| Craftsman GT-18 Utility/Trail Tractor. | |
TokyoDrift99 Member
Age : 24 Join date : 2014-03-28 Points : 3796 Posts : 111 Location : Vermont
| Subject: Craftsman GT-18 Utility/Trail Tractor. May 26th 2014, 11:06 pm | |
| My tractor is a Roper made Craftsman GT-18 that my uncle gave to me for free. It has a 18 hp oppy, and the Peerless 633 3 speed with hi/lo so it really has 6 speeds. This thing has always been a piece of crap from the day I got it. I haven't done many mods at all, but I will show them to you guys. It has been completely rewired with brand new connectors and wire, heat shrink tubing on every connection using the key switch. I also replaced the disgusting waterlogged, cracked rotted seat foam with some chair pads from Wal-Mart covered in gorilla tape, I ran out of tape, but you will get the idea. Currently it needs a starter but that has been ordered, so here are a bunch of pictures for you guys. I sanded off the REALY rough rust and painted the rotted out seat pan. These are the seat cushions, they were like $7. Way cheaper than a seat. I took two cushions and covered them in gorilla tape. I ran out of tape but you get the idea. Rewired with key switch. Beefy @ss peerless 633 rear end. The heart of the beast! Back when stuff was built to last. Made in USA! | |
Moose Established Member
Age : 34 Join date : 2014-01-12 Points : 4713 Posts : 919 Location : Defiance, Ohio
TokyoDrift99 Member
| Subject: Re: Craftsman GT-18 Utility/Trail Tractor. May 27th 2014, 5:15 am | |
| - Moose wrote:
- can never go wrong with the old high lows some sturdy trannys for pulling romping and just having fun :Dgood luck with it!
You are darn right it is sturdy, i dropped the whole tractor from two feet straight onto the rear end. I expected to see gear oil and chunks of aluminum, but it was fine! | |
| Subject: Re: Craftsman GT-18 Utility/Trail Tractor. May 27th 2014, 11:22 am | |
| - TokyoDrift99 wrote:
You are darn right it is sturdy, i dropped the whole tractor from two feet straight onto the rear end. I expected to see gear oil and chunks of aluminum, but it was fine! Lol yeah I did that and I used to get the 18hp kohler on our last tractor going as fast as itd go and pop wheelies in 3rd high when I was younger, when I was at pugs I challenged TRB to a pull off (which ended up being TRB and Stretch) it didnt end well but in first low even with a split diff she dug in and lifted the tractor right up! | |
Age : 23 Join date : 2013-04-08 Points : 4971 Posts : 913 Location : Central Pa
| Subject: Re: Craftsman GT-18 Utility/Trail Tractor. May 27th 2014, 5:36 pm | |
You are darn right it is sturdy, i dropped the whole tractor from two feet straight onto the rear end. I expected to see gear oil and chunks of aluminum, but it was fine! Lol yeah I did that and I used to get the 18hp kohler on our last tractor going as fast as itd go and pop wheelies in 3rd high when I was younger, when I was at pugs I challenged TRB to a pull off (which ended up being TRB and Stretch) it didnt end well but in first low even with a split diff she dug in and lifted the tractor right up! Do you have footage Moose??? | |
| Subject: Re: Craftsman GT-18 Utility/Trail Tractor. May 27th 2014, 6:16 pm | |
| - LAWN MOWER MUDDER wrote:
You are darn right it is sturdy, i dropped the whole tractor from two feet straight onto the rear end. I expected to see gear oil and chunks of aluminum, but it was fine! Lol yeah I did that and I used to get the 18hp kohler on our last tractor going as fast as itd go and pop wheelies in 3rd high when I was younger, when I was at pugs I challenged TRB to a pull off (which ended up being TRB and Stretch) it didnt end well but in first low even with a split diff she dug in and lifted the tractor right up! Do you have footage Moose??? Lol junkstar and 3dmachines do but I was to busy watching my tractor wheelie away to get any :p | |
TokyoDrift99 Member
Age : 23 Join date : 2014-01-22 Points : 4333 Posts : 546 Location : north carolina
TokyoDrift99 Member
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4341 Posts : 467 Location : Greensburg, PA
TokyoDrift99 Member
Angchor Member
Age : 66 Join date : 2014-04-14 Points : 4181 Posts : 491 Location : Index, Washington
TokyoDrift99 Member
camomanusa Member
TokyoDrift99 Member
TokyoDrift99 Member
TokyoDrift99 Member
