Excellent! id put like 5-8 degrees caster on the spindles when you weld them on. And the steering arms that come with them should be modified for acerman affect, so it will turn wayyyy better.
Take time welding the spindles on! Not a race. Clean up the metal and maybe look at different forms of welding to weld it on nice and solid. It's the difference between you and the pavement.
5-8 degrees positive caster? And i'm buying spindles from bmi karts or some go-kart place online not 100% sure yet
Last edited by Craftsman1998 on August 27th 2014, 10:33 am; edited 1 time in total
Age : 23 Join date : 2013-04-08 Points : 4993 Posts : 913 Location : Central Pa
5-8 degrees positive camber?
No, he means caster, look HERE and HERE for your front axle advice.
The front axle on my rally has 10* positive caster, ackerman set-up, no toe, and no camber. It handles really well on and off road. Remember grind the end of your spindle into a point so you can get really good penetration on your welds.
Again.
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 4936 Posts : 1068 Location : New jersey
I leveled my axle in a bench vise and used an angle finder to get 10*. Make sure your axle is squared off first (thus the vise). You should be able to get an angle finder at any major hard ware store. (Northern Tool, TSC, etc...)
Welded the transmission brackets to the frame The welds aren't pretty but there strong ill clean them up with the grinder. And i can weld better than that its just it was a tight area and it was hard to see how much of a puddle i was making to know how fast to move the welding gun.
Welded the corners of the frame too
Started stripping paint off the frame because i'm going to be welding up stuff for the steering
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5230 Posts : 1311 Location : NW USA
Started priming spots that i wont be modifying so it doesn't rust
I locked my mst 205 thats going to be used for off roading. My plan is 2 have 2 transaxles one locked for off roading then unlocked 206 or 820 for high speeds and each tranny will have different pulley sizes for different speeds and ill swap them out when i need them. the reason i'm not using a locked transmission is because i don't want a weld breaking at high speeds but i want pos for offroading which is why i'm going to use 2 transmissions. And my sisters tractor had a 6 spd spicer so i pulled it out and put this mst in it to test it before i use it in the racing tractor. but it will be awhile before the tractors done. and so far it works very well might lock the spicer for a spare.
welding in holes that aren't going to be used
Butt smooth finish lol and i am going to flap disk it i just need to buy some. And i actually used a piece of copper pipe to fill in the holes i stuck it in a vice and flattened it out works beautifully.
My neighbor gave me a kawasaki bike front end so i took the parts i needed of it. and he gave me to bikes one im using for parts and the other im selling.
So i took all the switches of the kawasaki handlebar because its to big and i put them on the bike handle bar which i'm going to use and if i like it ill keep it on the tractor if i don't like it ill put a steering wheel back on.
I might use the twist throttle not sure
Got mirrors a speedometer which i dont think ill be able to use and a tach that i might be able to use.
And heres the tractor sitting in pieces lol
and my neighbor gave me a diamond plate tool box this is just the lid of it so ill be doing some cool stuff with this oh and i forgot to take a picture of them but i got directional lights too
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6327 Posts : 2101 Location : Norway, Europe
Cool, i've got one of those diamond plate boxes sitting around too, just haven't hacked it up for a project yet. I hooked a snowmobile tach up to a mower engine one time and got it to show something, but I never tried hooking it up correctly to see how accurate it would work. I hooked a wire from the tach to the shut off wire on the coil.
Im going to hold off working on this build until February 1st so i can enter it in the build off so no more updates until then. And i got a new laptop so maybe i can do live streams straight from the garage. just an idea and for some reason i cant post pictures on the forum for some reason don't know why. i might have to set up my old computer just to post pictures lol.
