They" are)... Go Big or Go Home!
me and jay were talking, if we were to go to haspin, we could put black widow in the bed of mini deuce, then drive mini deuce onto a trailor and go | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6305 Posts : 2101 Location : Norway, Europe
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" January 21st 2014, 3:01 pm | |
- I'm sure if this thing makes it out to Haspin, a deuce themed tractor will be a hit with the steel soldiers guys.
i bet it would to, but dayum thats a long way for me to go lol. it would be a few years before i would be able i think | |
Guest Guest
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" January 21st 2014, 5:17 pm | |
| u son of a gun stole my idea lol just mines close to what i wanna do but since i found an extra 2 gears on mine i figured to just stick with the same tranny for now lol good luck i know u have been talking about doing this build for some time now so now get to it lol
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" January 21st 2014, 6:06 pm | |
| gone be an expensive build, the metal for the lift is ~ $45 bucks, and then the parts in need for the drive line are another $40, im going to get the lift built and tested, then build the bed, the bed is going to take ~$120 | |
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" January 21st 2014, 6:08 pm | |
| - richie thomas wrote:
- gone be an expensive build, the metal for the lift is ~ $45 bucks, and then the parts in need for the drive line are another $40, im going to get the lift built and tested, then build the bed, the bed is going to take ~$120
Really wow, can't you borrow Redline's junkyard. | |
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" January 21st 2014, 6:16 pm | |
Really wow, can't you borrow Redline's junkyard. yea richie you can find your lift, axles, and rims for probably $60. lol | |
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" January 21st 2014, 6:23 pm | |
Really wow, can't you borrow Redline's junkyard. yea richie you can find your lift, axles, and rims for probably $60. lol i wish i could | |
Doc Sprocket Site VIP
Age : 50 Join date : 2013-04-21 Points : 7080 Posts : 2914 Location : Ontario Canada
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" January 21st 2014, 9:28 pm | |
| - Doc Sprocket wrote:
- This oughta be an interesting build! Mind you, at 10 feet long- your turning radius is probably gonna suck.
yea the turning radius is the only major downfall i see on this, but the trails at slopoke have people taking those little jap. trucks that are 4x4 on em so this will be fine | |
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" January 22nd 2014, 7:13 pm | |
| ok guys, im workin saturday to get some cash for metal, and them stickers, my question is this, can yall think of anything that would be functional and productive to add to this build? | |
dked41 Member
Age : 59 Join date : 2012-01-31 Points : 4570 Posts : 141 Location : central Wisconsin
Age : 57 Join date : 2013-12-21 Points : 4567 Posts : 744 Location : Salem Illinois
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" January 23rd 2014, 12:36 pm | |
| - dked41 wrote:
- You could add a wrecker boom and winch. If you want to preserve the bed space, you could add a mower size wheel lift under the bed.
and you could use the under bed wheel lift as a bumper in the "Up" position. With the on board air, you could actually make it pneumatic. | |
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" January 23rd 2014, 2:44 pm | |
| - Lawren Wimberly wrote:
and you could use the under bed wheel lift as a bumper in the "Up" position. With the on board air, you could actually make it pneumatic. i was thinkin of making something to use for towing purposed, but idk it the pneumatic would be strong enough | |
mrkadage Member
Age : 34 Join date : 2014-01-12 Points : 3840 Posts : 103 Location : queensland, Australia
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" January 23rd 2014, 8:51 pm | |
| - mrkadage wrote:
- what are you using for a floor richie? cause if you used diamond plate you could get rid of the 2nd and 4th X-member.
ima talk to my old shop teacher, he had someone donate a full 4'x8' sheet of 1/4" diamond plate last year ill see if i can get it, or buy it cause i would love diamond plate floor | |
