| Craftsman Lt2000 Project | |
+20Ariens YT11 jamcco ZSmachines mr.modified 98Murray Jerbear0612 Ozzy's Creations 1997 Murray CornShuck4CE countryboy12894 craftsmancole Angchor tanis Creepycrawler TheRainbowBoxer camomanusa LAWN MOWER MUDDER redlinemotorsportts richie thomas willis923 24 posters |
jamcco Member
| Subject: Re: Craftsman Lt2000 Project December 23rd 2014, 4:11 pm | |
| Today I worked on patching the Transaxle....I ran out of JB Weld half way through But I ended up cutting out a piece of tin to use as scaffolding. I then made some coil spacers for the front end.... like my history teacher says, pictures are worth 1000 words filed the hole down some the tin patch, I made it big enough so that the bolt can pass through it....holding it in place dont mind the crappy pic...but I ended up adding a 3/4" spacer....this gives me 1" of frame clearance now | |
ZSmachines Member
Age : 24 Join date : 2014-08-27 Points : 3754 Posts : 221 Location : PNW
jamcco Member
Age : 24 Join date : 2014-01-04 Points : 3978 Posts : 226 Location : New Hampshire
| Subject: Re: Craftsman Lt2000 Project December 23rd 2014, 6:29 pm | |
| The front end wont be very "springy". This is a droop style suspension that drops the wheels instead of having loads of uptravel. When I used to have a 4 link, the coilover style was very limiting. Now that I have coils, the suspension should be a little bit more cushiony. I may have a problem with big bumps though.....we'll have to see once I get the tractor back on all fours | |
jamcco Member
| Subject: Re: Craftsman Lt2000 Project December 24th 2014, 2:14 pm | |
| Fearlessfront & Fozzy locked.....aka FFF Locker JB WELD is done back on all 4's driving, and ready to flex the new front end..... | |
jamcco Member
| Subject: Re: Craftsman Lt2000 Project February 22nd 2015, 11:04 pm | |
| So it's almost been 2 months since I've done any real up dates.......so I will start out saying to as why haha. Well I messed up somewhere during reassembly of the mst206 cuz while driving it, the transaxle didnt want to spin. The input was tight, I didnt think anything of it. So when I was driving around the yard the transaxle locked up when I was in 5th gear. I as of right now the transaxle is stuck in 5th gear and I had to pull out the keys on my wheels in order to roll my tractor home due to the fact that the transaxle has ZERO movement.
I'm planning on diagnosing what the problem is tomorrow. I am hoping to get back to working on this thing. I want to add a couple more mods to it, and if I find the peerless is junk, then I will slap a *gulps* hydro into the thing until further notice.
I'm thinking about going full rock crawler with this thing, as good as 2 wheel drive crawlers go that is. I'm going to add a skidplate, rear bumper, sliders under the floor boards, FINISH THE SUSPENSION, rear bumper, nerf bars, and I think that is it as of now
Age : 27 Join date : 2012-10-31 Points : 4926 Posts : 745 Location : The Wyo-Braska Panhandle
jamcco Member
| Subject: Re: Craftsman Lt2000 Project April 1st 2015, 9:07 pm | |
| Pulled this thing out from behind the house today, man it needs work though........ I pulled the transaxle apart and failed to fix the issue so i need some help...... So I rebuilt my transaxle the other day and I have not been able to get it work right since then. I had put a hole threw the case but the internals are fine and I have since then JB welded the hole. So the problem is that it wont roll while in neutral, and overall everything feels to tight. The bronze bushings are lined up so that isnt an issue. I put something back together wrong and I would like to know if anyone else has any input to what i could of possibly done before i pull the transaxle apart for the millionth time just a picture from today | |
Age : 23 Join date : 2014-01-22 Points : 4333 Posts : 546 Location : north carolina
| Subject: Re: Craftsman Lt2000 Project April 2nd 2015, 7:26 pm | |
| u r have the same problem I had with my mower, everything looks right goes together right and everything can be lined up but its to hard to turn is because you welded the spider gears wrong I know thi might sound stupid but there is a top and bottom gear and a surtan way you haft to put the shaft the the spider gears are on it has to go all the right way so what I did was grinded off the welds put everything back together it works fine so then I took it apart and goes a sharpi and maked how its suppose to go and it didnt bind up anymore | |
jamcco Member
| Subject: Re: Craftsman Lt2000 Project April 3rd 2015, 6:29 pm | |
| It turns out, it doesnt have to be pulled apart, it just had to be brokenin....woooot! It drives, shifts, and performs the way it should. all the front end needs is coil buckets and limit straps and it is done for the time being, exhaust needs to be reroute if i want to put my muffler back on, brakes need to be fixed, and skid plate needs to be made to save my already beat up transaxle, somehow it keeps on living, and that should be respected haha, anyways updates should be coming soon | |
crafsmankiller Member
