| | The Basics of Paint | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4342 Posts : 467 Location : Greensburg, PA
| Subject: The Basics of Paint August 30th 2014, 10:38 pm | |
| So after much time of realizing that i have no knowledge about paints, i figured id ask about it on hear. I never understood the differences from the normal cans of paint and enamels. Is there benfits of using an enamel over basic paint? Thats all i can really say though for now because i cant think of anything else, but id love to hear about everybodys knowledge about paint and of the topic. Also what kinds of paint are good for use on a specific part of a tractor compared to using a different type.
| | | Moose Established Member
Age : 34 Join date : 2014-01-12 Points : 4714 Posts : 919 Location : Defiance, Ohio
| Subject: Re: The Basics of Paint August 30th 2014, 11:02 pm | |
| I have a basic knowledge of paint I guess though I mostly rattlecan so from my experience: enamels are harder than your regular paint when dry and dry to a glossy finish some require primer and all that fun stuff but others dont (read the label) basic paints you can pretty much just spray on anything and hope for the best they can be in a variety of finishes gloss to matte and can be sprayed on pretty much anything. basic paints usually require a clear coat to achieve a nice hard skin. | |
| | | camomanusa Member
| Subject: Re: The Basics of Paint August 30th 2014, 11:04 pm | |
| so enamels pretty much regular paint with clear coat in it? | |
| | | Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 4915 Posts : 1068 Location : New jersey
| Subject: Re: The Basics of Paint August 31st 2014, 11:38 am | |
| - camomanusa wrote:
- so enamels pretty much regular paint with clear coat in it?
Yep enamel paint has clear coat in it but you can put clear coat on top of the enamel paint for more protection but its not necessary | |
| Subject: Re: The Basics of Paint August 31st 2014, 1:44 pm | |
| I'd use enamel for tractor stuff most of your tractor companies do now a days I think | |
| | | Doc Sprocket Site VIP
Age : 50 Join date : 2013-04-21 Points : 7081 Posts : 2914 Location : Ontario Canada
| Subject: Re: The Basics of Paint August 31st 2014, 5:50 pm | |
| Before I say anything else- I am a painter by trade.
"Enamel" is a general term, used to describe the "hardness" of a coating. I gotta be honest here- this "clear" thing, is a new one on me. | |
| | | TheBeal Veteran Member
Age : 29 Join date : 2013-06-06 Points : 5476 Posts : 1398 Location : Central PA
| Subject: Re: The Basics of Paint September 1st 2014, 12:39 am | |
| Maybe there ought to be a writeup/informational/how-to post about painting? | |
| Subject: Re: The Basics of Paint September 1st 2014, 2:01 am | |
| Doc if you do a write up on how to get better adhesion for tractors I will uhhh... not post awkward sentences? | |
| Subject: Re: The Basics of Paint September 1st 2014, 10:46 am | |
| Hehehehe... LOL- Sorry... I suppose a write-up could be done. But at the most basic level- you're not gonna believe this- read the label! Yup. Scary, huh? They all tell you to have the surface clean, and free of dirt, oil, grease, etc. Loose, cracked, or peeling paint should be scraped and sanded off, etc. When, and with what product to prime, temperature, humidity, etc- it's all there on the label! Aww heck... Maybe I WILL do something... | |
| Subject: Re: The Basics of Paint September 1st 2014, 11:50 am | |
| Should do a basic level a intermediate and a semi pro level :p | |
Age : 34 Join date : 2013-11-02 Points : 6926 Posts : 2906 Location : New Jersey USA
| Subject: Re: The Basics of Paint September 7th 2014, 8:03 pm | |
| Getting whatever your painting clean before you spray it is important, which has already been mentioned. You can get special cleaner for that which you wipe on with a clean rag. I don't like to touch the parts before spraying them because some times the oils from your skin will mess things up. Temperature can be an issue if it's extremely cold or really hot in direct sun light. Like Doc said, that's on the label. I've had a lot of trouble with humidity. Mostly with black paint. If it's really humid out (such as a hot day right after a rain) the black turns gray when it drys. I couldn't figure out why for quite a while. But...I guess that's why. | |
| Who is online? | In total there are 33 users online :: 0 Registered, 0 Hidden and 33 Guests
