| Mst 200 series ball bering support | |
dmania42 New Member
Age : 35 Join date : 2014-03-19 Points : 3708 Posts : 18 Location : pine bush ny
| Subject: Mst 200 series ball bering support March 25th 2014, 1:15 am | |
| So peerless makes a upgraded needle bearing kit for them but here is the part # for a ball bearing that fits better and has greater load capacity! I test fitted them fit like a glove! Mst205-206
6203-2RS-12 3/4 Bearing 0.750 inch ID 3/4 x 40x12 Sealed | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-22 Points : 7102 Posts : 2914 Location : Ontario Canada
| Subject: Re: Mst 200 series ball bering support March 25th 2014, 1:54 am | |
| Great info, thanks for posting! And- if it fits the MST, there's a dang good chance it will fit 800 and 900 series (3/4"). | |
dmania42 New Member
| Subject: Re: Mst 200 series ball bering support March 25th 2014, 2:01 am | |
| No problem need to get info like this out there. Good part u can get bearings that can handle 15000 rpm at about $5-10 each more exspensive Japan brands 17000rpm upwars $20. | |
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5230 Posts : 1311 Location : NW USA
| Subject: Re: Mst 200 series ball bering support March 25th 2014, 2:56 pm | |
| I found these awhile back
the correct part number from NAPA is 7-04140 spindle bearing. I think DU however stands for 3/4" ID so when ordering specify 6203-3/4. peerless part M83899, JD8535, AM122158, 780119, 37-9500, 37-0200, 106085, 106084, 106085, 106085, and 106084. •ID: 3/4", OD: 1-19/32", Height: 15/32". Ref. #6203-2RS 3/4. Fits Dixon & Toro/Wheel Horse. Replaces AMF/Dynamark/Noma #(s) 12325; Bearing #(s) 6203-2RS 3/4, 6203-RS 3/4; Dixon #(s) 6151, 539125582; Tecumseh #(s) 780119; Toro/Wheel Horse #(s) 10-6084, 10-6085, 37-0200. | |
WilliesBuilds Member
Age : 28 Join date : 2013-06-20 Points : 4353 Posts : 329 Location : Florida
dmania42 New Member
| Subject: Re: Mst 200 series ball bering support March 25th 2014, 4:05 pm | |
| You wont notice a huge difference but the transaxle will be alot stronger and rigid It feels good knowing your trans can handle just alittle more IMHO ! | |
| Subject: Re: Mst 200 series ball bering support March 25th 2014, 4:06 pm | |
| - dmania42 wrote:
- Yupp that's them
much better than the needle bearings peerless offers just ordered them up! I got these off ebay for 2$ or something like that not to long ago just curious how much did you find yours for? | |
dmania42 New Member
| Subject: Re: Mst 200 series ball bering support March 25th 2014, 4:36 pm | |
| I had my boss order them through his suppler $4 a piece for some high speed ones. And yea I like the ridgide it give the trans I haul heavy loads in a trailer including people lol
| Subject: Re: Mst 200 series ball bering support March 25th 2014, 5:55 pm | |
| - dmania42 wrote:
- I had my boss order them through his suppler $4 a piece for some high speed ones.
Ive been wanting to haul some people too lol it helps when you work at a salvage yard lol | |
dmania42 New Member
| Subject: Re: Mst 200 series ball bering support March 25th 2014, 6:01 pm | |
| Nice man I work at a small engine shop I get all my tracror stuff from him at his cost lol and endless used tractor parts on junk tractors ppl don't wana fix got my 31cube briggs goin for 45 $ with all new gaskets:-D just fixed a head with a poped valve seat and been using since lol | |
| Subject: Re: Mst 200 series ball bering support March 26th 2014, 12:19 pm | |
| - dmania42 wrote:
- Nice man I work at a small engine shop I get all my tracror stuff from him at his cost lol and endless used tractor parts on junk tractors ppl don't wana fix got my 31cube briggs goin for 45 $ with all new gaskets:-D just fixed a head with a poped valve seat and been using since lol
thats freaking awesome dude livin the dream lol sounds good alwsays wanted to open a shop here i dont see to many around. | |