Age : 26 Join date : 2012-10-18 Points : 4655 Posts : 412 Location : livingston texas
| Subject: Re: Craftsman Lt2000 Project April 4th 2015, 4:34 pm | |
| Ill tell ya, these mst206s are tough SOBs. Whoever manufacters them did somethin right fir sure.. their almost indestructible | |
jamcco Member
| Subject: Re: Craftsman Lt2000 Project April 4th 2015, 8:55 pm | |
| I definetly have to agree with that, the thing drives great with this front end I tell yah, I made some temporary buckets for the coils and it drives over the bumps amazingly, much spongier, the only thing is it can't be dumped into corners because then it three wheels. It needs a skid plate now, I feel like the JB weld may now be a soft spot, only a small suspicion , any ways I have plans to make a bumper as well and it definetly needs a couple of "Oh shiz" bars on the fenders to keep me from falling off, I can't wait till the snow melts so i can do some crawling in the woods and really test this things capabilities | |
jamcco Member
| Subject: Re: Craftsman Lt2000 Project April 5th 2015, 1:31 pm | |
| I'm pretty sure the arms have rubber bushings where it meets the axle tubes to allow twisting. Not sure. But yea no problem on using any of my designs at all | |
jamcco Member
| Subject: Re: Craftsman Lt2000 Project April 18th 2015, 7:26 pm | |
| Drives really good with this suspension, rides so much better than the 4 link did. I was doing some trail riding today and realised I need to make sliders for the floor boards. Sorry I have no pics but while going through the woods I was hitting trees and managed to add a few dents , A rear bumper is in order to I have gotten lucky so far because the rear tires stick out so far, but eventually I am going to hit something, planning on a backrack/trailer hitch mix for the bumper | |
jamcco Member
| Subject: Re: Craftsman Lt2000 Project April 20th 2015, 4:14 pm | |
| Today the drag link for the steering blew. I am going to pull the entire steering system off my other tractor and put it on this one. This thing keeps breaking, soon enough I am just going to have to rebuild the whole thing I lifted the tractor today and the linkage just fell out, the metal where the ball joint is cracked the pre-existing steering setup what will replace what i currently have, In my opinion, this is an upgrade, but i have no experience with this setup | |
the old guy Member
Age : 73 Join date : 2015-02-02 Points : 3385 Posts : 37 Location : eastern Kentucky
| Subject: Re: Craftsman Lt2000 Project April 20th 2015, 9:42 pm | |
| I disagree with you I think the steering box in the first picture is far better than the one in second one. I have both the bottom one has a plastic block that holds the steering shaft wears out real fast. the first one is much stronger built. if you look at the bottom of your steering shaft where it comes out of the steering box you will find a hole there should be a pin thru it to prevent the shaft from falling out the bottom of the tractor if the steering wheel is removed .I replaced the pin with a 3/4 shaft collar which allows you to tighten the pinion gear in the rack when needed . what you need is better tie rod and drag links with real 3/8s tie rod ends not the crap that come on mowers from the factory. hope this helps. | |
jamcco Member
| Subject: Re: Craftsman Lt2000 Project April 21st 2015, 12:47 am | |
| Thanks for the input, a real joint is definetly in order. for now i will swap this over, and then go to a better set up in the future, this tractor may be seeing the end of it's days soon, so this will get me by. The transaxle slips out of gear occasionally and the engine burns more gas than oil
the old guy Member
| Subject: Re: Craftsman Lt2000 Project April 21st 2015, 6:43 pm | |
| Jamcco you'r Sears is about the same condition as my old statesman. Mine won't steer to right very well the frames is breaking at the front axel and getting hard to shift. I think I better speed things up on my latest build or be without a tractor. | |
jamcco Member
| Subject: Re: Craftsman Lt2000 Project May 19th 2015, 8:32 pm | |
| so the steering finally got replaced today, and i have to say, the system works great, so much tigther. A small tip, on the arm that comes off the shaft the moon gear sits, you can grind away the little key/guide. this will allow you to clock the arm in any position you want started off today with everything blown apart, unbolted the steering from the parts mower and swapped everything over front end, still holding up well, could use a few gussets here and there full flex, was able to drive right on over the stump without a problem NEEDS LIMIT STRAPS!! a year later, and the kohler still lives, smokes worse than a chain smoker and is shortening my life of many years, but it still has enough grunt to crawl through almost anything | |
jamcco Member
Carshowkid Member
Age : 24 Join date : 2014-07-22 Points : 3933 Posts : 347 Location : Downers Grove Illinois
| Subject: Re: Craftsman Lt2000 Project August 3rd 2016, 11:20 am | |
| Very cool build! I'm trying to figure out a good front suspension for my tactor... And any updates on this thing? | |
