| Anyone Thought About Doing A Dual Engine Tractor? | |
+10Ariens YT11 crafsmankiller jaymz_eric dangeroustoys56 muddstir W1ldyOvvnZ Chopperhed Jamus Craftsman Dude CornishMorgan 14 posters |
CornishMorgan Member
| Subject: Anyone Thought About Doing A Dual Engine Tractor? November 21st 2012, 7:48 pm | |
| Just wondering if anyone has ever considered building or built a dual engine tractor. Basically, getting 2 tractors the same, getting rid of the front axles of both units and putting the 2 tractors together and using hydraulic rams for steering. I would have thought you'd have enough power for almost any job and it wouldn't have drive shafts or universal joints to snap or brake. I like the idea of 4 wheel drive, perpendicular suspension and articulated steering on a lawn tractor, would be interesting to drive. Just thought I'd throw the idea out there and see what you guy think. | |
Craftsman Dude Member
Age : 29 Join date : 2012-09-08 Points : 4375 Posts : 145 Location : MS
| Subject: Re: Anyone Thought About Doing A Dual Engine Tractor? November 21st 2012, 7:58 pm | |
| I thought about extening the frame and mounting two engines in one tractor before but i never had two identical engines .I like the idea you have posted better tho allows for 4 wheel drive and would just be awesome . | |
Jamus Established Member
Age : 44 Join date : 2010-06-28 Points : 5569 Posts : 511 Location : Southern WV
| Subject: Re: Anyone Thought About Doing A Dual Engine Tractor? November 21st 2012, 8:47 pm | |
| Using our little lawn mowers and building it like the picture would be a lot of wasted space. You could run 2 engines and 2 transaxles with a hinge in the middle for steering, but all that extra frame and belting would not be needed. The hardest part I see would be contols, like shifting linkages, clutches, etc. | |
Chopperhed Moderator
Age : 57 Join date : 2012-10-14 Points : 5017 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Anyone Thought About Doing A Dual Engine Tractor? November 21st 2012, 9:20 pm | |
| throttle and brake can be handle by push/pull cable from an old boat, or something similar.
trans shifting would be the biggest issue, both tractors would need to be identical drive line wise.
For variable belt F-N-r setups, the variable speed lever could be managed by a push/pull cable setup. The FNR shifting could be accomplished similarily.
If its a multi speed gearbox, a system of shafts and universals is required. Look at a shift linkage setup on a cabover highway tractor for ideas
Last edited by Chopperhed on November 23rd 2012, 12:18 pm; edited 1 time in total | |
W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5014 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: Anyone Thought About Doing A Dual Engine Tractor? November 21st 2012, 9:56 pm | |
| I know a friend who used to have one of those tractors, he actually used it fairly often for small chores around the farm, one night he parked it in a shop they were moving, the building was given to him from his neighbor so he pulled it across the yard and parked it, he parked his tractor in it because there was a storm warning and didnt have enough fuel to park it in the original shed and the next morning the entire shop fell down because he didnt have time to get a footing done the day before. He ended up just getting rid of it since he got the tractor on a deal because both tractors werent running and he had made it into one of those. I had thought of the lawn tractor setup but I thought it would look funny and didnt know how I would make the steering work well, on that they have hydraulic cylinders for steering normally isnt it? | |
muddstir Member
Join date : 2012-01-22 Points : 4800 Posts : 318 Location : Western,PA
| Subject: Re: Anyone Thought About Doing A Dual Engine Tractor? November 21st 2012, 10:00 pm | |
| When I was in vo-teck for machine shop class we had shop project that the year before started it was a dual engine tractor. It had two 8hp briggs on it, dont know how much the frame was extended but it wasn't alot. We only worked on it a handful of times then the teacher stopped coming in so we ended up with subs for rest of the year. The next year the new teacher junked it.
