| | MULE3... Brainstorming, ideas, etc. | |
+11ZSmachines TheBeal mr.modified untrusty huskee Doc Sprocket Deluxe66 willis923 Stretch44875 redlinemotorsportts Carshowkid matt-man 15 posters | |
| Subject: Re: MULE3... Brainstorming, ideas, etc. January 24th 2015, 9:32 pm | |
| You're gunna blow the welds on your intake, kid.
Or maybe that was for nitrous.
Oh well, look crazy like always. Gunna be happy to see what happens when the drivetrain gets set up. | |
| | | ZSmachines Member
Age : 24 Join date : 2014-08-27 Points : 3755 Posts : 221 Location : PNW
| | | | Doc Sprocket Site VIP
Age : 50 Join date : 2013-04-21 Points : 7081 Posts : 2914 Location : Ontario Canada
| Subject: Re: MULE3... Brainstorming, ideas, etc. January 25th 2015, 9:04 am | |
| - ZSmachines wrote:
- will the front suspension be hard enough to support that heavy of an engine? and what PSI are you going to run it @?
Good question. All I can do is set it up, and see what happens. If it's not stiff enough, I can alter the angle of the coilovers, play with the preload, or even change them out for something stiffer. PSI? As in boost? Dunno yet. It remains to be seen how much the T3 can develop with the Kubota's exhaust stream. I WILL be connecting a vac/boost gauge to monitor it, and see where it goes form there. The engine that the turbo came off, had approximately 4x the displacement. I don't expect a lot, but any improvement is improvement. I doubt it will ever spool hard enough to trigger the waste gate. The waste gate is actuated by a diaphragm, which basically measures the difference between boost and atmospheric pressure. I don't know what it's calibrated for, but is non-adjustable. If on the off-chance I think it's developing too much, I'll find a way to bleed off more pressure. Could be as simple as a port on the intake pipe. We'll see. This turbo stuff is new territory for me. | |
Age : 21 Join date : 2016-10-29 Points : 6504 Posts : 3563 Location : Lewisburg, KY
| Subject: Re: MULE3... Brainstorming, ideas, etc. February 3rd 2017, 10:08 pm | |
| Hey Doc, now that you've kind of restarted the Bannerman project, are you going to start a new thread on it or use this one? Or just not post about it? | |
| | | 88ss408 New Member
| | | | CraftsmanQuad19 Veteran Member
Age : 23 Join date : 2016-04-12 Points : 5719 Posts : 2617 Location : Indiana
| Subject: Re: MULE3... Brainstorming, ideas, etc. May 15th 2017, 10:30 pm | |
| We lost M1 during surgery. Doc tried his best but the project just died. M2 became an organ donor. The vanguard from M2 is in his sears, "suburban commando" | |
| | | Packman New Member
Age : 32 Join date : 2017-05-02 Points : 2526 Posts : 4 Location : Waterloo, Illinois. USA
| | | | Sponsored content
| Who is online? | In total there are 19 users online :: 1 Registered, 0 Hidden and 18 Guests CrazycraftsmanMost users ever online was 412 on January 7th 2023, 7:59 am |
