| | Anything Wrong? Ackerman Steering | |
+6LAWN MOWER MUDDER willis923 CornShuck4CE Stretch44875 Doc Sprocket kieranruffell 10 posters | |
Doc Sprocket Site VIP
| Subject: Re: Anything Wrong? Ackerman Steering September 23rd 2014, 7:33 pm | |
| I guess that's a matter of perspective. If you're silly enough to take it as a scale technical drawing... Maybe. Maybe not. | |
| Subject: Re: Anything Wrong? Ackerman Steering September 23rd 2014, 8:10 pm | |
| - Doc Sprocket wrote:
- I guess that's a matter of perspective. If you're silly enough to take it as a scale technical drawing... Maybe. Maybe not.
Wait. What? Im not sure what your referring to. Like, at all lol. | |
Age : 50 Join date : 2013-04-21 Points : 7080 Posts : 2914 Location : Ontario Canada
| | | | Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5463 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: Anything Wrong? Ackerman Steering September 24th 2014, 7:13 pm | |
| ok. I polished things a bit, and clarified some stuff. Really, it's the same thing, just interpreted. Anybody? Mine on the left, original on the right. | |
Join date : 2012-12-21 Points : 6305 Posts : 2101 Location : Norway, Europe
Age : 34 Join date : 2013-11-02 Points : 6925 Posts : 2906 Location : New Jersey USA
| Subject: Re: Anything Wrong? Ackerman Steering September 26th 2014, 10:41 am | |
| Okay, finally got some time to post what I think needs to happen. On left, is a simplified version of what Doc posted, what I would call go-kart/ATV steering. Two tie rods connected to one or two pitman arms in the middle. Works great, but usually we have an engine in the way. On the right is what works for front engine mowers. Steering column is not shown, because it is straight up and down for this simple drawing. It uses an extra connection to the spindles to get the steering hooked up. | |
| | | kieranruffell Member
Age : 24 Join date : 2014-01-22 Points : 3776 Posts : 43 Location : Whangarei, New Zealand
| | | | Moose Established Member
Age : 34 Join date : 2014-01-12 Points : 4713 Posts : 919 Location : Defiance, Ohio
| Subject: Re: Anything Wrong? Ackerman Steering September 27th 2014, 3:01 pm | |
| I have the steering setup on the left for the massey I absolutely love it it is a really tight setup only thing Id change is the ratio but thats because I have big tires lol | |
| Subject: Re: Anything Wrong? Ackerman Steering September 27th 2014, 8:09 pm | |
| - kieranruffell wrote:
- Thanks Doc and stretch that was just what I needed, Now I can get on with making it
Fantastic... Good luck! | |
| Subject: Anything Wrong? Ackerman Steering September 30th 2014, 5:48 pm | |
| Almost finished building this Just one question though... is there supposed to be a certain angle the pitman arm is on? Ill post some pictures soon. | |
| Subject: Re: Anything Wrong? Ackerman Steering September 30th 2014, 7:41 pm | |
- Almost finished building this Just one question though... is there supposed to be a certain angle the pitman arm is on?
Ill post some pictures soon. I have had the best results having the pitman arm parallel to the steering arm when steering is straight. | |
| | | | Sponsored content
| Who is online? | In total there are 21 users online :: 0 Registered, 0 Hidden and 21 Guests