Then somewhere on the net I saw a lawnmower converted into a pullin tractor, the frame was extended atleast 2 feet and had three snowmobile motors on it. Don't remember what size they were but it looked sweet. Ill have to hunt up a pic of it sometime. | |
Age : 53 Join date : 2010-02-10 Points : 6839 Posts : 1726 Location : Florida, USA
| Subject: Re: Anyone Thought About Doing A Dual Engine Tractor? November 23rd 2012, 10:01 am | |
| I have pics somewhere of a guy that used two cub cadets similar to the pic of the blue one posted - wasnt much larger then the original tractor- hinged in the middle - probably used some sort of wheel brakes ( similar to a bulldozer) to steer it. Hot rods/dragsters back in the day ran multiple motors, but usually just a single trans. The 'Hurst Hairy Olds' was one that ran two motors and two transmissions - had something like 2000 HP: Id say for something in a tractor , pick a large GT- mount a noma 4 wheel steer trans up front hooked to a motor, and a standard trans with a motor in back - hook them up similar to a RER tractor where the motor is real close to the trans or even over it. Id say a whole custom chassis would be needed, to lay it out right , then sheetmetal fitted over it. For another dual engine mod, use two motors and one 'trans' - use a couple right angle gear boxes hooked to the wheels ( one left- one right) similar to a z turn - run separate belts to each RAGB - best bet would be to run go kart clutches or some type of MTD variable drive setup instead of a actual trans . | |
jaymz_eric Member
| Subject: Re: Anyone Thought About Doing A Dual Engine Tractor? November 27th 2012, 12:33 am | |
| why couldnt you widen the front of the frame, mount two identical engines side by side, mount another identical pulley on the rear above the existing one, run a belt from each motor to a pulley and then rig up a double pulley clutch system to disengage both motors at the same time, wire the ignition to fire both at the same time, fuel lines and finally a throttle cable splitter setup....wouldnt that work in theroy or would it still be like having one motor since everything would be identical?? | |
crafsmankiller Member
Age : 26 Join date : 2012-10-18 Points : 4656 Posts : 412 Location : livingston texas
| Subject: Re: Anyone Thought About Doing A Dual Engine Tractor? November 27th 2012, 8:48 am | |
| Anything is possible with some tweeking - i was tinkering with a dual carb setup on a opposed twin i have - biggest issue was hooking the governer up.
The issue with 2 motors up front for power actually defeats the purpose - besides weighing a whole lot more ( steering issues) and hooking them up - youre better off just getting a larger motor. The front and back motors would make more sense.
Id say the easiest way to hook up two motors is to use horizontal shaft motors and use some sort of gear box . | |
Age : 27 Join date : 2012-10-31 Points : 4927 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: Anyone Thought About Doing A Dual Engine Tractor? November 28th 2012, 12:20 pm | |
| the second link is cool, the first one looks completely stock, if you could say that seein 2 engines on it. i would rather have the second one as a mudder, if a engine blows you have 3 more! | |
| Subject: Re: Anyone Thought About Doing A Dual Engine Tractor? November 28th 2012, 4:49 pm | |
| - Chopperhed wrote:
- Here's a quick and dirty Microsoft Paint image that might be cool
You'll notice the front tractor has been shortened That's what I was thinking of. That looks awesome, I may have to build one of those at some point . | |
TheEquineFencer Member
Join date : 2013-02-19 Points : 4184 Posts : 90 Location : Farmville,NC, USA
Doug Site Owner
Age : 28 Join date : 2012-12-24 Points : 7532 Posts : 3035 Location : Lebanon County, PA
| Subject: Re: Anyone Thought About Doing A Dual Engine Tractor? February 22nd 2013, 10:47 am | |
| - TheEquineFencer wrote:
- Witha hydrostatice drive you could probably get the two rears to run at the same speed if you did the linkage right.
Could always run a geared rear and a hydro front. Then it could be selective 4wd. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
steeldaytonas Member
Age : 41 Join date : 2015-10-23 Points : 3174 Posts : 77 Location : petawawa,Ontario, Canada
Age : 34 Join date : 2013-11-02 Points : 6926 Posts : 2906 Location : New Jersey USA
| Subject: Re: Anyone Thought About Doing A Dual Engine Tractor? January 2nd 2016, 11:48 pm | |
| Just read through this thread. This comes to mind. I don't see why it would have to be hydrostatic though. Seems like it would be just as easy to hook two conventional setups together. If you wanted to hinge the middle, you'd need a pretty beefy hinge. | |
