| | Pulley Swap Problem | |
BigPip Member
Age : 44 Join date : 2014-08-10 Points : 3631 Posts : 73 Location : Central FL
| Subject: Pulley Swap Problem August 24th 2014, 5:49 pm | |
| I am working on my build and I started with the pulley swap and the shaft came out with my pulley. I am assuming that wasn't supposed to happen but being an amateur with these I want sure what I was looking at to get out back together. I was going to try and attach a picture but I guess I need to read how to do that on this forum. It is a Spicer / DANA transmission out of a 2004 murray | |
Age : 27 Join date : 2013-04-10 Points : 5545 Posts : 1408 Location : Galway NY
| Subject: Re: Pulley Swap Problem August 24th 2014, 6:48 pm | |
| there is a snap ring that broke.. youre going to have to open it up, find the broken bits and replace the snap ring. no big deal really, just make sure you get all the bits out.. that could go badly if there is some left in there
| | | Angchor Member
Age : 66 Join date : 2014-04-14 Points : 4203 Posts : 491 Location : Index, Washington
| Subject: Re: Pulley Swap Problem August 24th 2014, 6:59 pm | |
| - willis923 wrote:
- there is a snap ring that broke.. youre going to have to open it up, find the broken bits and replace the snap ring. no big deal really, just make sure you get all the bits out.. that could go badly if there is some left in there
WORD!!! Man, I cringed when I read that the shaft had come out with the pulley. Don't even spin the tires until you get it apart and make sure there are no broken parts inside. | |
| | | BigPip Member
| Subject: Re: Pulley Swap Problem August 27th 2014, 11:42 am | |
| Thanks! I got it all tore apart the other night and pulled out all the pieces with a magnet. I picked up a new clamp last night and hopefully I will get it all back together by the weekend. | |
| | | | BigPip Member
| | | | CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 4020 Posts : 337 Location : Woodville Al
| Subject: Re: Pulley Swap Problem August 28th 2014, 9:55 am | |
| - willis923 wrote:
- ok, good. just so you know, thats called a 'snap ring'
Actually its an external snap ring. | |
| Who is online? | In total there are 20 users online :: 0 Registered, 0 Hidden and 20 Guests
