| " Spare Parts " | |
+41997 Murray Moose Ariens YT11 truckin42 8 posters |
truckin42 Veteran Member
Age : 25 Join date : 2012-10-04 Points : 5265 Posts : 1070
| Subject: " Spare Parts " August 24th 2014, 9:52 pm | |
| This is my latest project. A fully custom offroad tractor. Homemade frame, 6.5hp motor, 3 speed tranny, 22" tires, rear steer, 2 seater, front wheel drive... An off-roading machine. Homemade wheel hubs. 1in axles.
Last edited by truckin42 on September 8th 2014, 8:22 am; edited 2 times in total | |
Age : 27 Join date : 2012-10-31 Points : 4926 Posts : 745 Location : The Wyo-Braska Panhandle
Moose Established Member
Age : 34 Join date : 2014-01-12 Points : 4713 Posts : 919 Location : Defiance, Ohio
| Subject: Re: " Spare Parts " August 29th 2014, 4:13 pm | |
| gonna need some mud flaps for sure! always wondered if a front wheel drive would work pretty good mudding | |
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5208 Posts : 1311 Location : NW USA
| Subject: Re: " Spare Parts " August 30th 2014, 2:02 pm | |
| Im making some custom steel fenders for it here soon. Im actually not sure if its gonna work or not but ill make it work lol. 1997 Murray, yes it is a rototiller. Clutch setup. Ill get some more pics soon when I get more progress made. | |
| Subject: Re: " Spare Parts " September 8th 2014, 8:21 am | |
| Finally able to drive to drive this thing around and test it. This thing is unstoppable it never gets stuck, doesn't spin its just full traction all the time. But the frame needs braced, Needs a metel front end, A better seat, And it needs some steering lol ( It only goes straight lol ) But tell me what ya guys think? Open to all suggestions. | |
| Subject: Re: " Spare Parts " September 8th 2014, 11:01 am | |
| I suggest bigger tires and some gnarly ones at that! | |
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5523 Posts : 1408 Location : Galway NY
| Subject: Re: " Spare Parts " September 8th 2014, 2:03 pm | |
| that thing is pretty sweet! is that a U-joint on the back? technically, you could make it articulating 4wd! needs some bigger rears though | |
| Subject: Re: " Spare Parts " September 9th 2014, 8:38 am | |
| - willis923 wrote:
- that thing is pretty sweet! is that a U-joint on the back? technically, you could make it articulating 4wd! needs some bigger rears though
Thanks, and no, 4wd is in the future plan lol. I got a set of atv tire with 4bolt rims im gonna swap on..20in Also the rear steering set up works pretty good, steers this machine with no problem, It does surprisingly well with a locked tranny. But here are some pics of the set up. New cast iron front axle too. Front axle and bigger temporary front tires Steering plate. Steering arms | |
| Subject: Re: " Spare Parts " September 10th 2014, 2:01 pm | |
| Got some pictures of Spare Parts.. After doing some testin, everything seems to hold up well..Now i just gotta finsh weld everything and tighten up the steering then it will be ready for its frist trail ride. | |
| Subject: Re: " Spare Parts " September 11th 2014, 1:17 pm | |
| Got some progress made..Got the steering shaft extended and made up a custom steering wheel. And also got mostely everything welded in place, just gotta build a seat and some foot boards then time for a trail ride out in the field. | |
Doc Sprocket Site VIP
Age : 50 Join date : 2013-04-21 Points : 7080 Posts : 2914 Location : Ontario Canada
B440 Member
Join date : 2014-01-22 Points : 3966 Posts : 226 Location : Thompson, CT
| Subject: Re: " Spare Parts " September 13th 2014, 8:19 pm | |
| I like it. It's smaller than a typical machine.
Question: The steering looks like it will steer incorrectly. When you turn left, you will go right? I am wrong, yes? | |
| Subject: Re: " Spare Parts " September 15th 2014, 8:24 am | |
| - B440 wrote:
- I like it. It's smaller than a typical machine.
Question: The steering looks like it will steer incorrectly. When you turn left, you will go right? I am wrong, yes? Yes you are right, left is right, right is left. Update, The steering quit working, it just destroyed the rod ends now the tires will turn 90* without effecting the steering. Back to just goin straight, Its got a straight axle set up (3/4in) with heavy dudy bearings. This set up does great just have no steering lol. | |
| Subject: Re: " Spare Parts " September 15th 2014, 10:15 am | |
| Just weld a rod to the linkage and steer it like a tiller on a boat :p | |
| Subject: Re: " Spare Parts " September 15th 2014, 12:31 pm | |
| - Moose wrote:
- Just weld a rod to the linkage and steer it like a tiller on a boat :p
I don't understand what your meaning, how would that work? | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6305 Posts : 2101 Location : Norway, Europe
| Subject: Re: " Spare Parts " September 17th 2014, 8:33 am | |
| - Thunderdivine wrote:
- What way is the front?
Its front wheel drive so the big tires are the front end and the small tires are the rear end. Its a backwards set up but it works. | |
| Subject: Re: " Spare Parts " September 17th 2014, 12:39 pm | |
Its front wheel drive so the big tires are the front end and the small tires are the rear end. Its a backwards set up but it works. Ah cool, then i saw it right. | |
| Subject: Re: " Spare Parts " September 17th 2014, 12:41 pm | |
| - truckin42 wrote:
I don't understand what your meaning, how would that work? Itd be direct steer like direct direct more or less you just weld it to the spindle | |
| Subject: Re: " Spare Parts " September 17th 2014, 2:00 pm | |
| - Moose wrote:
- truckin42 wrote:
I don't understand what your meaning, how would that work? Itd be direct steer like direct direct more or less you just weld it to the spindle I see now, ill give it a shot today. | |
| " Spare Parts " | |
