| Craftsman "Champ" Build | |
+9Thunderdivine Creepycrawler redlinemotorsportts craftsmancole willis923 k2500life Speedfreek241 TroyBilt Pony WilliesBuilds 13 posters |
WilliesBuilds Member
Age : 28 Join date : 2013-06-19 Points : 4332 Posts : 329 Location : Florida
| Subject: Craftsman "Champ" Build November 15th 2013, 9:45 pm | |
| Just got a new craftsman mower its older I need help identifying the model and stuff like that?
Last edited by WilliesBuilds on May 1st 2015, 9:25 am; edited 2 times in total | |
Join date : 2013-06-01 Points : 4573 Posts : 578 Location : West Virginia
Speedfreek241 Member
Age : 25 Join date : 2013-07-12 Points : 4092 Posts : 137 Location : Loxahatchee
| Subject: Re: Craftsman "Champ" Build November 15th 2013, 10:28 pm | |
| - Speedfreek241 wrote:
- Look like a 93 lt 1000
how do I find what model spicer it is ? these transaxles are "ok" so ive heard not the best | |
k2500life Veteran Member
Age : 26 Join date : 2013-06-19 Points : 5134 Posts : 1135 Location : Southern Florida
| Subject: Re: Craftsman "Champ" Build November 15th 2013, 10:57 pm | |
| Pretty nice mower umm the numbers should be on the top or bottom of the transaxle | |
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5524 Posts : 1408 Location : Galway NY
| Subject: Re: Craftsman "Champ" Build November 16th 2013, 3:40 pm | |
| - willis923 wrote:
- strong engine! make sure you read your instructions though.. LOL
im telling you dude nothing beats these 12.5 ponys lol haha:lol!: | |
| Subject: Re: Craftsman "Champ" Build November 19th 2013, 9:46 pm | |
| So the grill on my craftsman was loose and upon further inspections it seems the 2 bottom bolts were missing the threads so I bought the hammer in thread at LOWES 4pcs for like 2-3$ along with some 1/4 x20 bolts for it and it seems to fit nicely ill check it out tmrw at work | |
| Subject: Re: Craftsman "Champ" Build November 19th 2013, 9:47 pm | |
| oh and the grill was cracked so I had to weld the plastic on it seems to look better now | |
Age : 24 Join date : 2013-04-05 Points : 4725 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: Craftsman "Champ" Build November 20th 2013, 8:46 am | |
| - craftsmancole wrote:
- I have a plastic welder, aka a lighter
yup or in my case a soldering iron lol | |
| Subject: Re: Craftsman "Champ" Build November 20th 2013, 8:51 am | |
| oh.. lol. in my shop class, we have an actual plastic welder. idk how to use it though... uses compressed air and plugs into the wall and what not.. i dont know, might fire it up one of these days | |
| Subject: Re: Craftsman "Champ" Build December 20th 2013, 8:22 am | |
| and this is the craftsman engine im currently working on , broke a head bolt idk how ... any suggestions | |
Age : 27 Join date : 2013-03-18 Points : 7246 Posts : 3131 Location : raleigh nc
| Subject: Re: Craftsman "Champ" Build December 20th 2013, 8:32 am | |
| You can weld a bolt on there, someone on here might have a better suggestion tho. At worse you might have a drill and tap a new hole. | |
Age : 36 Join date : 2013-07-02 Points : 4782 Posts : 731 Location : Logan Ohio
| Subject: Re: Craftsman "Champ" Build December 20th 2013, 8:46 am | |
| dont weld a bolt, find a nut that just barely slides over the broken stud, weld it on hot, I mean almost melting the nut hot. let it cool for about 3 mins and then it will come right out. the welder heats up the stud and will break it loose. | |
| Subject: Re: Craftsman "Champ" Build December 20th 2013, 8:48 am | |
| - Creepycrawler wrote:
- dont weld a bolt, find a nut that just barely slides over the broken stud, weld it on hot, I mean almost melting the nut hot. let it cool for about 3 mins and then it will come right out. the welder heats up the stud and will break it loose.
...oops, i ment nut duh... | |
| Subject: Re: Craftsman "Champ" Build December 20th 2013, 9:11 am | |
| it happens I myself have welded bolts and had them work, but I have alot better luck with nuts. wow that sounds kinda dirty now | |
| Subject: Re: Craftsman "Champ" Build December 20th 2013, 4:09 pm | |
| you might be able to bite on it with vice grips. but like the others are suggesting, weld a nut on, weld it super hot, and back it off | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6306 Posts : 2101 Location : Norway, Europe
| Subject: Re: Craftsman "Champ" Build December 20th 2013, 5:26 pm | |
| Dremel or hacksaw a flathead in the remaining bolt, then use a flat screwdriver. | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4342 Posts : 467 Location : Greensburg, PA
