| Briggs Engine Wiring Diagram | |
+8Jamus Jordan ferg RompinRedneck arild365 Chunk dangeroustoys56 Webmaster 12 posters |
ferg Member
| Subject: Re: Briggs Engine Wiring Diagram January 9th 2012, 3:27 pm | |
| - RompinRedneck wrote:
- Sorry for bringing this thread back from the dead, but I am having a problem directly related to this thread. What do I do with the black wire if my tractor does not have lights?
the wires are usually painted black, use some sand paper or a craft knife to scrape away the paint. The red wire charges the battery, and the orange or white wire is for the head lamps | |
RompinRedneck Member
Age : 30 Join date : 2012-01-01 Points : 4521 Posts : 41 Location : CT
Jordan Member
Age : 29 Join date : 2010-10-03 Points : 5117 Posts : 170 Location : Ontario Canada
| Subject: Re: Briggs Engine Wiring Diagram January 9th 2012, 7:04 pm | |
| ok so what if i have the carb with a wire coming out of it? i need to put that engine in another tractor and i cant take the wire harness with it because the safety switches wont work on the new tractor i have wired a few tractors myself and they always work out for me i just need to know what to do with that wire | |
| Subject: Re: Briggs Engine Wiring Diagram January 9th 2012, 7:14 pm | |
| - Jordan wrote:
- ok so what if i have the carb with a wire coming out of it? i need to put that engine in another tractor and i cant take the wire harness with it because the safety switches wont work on the new tractor
i have wired a few tractors myself and they always work out for me i just need to know what to do with that wire Your carb has a fuel shutoff solenoid. You can bypass it by unscrewing it from the bottom of the float and snipping off the needle that you see. You will need to use a manual shutoff on the fuel line after doing this though. Refer to my video if need be. Good luck! https://youtu.be/f3j3LjiqhOA | |
Jordan Member
| Subject: Re: Briggs Engine Wiring Diagram January 9th 2012, 8:56 pm | |
| have you tested this out yet? because its actually my brother engine that has it and i dont wanna have to pay to fix it for him if i do something wrong, and he actually runs the manual shut off anyway because if the fuel is left on it floods the engine | |
Jamus Established Member
Age : 44 Join date : 2010-06-28 Points : 5568 Posts : 511 Location : Southern WV
| Subject: Re: Briggs Engine Wiring Diagram January 9th 2012, 9:24 pm | |
| I have an engine with that electric valve on it in my murray. I ran it to a toggle switch as a sort of secondary cutoff along with the coil wire. I can't remember how I wired it in though. | |
Guest Guest
| Subject: Briggs Engine Wiring Diagram January 9th 2012, 9:47 pm | |
| the techies have a screw option to replace the cut off sol. in their carb kits. not sure if briggs has the same thing or not. the plunger shuts the gas off when you turn the key off to eliminated that 10 second delayed pop from the muffler. if you have rewired for just the toggle kill and push button start, you could used a DPST toggle for the fuel stop solenoid. then you wont run the battery down trying to start it if you forget to turn on the other switch make sure to fuse the hot wire before the switch in case the wires or the switch shorts.
Jordan Member
| Subject: Re: Briggs Engine Wiring Diagram January 10th 2012, 7:24 pm | |
| i have a spare carb for the engine anyway so i just cut the plunger off and the engine runs fine, no problems at all so i put the engine on the other tractor and wired it like i normally do and it runs great | |
csonka39 New Member
| Subject: Re: Briggs Engine Wiring Diagram January 13th 2012, 10:53 pm | |
| First of all, Thanks for response. Correction, I have a 16 hp twin briggs pig, ordered a new coil as the one the motor had was burnt at the ground and wires where coming from inside the plastic. So, technically once i install and gap the new coil w/ the ground unattached the motor should give me some spark, correct?, from there I can bypass wiring like the diagram from fearlessfront, and be set to dominate the back 1/2 acre. | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6162 Posts : 1434 Location : east dublin georgia
| Subject: Re: Briggs Engine Wiring Diagram June 9th 2012, 8:00 am | |
| I've had good luck wiring up a couple of my mowers, including a twin, using the diagram posted by fearlessfront. It's in the wiring topic stickied to the top. | |
Age : 53 Join date : 2010-02-10 Points : 6838 Posts : 1726 Location : Florida, USA
| Subject: Re: Briggs Engine Wiring Diagram June 9th 2012, 8:37 am | |
| Csonka39: Yes - the mag will have spark when its unhooked - you wont be able to shut it off until you touch the mag lead to ground tho.
Actually thats how i see if my clunkers i drag home work - unhook the motor from the harnesses ( to avoid a bad ign switch scenario) , and starter solenoid - just jump it off the starter motor - if it runs, then i hook stuff back up and troubleshoot from there. | |
Junkstarbuilds Administrator
Age : 47 Join date : 2012-07-03 Points : 4605 Posts : 236 Location : Fort Stewart Georgia
| Subject: Re: Briggs Engine Wiring Diagram July 14th 2012, 12:27 am | |
| I will say this, you dont always recieve a tractor with factory wiring...remember alot of us are CL hunters for free tractors..I just recently got a yard machine for my buddy's first off road mower... lets just say, the guy said it wouldnt start......and I found out why...
12.5 B&S and it had some very strange wiring I hadnt seen before....mostly because it had a lot of rewirng to counter the auto shut offs and safeys..not to mention it didnt have a key, so that was "altered"
Its funny how things come full circle...I just posted a "typical wiring diagram for B&S" on my facebook...
@Fearless, I went back just to watch your video when you redid the craftsman...I too was confused, this 12.5 had two wires for the alternator..
I get mostly get questions on how to remove the saftey switches...seat, parking, and mower deck engagement... | |
Cr8zyB0b Member
Age : 27 Join date : 2013-01-02 Points : 4155 Posts : 30 Location : England uk
| Subject: Re: Briggs Engine Wiring Diagram January 3rd 2013, 11:36 am | |
| - FearlessFront wrote:
- I've been asked about wiring alot recently. So here is a diagram that should help everyone. Let me know if you have any questions.
would this work for a honda gv400 verticle shaft motor | |
