| | HELP!!!! PULLEY SWAP | |
samwillis211 New Member
| Subject: HELP!!!! PULLEY SWAP February 22nd 2015, 8:48 pm | |
| i want to swap the pulleys on my 11hp craftsman to go at least 25mph it has two forward speeds and reverse what size pulleys should i use to accomplish my goal | |
Age : 25 Join date : 2013-11-13 Points : 5208 Posts : 1311 Location : NW USA
| | | | Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 4914 Posts : 1068 Location : New jersey
| | | | LAWN MOWER MUDDER Established Member
Age : 23 Join date : 2013-04-08 Points : 4971 Posts : 913 Location : Central Pa
| Subject: Re: HELP!!!! PULLEY SWAP February 23rd 2015, 9:59 pm | |
| I run a 4.5" on the motor to a 3" on the transaxle. With 19-20" tires and without the governor she cruises right around 25. Now when I am cranking the high rpms from my motor I could pass out my dad on his side-x-side who was doing 25.
Your gear ratio can depend on a lot of little stuff too. Like for example ,the bigger tires you run, the faster it'll go. Also if you take the governor off your engine it may speed up a little bit.
The bigger the pulley on the motor the faster it'll go, just remember that. lol | |
| | | willysjeepmb Member
Age : 28 Join date : 2014-11-23 Points : 3530 Posts : 101 Location : Elora, Tn
| Subject: Re: HELP!!!! PULLEY SWAP February 25th 2015, 1:09 am | |
| Right now I run dead on 20mph. I don't know what my front pulley is, but its the factory one with the trans and deck drive. I run a 3" on the rear with a 6 speed and 20" tractor supply atv tires. Also, stock clutch with stock spring plus 3 trampoline springs. With my setup I use a 86" belt.
A little advice. Don't use cast aluminum 3" pulley on the rear. The shaft part got wore out in a week, because of the belt tension. It is so loose, at a idle it sounds like a rod knocking. If you use cast aluminum pulley on the rear, go no smaller than 4", I used one for 5 months before I wanted to go faster. | |
| | | Doc Sprocket Site VIP
Age : 50 Join date : 2013-04-21 Points : 7080 Posts : 2914 Location : Ontario Canada
| Subject: Re: HELP!!!! PULLEY SWAP February 25th 2015, 7:15 pm | |
| Not to bring the hate or anything, but from an engineering perspective, I would not suggest a 3" rear pulley and gobs of spring tension. 3" is really too small to get an effective amount of grip under a large load without artificial enhancement, such as your trampoline springs. So what the problem is?
All that tension is creating one hell of a radial load on the engine's crankshaft bearings and the tranny input shaft bearings. Much better to use larger pullies and save the added stress. | |
| | | willysjeepmb Member
| Subject: Re: HELP!!!! PULLEY SWAP February 25th 2015, 8:10 pm | |
| - Doc Sprocket wrote:
- Not to bring the hate or anything, but from an engineering perspective, I would not suggest a 3" rear pulley and gobs of spring tension. 3" is really too small to get an effective amount of grip under a large load without artificial enhancement, such as your trampoline springs. So what the problem is?
All that tension is creating one hell of a radial load on the engine's crankshaft bearings and the tranny input shaft bearings. Much better to use larger pullies and save the added stress. When I find a good way to build a clutch for a bigger pulley setup I'm going to shoot for a 6" to 5". | |
| Who is online? | In total there are 13 users online :: 0 Registered, 0 Hidden and 13 Guests
