| Need advice | |
Jwaynetown86 New Member
| Subject: Need advice October 4th 2016, 8:02 pm | |
| Did a pulley swap on rearend of my mud mower. Went to a 3.5 in pulley. Runs a solid 17mph. But climbing up a hill she struggles any ideas. I want to still be able to take her off road but it don't seem strong enough now | |
Age : 25 Join date : 2016-07-10 Points : 8350 Posts : 5190 Location : Ontario Canada
| Subject: Re: Need advice October 4th 2016, 8:12 pm | |
| Not enough torque. These motors do fine with stock pulleys, but when you change the ratio (higher) it puts the motor under load more in high gear. So basically you need to do some slight motor mods to get some more torque. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
TheGreenHornet Member
Age : 23 Join date : 2016-04-16 Points : 3182 Posts : 227 Location : Indiana
| Subject: Re: Need advice October 4th 2016, 8:16 pm | |
| What kinda engine/ transmission and pulley setup do you have? like AllisKid said, you need a little more torque, and minor engine mods will help you there. | |
| Subject: Re: Need advice October 4th 2016, 8:34 pm | |
| It has a 15.5 Briggs in it. The pulley on motor is stock(one of the doubles that run the drive and deck) the deck is gone. The tranny not sure it has the speed differential pulley on it. The new pulley is a 3.5. All I've done to the motor is a slight snorkel and a gov adjustment and a foot throttle tied to gov for a lil extra boost if needed | |
| Subject: Re: Need advice October 4th 2016, 9:09 pm | |
| Try tuning the carb a bit. It could possibly be running too lean, causing a loss of power. Also maybe clean the spark plug. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 23 Join date : 2016-04-12 Points : 5719 Posts : 2617 Location : Indiana
| Subject: Re: Need advice October 4th 2016, 9:47 pm | |
| Or, even better, get a mikuni clone slider carb on eBay. they're like 30 bucks. Fearless did a video on making it fit. i think you just have to enlarge the mounting holes on the stock intake manifold to make it fit. | |
| Subject: Re: Need advice October 4th 2016, 9:58 pm | |
| Hahaha. Well there's that, that would sure do the job! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Need advice October 4th 2016, 10:03 pm | |
| oh another thing, it may not be lack of power (i have an 11 horse that i mud bog with, does just fine). with a 3.5 inch pulley on the back and that small stock front, it may be belt slip. i would change the rear to a 4 or 4.5 and do a 4 or 5 on the front. that should help. then to take it a step further, build a double pulley clutch | |
| Subject: Re: Need advice October 4th 2016, 11:21 pm | |
| True, most times the HP rating on the shroud doesn't define what the engine is capable of stock. I mean, the old DB walk behind tractors had 1.25hp, and they where ground engaging machines! I would check for belt slip like CQ said and just do a basic tune-up on the motor. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Need advice October 5th 2016, 9:58 am | |
| Ok. It's the belt running from the motor to the speed diff pulley. I've already went to smaller belt but still slipping up hill | |
| Subject: Re: Need advice October 5th 2016, 10:09 am | |
| So this is on an MTD.....there is only so much you can do with one of these to keep them from slipping. AllisKidD21 runs the vari-drive on his MTD, so he may know something that I don't. I just use my MTD for mowing lol | |
| Subject: Re: Need advice October 5th 2016, 2:55 pm | |
| Thanks hopefully he can get back with me and give me an idea or two | |
| Subject: Re: Need advice October 5th 2016, 3:30 pm | |
| Did, you adjust any of the the linkages for the vari-drive after the pulley swap? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Need advice October 5th 2016, 3:33 pm | |
| no. Just put a spring on the tensioner. | |
| Subject: Re: Need advice October 5th 2016, 4:20 pm | |
| Yeah, sometimes the clutch pull rod needs to be adjusted. It may not be acting all the way through the gears like it should. Would it be possible for you to post some picture of the vari drive on the tractor? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Need advice October 5th 2016, 4:46 pm | |
| I'll be able to maybe when I get home from work later. Still haven't figured out how to on this site. Doing it from my iPhone | |
| Subject: Re: Need advice October 5th 2016, 5:01 pm | |
| The belt comes straight back to variable speed pulley (bottom part) then another belt from top back to trans with tension pulley in there. The drive pulley on front is stock and the belt is an inch shorter than stock. Original is a 35 in x 1/2 v belt. But you are thinking maybe clutch isn't letting it grip around pulley. Right | |
| Subject: Re: Need advice October 5th 2016, 5:49 pm | |
| Yeah. It could be the rear belt slipping, what size was the stock trans pulley? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 4859 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: Need advice October 5th 2016, 7:45 pm | |
| Belts for the vari-drive setup is 5/8 inch. If you use a 1/2 belt it will not get all the gears and will slip in the high gear or the low gear, sorry forgot that part. | |
| Subject: Re: Need advice October 5th 2016, 8:11 pm | |
| I'll try it. Probably buy one this weekend. I hope it works and thanks for all of your help | |
| Subject: Re: Need advice October 5th 2016, 9:08 pm | |
| No problem, good luck! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Caddy_V3 Member
Age : 24 Join date : 2015-07-10 Points : 3291 Posts : 56 Location : Derry NH
| Subject: Re: Need advice October 6th 2016, 7:15 pm | |
| did you try downshifting like in a car? | |
| Need advice | |
