| All-Terrain Murray aka Hellpussy :mtd2fst4u: | |
+7redlinemotorsportts Ariens YT11 Carshowkid f4klift mr.modified Craftsman1998 Doc Sprocket 11 posters |
MatthewD Veteran Member
Age : 22 Join date : 2014-11-16 Points : 5515 Posts : 1993 Location : Northern Ireland
Guest Guest
| Subject: Re: All-Terrain Murray aka Hellpussy :mtd2fst4u: March 22nd 2015, 1:42 pm | |
| not much of an update on barney, just awaiting a little bit for some more warmer weather so i can start the painting atleast dont like paint drying when its in the 60's and high humidity |
Age : 34 Join date : 2013-11-02 Points : 6925 Posts : 2906 Location : New Jersey USA
| Subject: Re: All-Terrain Murray aka Hellpussy :mtd2fst4u: March 23rd 2015, 10:58 pm | |
| I've had problems with black paint in humid weather, turns greyish as it drys. Terrible, just terrible. Couldn't figure out why it was doing it for a while, but finally figured it out. | |
Guest Guest
Guest Guest
Guest Guest
Guest Guest
Guest Guest
Guest Guest
| Subject: Re: All-Terrain Murray aka Hellpussy :mtd2fst4u: April 8th 2015, 3:14 pm | |
| Went to a friend's hose today took him some tires and stickers and scored me big ol 19.5 hp 98 model opposed twin for barney...runs good too just needs a starter gear and I have that so ooo yea we rolling boys buying my bearings Friday for the front wheels too |
Guest Guest
Guest Guest
| Subject: Re: All-Terrain Murray aka Hellpussy :mtd2fst4u: April 10th 2015, 10:24 pm | |
| update 10:22 pm put a gear on the starter and had a fully fresh marine battery to crank it over annnnd was a no go starts shot so going to change the guts out of one of my other starters see what happens also was told sometimes its best to use wiring to the starter instead of jump starting it with cables so ill try that too could possibly not be getting enough connection but im saying its bad most likely sounds like a dying duck lol |
Guest Guest
| Subject: Re: All-Terrain Murray aka Hellpussy :mtd2fst4u: April 16th 2015, 5:28 pm | |
| im just afraid of the future holds for this motor so far makes my 2nd opposed and both i have owned starters are bad lol heard they love going through them too lol |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 4914 Posts : 1068 Location : New jersey
| Subject: Re: All-Terrain Murray aka Hellpussy :mtd2fst4u: April 17th 2015, 11:07 pm | |
| The starter on my opposed twin is bad too so i took it apart and cleaned it. seemed to help some. but i will eventually replace it. I think the bushing or whatever you call the thing that the shaft goes threw is egg shaped so the starter doesn't work right. | |
crafsmankiller Member
Age : 26 Join date : 2012-10-18 Points : 4655 Posts : 412 Location : livingston texas
Guest Guest
| Subject: Re: All-Terrain Murray aka Hellpussy :mtd2fst4u: April 19th 2015, 5:16 pm | |
| i am soon after i make sure she will run on her own and a new starter i wanna make sure the carb is bug free and pump is working properly first before i try pull starting it and it does nothing but a sore arm and some pride hurt lol i cant get nothing down all this rain every single motha flipping day is getting old
Guest Guest
| Subject: Re: All-Terrain Murray aka Hellpussy :mtd2fst4u: April 22nd 2015, 4:58 pm | |
| Great news!!! The opposed twin lives guys after the starter gear exploded the first attempt put another gear on boom she running video of it running on fb and picture of the gear as well |
ThePinkMTD New Member
Age : 33 Join date : 2014-07-02 Points : 3570 Posts : 10
Guest Guest
Guest Guest
| Subject: Re: All-Terrain Murray aka Hellpussy :mtd2fst4u: May 25th 2015, 8:27 pm | |
| [url= ] so u thought i was done with the mower world...nope i cant and figured i can leave it, at-least not till this one is done, so soon as i recived the frame back which i did sell but the kid had to get rid of his toys so i got it back for 20 bucks in scrap metal, soon as i got it back that day i fixed my transaxle, re-greased it bolted it all back down, found a neat trick how to put the shifting ball back in which was hell the other way around lol got it all back together bolted it in put my pulley on bolted it down put my wheels all back on and i dont like rear snap rings that hold my rear wheels on so i will do a something about it later, put my 2 inch body lift on her mainly just raised the rear fenders so i could clear those 22x11x8s out back and this is how she sits now before tires rubbed and now it dont, next is belts idler pulleys and getting that big ol opposed twin up and going new carb rebuild kit and starter...then the wiring comes into play and i already have my bumper so thats good aswell then after i get that all aligned out i will start with the paint sanding and primer after she is fully moving on her own and no problems then i might buy my locker kit i want after i do a few test runs i found out that i do want it locked after all |
Guest Guest
| Subject: Re: All-Terrain Murray aka Hellpussy :mtd2fst4u: June 23rd 2015, 2:04 am | |
| " /> the paint scheme color 1 i have found that i will use on this build reason to the name barney lol still have 2 more colors to choose from still undecided i know black and gray most likely |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 29 Join date : 2010-05-12 Points : 6138 Posts : 899 Location : PA pittsburgh and pymatuning
Guest Guest
| Subject: Re: All-Terrain Murray aka Hellpussy :mtd2fst4u: June 23rd 2015, 12:53 pm | |
| lol red ive been hunting for a good purple and finally decided on that one was trying to go with the best with what i thought would fit the body pretty good im also using black and some sort of gray not sure if u will use a dual gray gun metal gray matalic gray or what ever but i will be using some good primer tho last time i painted and didnt primer looked like a turd lol |
