| Lock with out a welder or melting zink! | |
+4redlinemotorsportts Doc Sprocket B440 mudman604 8 posters |
mudman604 Member
| Subject: Re: Lock with out a welder or melting zink! March 11th 2015, 9:32 pm | |
| this weekend i towed my friends tractor (820, oppy, with his big but and his friend,) up and down several hills at top speed, this locker is still holding strong. | |
Vortec7622 New Member
Age : 25 Join date : 2014-09-27 Points : 3494 Posts : 20 Location : Massachusetts
| Subject: Re: Lock with out a welder or melting zink! March 31st 2015, 8:26 pm | |
| Does anyone know if this would work on a Peerless MST-206 545C? I've seen some say yes it will and some say it won't. I've also seen people say you need an even number of teeth for this to work. Does the 545C have 13 or 16 tooth gears? | |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 4914 Posts : 1068 Location : New jersey
| Subject: Re: Lock with out a welder or melting zink! March 31st 2015, 8:50 pm | |
| So, judging by the video this locker will work with my transmission, correct? Do I need one or two extra spiders? Sorry for all the questions, I'm new to this | |
Doc Sprocket Site VIP
Age : 50 Join date : 2013-04-21 Points : 7080 Posts : 2914 Location : Ontario Canada
| Subject: Re: Lock with out a welder or melting zink! March 31st 2015, 9:10 pm | |
| Starting to feel stupid but it's been a long day and I just want to clarify. This locker will not work with 13 tooth spiders? Isn't that what the video showed as working? | |
mudman604 Member
Age : 25 Join date : 2014-12-03 Points : 3543 Posts : 110 Location : hudson FL
| Subject: Re: Lock with out a welder or melting zink! April 1st 2015, 6:35 am | |
| I used 13 tooth, i only put in ONE extra spider gear. One will fit. I know on paper that doesn't work, but there is a small sweet spot there that you can find, and they fit with out wobleing the bull gear. | |
mudman604 Member
| Subject: Re: Lock with out a welder or melting zink! April 1st 2015, 9:30 am | |
| - mudman604 wrote:
- I used 13 tooth, i only put in ONE extra spider gear. One will fit. I know on paper that doesn't work, but there is a small sweet spot there that you can find, and they fit with out wobleing the bull gear.
You might have gotten away with it for now, but it sounds dodgy to me. A lot of stress concentrated over a small area. Honestly, I wouldn't do this. | |
mudman604 Member
| Subject: Re: Lock with out a welder or melting zink! April 1st 2015, 9:38 am | |
| I have two trannys locked this way with 13 tooth, one is being driven by a twin. Still holding strong. I don't recommend for high speeds becausenofmthe inbalence on the axle though. Not over 20mph I'd say. Also, it actual has more surface area than welding, so the stress is really, more spread out. | |
mudman604 Member
mudman604 Member
mudman604 Member
Yard Ape New Member
Age : 27 Join date : 2015-02-23 Points : 3354 Posts : 19 Location : homer city pa
mudman604 Member
mudman604 Member
