| MTD Mower ATV engine swap | |
Mud Machine New Member
Join date : 2015-08-03 Points : 3171 Posts : 8 Location : Australia
MLTOYS New Member
| Subject: Re: MTD Mower ATV engine swap September 29th 2015, 7:03 pm | |
| I was going to possibly do the same with my Agway. I have a polaris 250 motor and the f/r gearbox for it. | |
Age : 34 Join date : 2013-11-02 Points : 6925 Posts : 2906 Location : New Jersey USA
| Subject: Re: MTD Mower ATV engine swap September 30th 2015, 1:11 pm | |
| Maybe a little less power than you had originally, but might be neat. OHC is pretty interesting. I thought most of those things were 2 strokes. | |
| Subject: MTD Mower ATV engine swap September 30th 2015, 7:31 pm | |
| I'm hoping to gear it down a bit using a centre sprocket since the engine has 3 forward gears | |
MLTOYS New Member
MLTOYS New Member
| Subject: Re: MTD Mower ATV engine swap October 10th 2015, 9:25 am | |
| Looks like its going to be a cool build. Are you going to drop down to a jackshaft then to rear or just challel it through ?
| Subject: Re: MTD Mower ATV engine swap October 10th 2015, 7:45 pm | |
| Nope I am going to do it straight through to the rear axle with a chain and some tensioners | |
| Subject: Re: MTD Mower ATV engine swap October 10th 2015, 10:38 pm | |
| Neat, I love new parts. Is suggest bracing the frame up on those because they are very weak, like welding sections together, running 1x1" stock down the hole length, and some cross braces should get it really stuff and good for handling. | |
| Subject: Re: MTD Mower ATV engine swap October 12th 2015, 1:53 am | |
| Sorry Redline we already built the mounts before your post but I reckon that I can do some extra bracing | |
thewisconsinredneck5160 Member
Age : 25 Join date : 2015-02-16 Points : 3378 Posts : 40 Location : Brookfield WI
| Subject: Re: MTD Mower ATV engine swap November 3rd 2015, 7:36 pm | |
| since your doing a solid axle and a verticial chain drive, you should think about a rear swing arm suspension, that would be really neat | |
